i.MX RT minimal circuit
3,005 次查看
paulson2003
Hello. I want to start programming the i.MX RT1064. But I need a minimal wiring of the microcontroller. Can you please continue to help me to give a circuit diagram(min. Schematic) with minimal wiring. Thank you.
标记 (1)
2,809 次查看
jeremyzhou
Hi Alex Kaboomski ,
the opportunity to serve you.
To provide the fastest possible support, I'd highly recommend you to refer to the schematic of the MIMXRT1064, in addition, I've attached the schematic of Mini i.MX RT1052 and please check it.
TIC
