I am using iMXRT1064 device. I wanted to use conditional statements in linker file such as #ifdef
If we can use then what is the syntax for it?
Anuj
Hi Anuj Tanksali,
Thank you for your interest in NXP Semiconductor products and
for the opportunity to serve you.
Firstly, the linker file is configurable, however, the format of the linker file is not the same for the different IDEs, so I'd highly recommend you to refer to the user guide of the corresponding IDE to learn how to manage the linker file.
TIC
Hello jeremyzhou,
Thank you for your reply.
I have already gone through the MCUXpresso 11.1 user manual and it does not contain any information about using the pre-processor directives such as #ifdef in the linker file. Could you please point me to any link or information if available.
Anuj
Hi Anuj Tanksali,
Thanks for your reply.
I've not found the ifdef syntax in the GNU linker guide, however, I'd like to suggest you try this method as the post presents.
TIC
