[Google translation]
imxrt1052 eflexpwm low frequency output
AHB_CLK 600M, IPG_CLK150M, how to output 1hz pwm waveform without reducing frequency. According to the maximum subdivision of 128, the minimum 16bit comparator is only 150M/128/65535=17.88HZ, which cannot reach 1hz. The output frequency varies from 50khz to several hz. Don't know how to implement it
Thank you so much for your interest in our products and for using our community.
You can take as reference the following idea, you just needed to do the math for the desired frequencies.
Clocking the eFlexPWM with an External Clock Signal (EXT_CLK) on i.MX RT Series
You will see something like this:
Hope it helps you.
Have a nice day!
Hope it helps you.
Have a nice day!
