I am using SLN-LOCAL-IOT and need to add some external sensors to it's ADC interface - going to use both ADCs. Looking through the SDK I haven't found any reference to the ADC except the registers configuration in MIMXRT106L.h and MIMXRT106L_features.h. There ar no fsl_adc.x drivers available.
Also, when trying to configure it using Config Tools (pins, peripherals) I get error "Peripherals tool does not support selected processor " and there is no option to update the tools.
Could you please point me to an application note/code that can be used for SLN-Local-IOT configuration. and how can I resolve the configuration tools issue?
Thank You,
Alex
