Dear all
I wanted to start with i.MX RT series and has been wondering when the brand new i.MX RT 1170 dev board will be available? I'm considering 1064 as well, but I'm curious about the MIPI CSI interface. Thanks.
Solved! Go to Solution.
Hi LUKASZ,
As I know, RT1170 EVK will available on October. If you are interested in RT1170, start from RT1060 is a good idea. Their structure are similar. Learning i.mxRT is a bit harder than normal MCU. Moving from RT1060 to RT1170 will be more quickly.
RT1170 has MIPI CSI interface, but RT1064 hasn't.
Jing
Hi LUKASZ,
Jing
