i.MX RT1170 VDD_SOC_IN vs. VDDA_SOC_IN
cdidear
Can someone confirm whether VDD_SOC_IN and VDDA_SOC_IN are referencing the same voltage domain? IMXRT1170CEC Rev2 only mentions VDD_SOC_IN. IMXRT1170RM Rev1 mentions both VDD_SOC_IN and VDDA_SOC_IN, but doesn't mention whether they are related, at least not as far as I can tell.
Edits:
I also noticed that VDDA_MIPI_1P8 is only found in the RM and VDD_MIPI_1P8 is only found in the datasheet (IMXRT1170CEC).  Are these also the same?  Similar story with VDDA_USB_1P8.  These are more obvious to me to be the same, but I am still trying to understand how the core voltage is boosted with FBB and want to make sure VDD_SOC_IN and VDDA_SOC_IN are the same.
Charlie
Tags (2)
jeremyzhou
In my opinion, they all stand for the same pins.
VDD_SOC_IN, VDD_MIPI_1P8 and VDD_USB_1P8 are correct, I'll report the typos for the Doc team for checking.
TIC
jeremyzhou
TIC
