USB recognition error on uClinux
2,624 次查看
minkyu_shon
Hi.
i.MXRT 1060-EVK based board is under review.
 With the following :
There are cases when USB is recognized and not. There is a difference in the D+ waveform,
but I want to know the reason for the other part....
The circuit is as follows.
I'd like you to tell me if there is a problem...
Thanks.....
2,482 次查看
minkyu_shon
Hi. Victor....
A Linux (uClinux) Board Support Package is running fine.
If you look at the log above, boot is working fine.
Shon.
2,482 次查看
victorjimenez
Hi Shon,
Unfortunately, this board support package is from a third-party provider. I recommend contacting their support line, as they will be able to provide correct information.
If you would like to try our examples please download the SDK. There are several USB examples that can get you started.
Victor
2,482 次查看
victorjimenez
Hi SON MINKYU,
The circuit looks fine. Are you running a Linux (uClinux) Board Support package on your board?
Victor
