Hi Edwin,
Thank you, that make sense.
Just wondering who would be able to set the PERSIST_REDUNDANT_BOOT bit?
For example, if the boot ROM fails to boot the first firmware copy, it could try to boot the second firmware copy if PERSIST_REDUNDANT_BOOT is set (to 1). However, if the first firmware copy does not boot, it will not be able to update the PERSIST_REDUNDANT_BOOT bit.
Thanks and regards,
Richard
