Hi !
i am using a program based on the lpspi_polling_btb_transfer_master SDK example to communicate a flash device and is working ok.
the issue is the frequency
its unstable and maximum reaching 920KHz
we need to reach 12.5 MHz like on this transaction which microchip device :
in addition we would like to cancel the gap between every byte like in the photo above, make the clock continuous.
any help will be blessed
thank you!
