I have a i.MX RT1050 Crossover MCU and MT25TL01G QSPI, and I want to customize a flashloader for IAR in order to load my code into the external memory .
1)Does anyone have a source code of flashloader for a customized board that may help me?
2)Does anyone have some documents, tutorials about how to make my own flashloader ?
Ramzi
解決済! 解決策の投稿を見る。
Hi dridiramzi,
You can find flashloader demo in IAR install directory. (IAR Systems\Embedded Workbench 8.4\arm\src\flashloader\NXP\FlashIMXRT1050_EVK_FlexSPI)
The user guide is \IAR Systems\Embedded Workbench 8.4\arm\doc\FlashLoaderGuide.ENU.pdf
Jing
Hi Jing,
Thanks for your answer
does NXP offer a method to generate customized flashloaders (even using MCUXpreso) so that it will be more easier for users to make them own flashloaders?
example of method((as input GPIO,QSPI instruction...etc,and as output customized flashloader))
Does NXP offer a customized flashloader or a flashloaders support for external memories other then the one used with the IMXRT1050_EVK?
Ramzi.
No, we use IAR demo project to generate flash bootloader too.
NXP doesn't support RT1050 QSPI flash algorithm one by one since there are many kinds of flash in the market. We tell customer how to make it by themselves.
Jing
Hi dridiramzi,
Jing
