Q1. If possible, what is the best method to get the micro's internal LUT updated at boot, before XIP from FlexSPIA?
A1. There is no way to do that.
Q2. The Flexspi NOR Polling Transfer example in the SDK creates a custom LUT, but does not use custom sequence enable or custom LUT sequences in the config - Is this not necessary since it is not used at boot?
A2. Yes, your understanding is correct.
Q3. Is there some other option to update LUT while XIP from FlexSPI A, besides executing out of RAM?
A3. There is no way to do that other than executing the LUT updating code from RAM.
Artur
