Using MFGtools with MIMRX1170-EVK
fmabrouk
@kerryzhou
Hello Kerry!
I am trying to use MFGTool with my new dev board iMX RT1176xxxxA. I followed the same steps used with MFGtool with iMX RT1060, but I could not get the blinky LED to work. I attached the files I generated.
I also added these to my IDE: XIP_EXTERNAL_FLASH=1, XIP_BOOT_HEADER_ENABLE=0,XIP_BOOT_HEADER_DCD_ENABLE=0.
Please have a look and see if I am missing anything.
@kerryzhou
kerryzhou
Hi fmabrouk,
 Thanks for your patient.
  1. Check python version, I am using python 3.7.0
2. MCUbootUtility tool path
 Don't put in the long length path, you can put it in the desktop.
3. This is my MCUbootUtility RT1170 test result
Code has been downloaded, and it works.
Now, I am testing the MFGtool method, give you reply later.
Kerry
fmabrouk
Hello Kerry,
What is the difference between MCUBootUtility and this utility:
https://www.nxp.com/design/software/development-software/mcuxpresso-software-and-tools-/mcuxpresso-s...
Thank you,
Farid
fmabrouk
Could you please tell me where to download MfgTools for imxrt 1170?
fmabrouk
@kerryzhou
does the new Sdk for imxrt 1170 has an OTA demo code. I could not see it. ?
kerryzhou
No OTA demo for RT1170 now.
