[i.MXRT 600] Wrong description in readme for A2DP sink demo
2,096件の閲覧回数
Tomoki_Kimura
Hi, I have taken pains to run A2DP sink demo on EVK-RT685 and AW-AM457 because of wrong decription of readme.txt.
AzureWave Solution Board settings
Jumper settings for AzureWave AW-AM457-uSD Module:
- J11 2-3: VIO_SD 3.3V (Voltage level of SDIO pins is 3.3V)
- J2 1-2: 3.3V VIO_uSD (Power Supply from uSD connector)
- J4 2-3: 3.3V VIO
- JP7 1-2
- JP8 1-2
should be
- J4 2-3: 3.3V VIO
Jumper settings for evkmimxrt685 Module:
- JP7 1-2
- JP8 1-2
2,083件の閲覧回数
kerryzhou
Hi @Tomoki_Kimura ,
     I find you are my NXP colleague.
    You mean in the SDK:
\SDK_2_12_0_EVK-MIMXRT685\boards\evkmimxrt685\edgefast_bluetooth_examples\a2dp_sink
  The following part add:
Right, I will help you to report to our SDK team.
Thanks!
If you find the SDK bug, you also can report to the SDK team in jira!
Kerry
3 返答(返信)
2,078件の閲覧回数
Tomoki_Kimura
Thank you.
I will report to the SDK team in jira from now on!
2,074件の閲覧回数
kerryzhou
Hi @Tomoki_Kimura ,
   Thanks!
   This issue I already help you report it, then jira link is:
https://jira.sw.nxp.com/browse/MCUX-52237
Kerry
2,084件の閲覧回数
kerryzhou
Hi @Tomoki_Kimura ,
Thanks!
Kerry
