I want use the i.MX RT1024 with an external 64MB SDRAM. As per the datasheet it supports 8/16-bit SDRAM External memory interfaces. Which mode is better from performance perspective and how ? Please let me know if there is any link/reference to go through for this details. Thanks
解決済! 解決策の投稿を見る。
Hello @Jigs,
The usage between 8/16-bit SDRAM could have the following differences:
We share you an interesting application note relating with the performance optimization of the i.MX RT Series, that could be useful to the topic: AN12437: i.MX RT Series Performance Optimization – Application Note.
Finally, we share some community post using 8bit SDRAM:
Best regards, Raul.
Hello @Jigs,
Best regards, Raul.
Thank you @RaRo . Really appreciate your detail explanation on this.
