iMXRT1170 configuring M.2 port for configuring CYW43439
b_Tushar
I want to configure the imxRT1170 and want to configure the CYW43439 using M.2
can you share the procedure. Since fairly new to kit and IDE,
Step by step guide would be appreciated.
Along can you share the guide to port the freeRTOS and bt stack
Omar_Anguiano
The configuration of m.2 is though the SD module on the device, the configuration will depend on the device to connect. To start the configuration it will be helpful first configure the pins, this can be done with Config Tools on MCUXpresso.
Omar
b_Tushar
