how to use new dsp bin file in CM33
552件の閲覧回数
LUBEN
I'm using the evkmimxrt685_dsp_audio_demo_bm_cm33 demo, and my problem is that the new DSP firmware I want to use in the compilation of CM33 doesn't actually work.
          I've also updated the bin file in the audio_demo_bm\dsp\binary   directory, and I need to know how I need to configure it in the MCUXPRESSO IDE to use the new DSP firmware.
494件の閲覧回数
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, but I need more information is not enough to understand your situation. Could you elaborate further? use an image is you might be necessary.
Pavel
