i want use a hardware delay instead of vtaskdelay()
1,486 次查看
nsnmaniram
hi,
there is any way to implement a hardware delay on imxrt1050 instead of vtaskdelay().
Maniram
1,384 次查看
davidrozenski
Somethings like that :
static void delay(uint32_t val)
uint32_t coreClock = SystemCoreClock; /* in Hz */
uint32_t ticksPerMicroSec = coreClock / 1000000; /* Target runs at 600 MHz => 600 */
volatile uint32_t ticksToWait = 1000 * val * ticksPerMicroSec / 8; /* Divide by 8 to get proper timing */
while(ticksToWait--)
__asm("NOP"); /* delay */
However I do not recommend since you will lock all tasks by doing this.
