Using VGLite with custom Display
1,003 次查看
Bedair
    I'm currently building a new board based on i.MX RT1176 microcontroller to driver a custom Display. I managed to communicated with display via MIPI-DSI interface to initialize the display but when I try to use VGLite to show images on the display I didn't work.
    My question is how to start debugging such issue? and what may be the reason for such issue?
950 次查看
Bedair
Issue now fixed, it was because of the clock configuration.
951 次查看
Bedair
988 次查看
CarlosGarabito
hi @Bedair The most probably is that your connection with the display is wrong, i suggest that check our design as reference for your connection with the LCD
https://www.nxp.com/webapp/sps/download/preDownload.jsp?render=true
Have a good day
