i.MX RT1170
i.MX RT1170
huuuyendt1
Are there any model numbers in the i.MX-RT series that can support 4K resolution?
EdwinHz
Hi @huuuyendt1,
The maximum resolution is capped by the MIPI bandwidth, which would be in turn limited by the maximum peripheral frequency. You can support 4K resolution, but your frame rate will be low. The following post provide much more information about this topic:
i.MX RT1170 display maximal resolution - NXP Community
BR,
Edwin.
