i.mxrt1170: CAN Bus trace impedance controller
haryanl
Hi NXP team,
we are designing a CAN FD Port (RT1170 +TJA1057BT/0Z)
can you tell us is it necessary to control (CANH/CANL) trace impedance as differential signal? And if yes, how many Ohm (120Ohm?) to control
or like Single-Ended Signal (50Ohm) is enough
Huy
Labels (2)
Tags (2)
Gavin_Jia
Hi @haryanl ,
Thanks for your interest in NXP MIMXRT series!
Yes, and the target impedance is 120 ohm. The schematic you provided is referenced to the correct section.
Gavin
Gavin_Jia
Hi @haryanl ,
Gavin
haryanl
Hi Gavin,
Thank for your reply
We got it
Huy
