i.MXRT1050 LCD dot clock setting
sugiyamatoshihi
Contributor V
When i.MXRT1050 connect to LCD, how to set  DOT clock of LCD?
Does dot clock is direct to connect LCDIF_CLK_ROOT?
Is there any clock divider between LCDIF_CLK_ROOT to DOT clock?
Sugiyama
fangfang
 Unfortunately, I can't find the other register for LCKIF clock. But the  DOT clock please refer to the document. URL:https://www.nxp.com/docs/en/application-note/AN12302.pdf.
fangfang
You can  set the DOT clock refer to the reference manual.The LCD_DOTCLK is max 75MHz, see LCDIF_CLK_ROOT in Reference Manual. And defult the value of the divider is 1 between with LCDIF_CLK_ROOT to DOT clock. Hope it help you.
TIC
sugiyamatoshihi
Contributor V
Hi, TIC team,
Thank you for your answer.
I' not sure which divider are you specified LCDIF_CLK_ROOT to DOT clock?
I can see LCDIF_PODF(default=1/4), and LCDIF_PRED(default=1/4), but I couldn't  find the other register for LCDIF clock.
Could you specify the register name?
Sugiyama
fangfang
sugiyamatoshihi
Contributor V
Hi, fangfang,
I understood.
Sugiyama
