Dear All,
I'm using USB C type connector for powering my custom board.
Can the data lines of the USB C type be connected to USB_OTG lines of the imxrt1050?
PFA for the screenshot.
That is can we connect usb c type data lines to pins N7 & P7 of imxrt1050?
Solved! Go to Solution.
You can refer to our type-c shield demo, it is for RT, kinetis and LPC mcu.
Jing
Yes, please connect D+/D- to P7 & N7 if you want to use type C on OTG2.
Jing
Hi Jing,
Thanks for the response.
I've used data mux and data protector between USB-C type and imxrt1050.
Should that suffice?
Jing
