I'm tring to use evkmimxrt1020_flexspi_nor_polling_transfer example with my own flash, what do i need to take care of in order to do that?
Thank you,
merav
Hello Merav,
Have you already run any other projects from that memory? If so, then you already have the correct driver for the memory, which means that to run the example evkmimxrt1020_flexspi_nor_polling_transfer, you just need to modify the function flexspi_nor_flash_init.
Victor
