bluetooth stack in SDK v2.14.0 for MIMXRT1060-EVKB
uzzzuuu
I tried to build SDK v2.14.0 for MIMXRT1060-EVKB, edgefast_bluetooth stack was not in the middleware list.
I could select it in the previous SDK versions though.
v2.14.0 does not include BT middleware?
#MIMXRT1060
benjaminaxiles
Hello, where you able to run a Bluetooth application on the MIMXRT1060-EVKB? Are you using a wireless module connected by the M.2 connector ?
kerryzhou
Hi @uzzzuuu ,
  Yes, you are right, SDK2.14.0 for RT1060-EVKB didn't add it.
  You can download the SDK2.14.1 for the MIMXRT1060-EVKC, that code have it :
https://mcuxpresso.nxp.com/en/builder?hw=MIMXRT1060-EVKC
Wish it helps you!
Kerry
