UART3 overrun error occurs RT1020
hanmant
I'm using uart3 interrupt of RT1020 ,i'm using uart3 for rs-485 communication and its speed is 3MBps.
Also, I'm using LPSPI4 CMSIS driver handler for other communication .
Individually uart3 works fine but after adding spi handler , it will start occurring Overrun.
Still im clearing overrun flag but why this flag is getting set .
Also ,one query when this flag set ,in this case will i receive all data or lost
Tags (2)
mayliu1
Hi @hanmant ,
I use MIMXRT1020-EVK board  as edma_b2b_transfer_master, MIMXRT1064-EVK board as edma_b2b_transfer_slave.
I create a project based on  MIMXRT1020-EVK board, I set this board as I2C master, add UART TX, UART RX, totally using 4 DMA channels.   I modify some code  both of MIMXRT1020-EVK project  and MIMXRT1064-EVK project.
The result is both projects run Okay.
So please check your code, the critical code I have shown you bellow.
Please try it, and tell me to close this case.
If you still have question, Please create a new case.
mayliu
hanmant
Hi @mayliu1 ,
Thanks for reply.
Currently im using DMA uart. I'm using uart interrupt.
Please see below code snippet.
hanmant
Hi @mayliu1 ,
Please Note Currently im not using DMA uart. I'm using uart interrupt.
mayliu1
Hi @hanmant
Thanks for your update information.
If you use UART interrupt to send and receive UART data, every UART byte will trigger a UART interrupt.
Your UART baud rate is very high(3MBps) and will cause frequent entry UART interrupt, which is unreasonable.
I don't recommend you to use the UART interrupt when the UART baud rate is so high.
Best Regards
mayliu
hanmant
Thanks for reply .
This overrun problem is coming after inclusion of spi cmsis handler.
mayliu1
Hi @hanmant
Question: This overrun problem is coming after inclusion of spi cmsis handler.
Answer: Due to the addition of spi cmsis handler, the entry of UART interrupt will be delayed and the UART data cannot be received in time.
mayliu
hanmant
So , I have to implement DMA uart then?
mayliu1
Hi @hanmant
I highly recommend you using the DMA UART , especially when UART baud rate is particularly high.
mayliu
hanmant
Hi @mayliu1 ,
As per your suggestion i configured uart in DMA but still see the losses.
I can see clear losses at receiver side(my receiver is another device comport).
mayliu1
Hi @hanmant
Thank you for your updated information.
Can you tell me when and where you call the DMA UART receive function interface?
"In the source files(lpuart_edma_transfer.c) you sent, I didn't see any calls to the DMA UART data receive interface."
Please try to verify it according to the steps shown below.
1: Set the DMA_UART interrupt priority to be higher than other modules.
2: Use ping pong buffer to receive UART data.
Wish it helps you.
Best Regards
mayliu
hanmant
Thanks for reply.
In this project i only send the data using DMA uart .
So the my receiver is Ti processor device.
I think priority does not matter in this example because here only DMA Uart is running.
I have tried to send 2 bytes of data but still same issue .
Give me solid solution to work this because this simple uart DMA transmission .
mayliu1
Hi @hanmant
As you said, if you only send UART data, why you ask me UART overrun error happened.
UART overrun error is related with UART receive.
and if you want to send UART data, It is very simple, just call LPUART_SendEDMA.
mayliu
hanmant
Hi @mayliu1 ,
Thanks for reply.
As of now im not using uart receiver .
whatever i shared with is only uart transmit only (size 52 buffer)but i dont receive correct data on my Ti board using dma.
mayliu1
Hi @hanmant
I think I know the reason of the problem.
Continuous data transmission in your program can cause Ti board UART receiver overrun, resulting in abnormal data transfer.
I suggest adding a delay after sending 52 bytes UART data, Please try it.
I have tested and verified this 100 times on my end, and the data sending and receiving are consistent.
Wish it helps you.
hanmant
Thanks for reply.
Can you please share your source code files.
mayliu1
Hi @hanmant
Just add a delay function, I have shown to you.
SDK_DelayAtLeastUs(100000, CLOCK_GetFreq(kCLOCK_CpuClk));
1:In addition, I suggest you check whether the data format for UART sending and receiving is consistent.
2:Please confirm whether your NXP development board and TI development board share a common ground.
3:Please confirm whether the connection between UART transmission and reception is secure.
mayliu
hanmant
Hi @mayliu,
Can you please tell me how to set Highest the Priority to DMA controller over CPU.
Also in DMA i want set the highest priority to UART receive and TX than SPI.
Please tell me the process and API's or any examples.
mayliu1
Hi @hanmant ,
I suggest you can use NVIC_SetPriority(IRQn_Type IRQn, uint32_t priority)function.
1: The first parameter is IRQn_Type:
It depends on your design, if UART3 using DMA channel 0(#define LPUART_TX_DMA_CHANNEL 0U), then the first parameter is DMA0_DMA16_IRQn.
2:The second parameter is priority, The lower value, the greater the priority  of the corresponding interrupt.
Best Regards
mayliu
hanmant
Hi @mayliu,
I'm thinking add this way,
const edma_channel_Preemption_config_t Channel_preemption_config = {
.enableChannelPreemption = false,
.enablePreemptAbility = true,
.channelPriority = 14U
const edma_channel_Preemption_config_t Channel14_preemption_config = {
.channelPriority = 15U
EDMA_SetChannelPreemptionConfig(EXAMPLE_LPUART_DMA_BASEADDR,LPUART_TX_DMA_CHANNEL, &Channel_preemption_config);
EDMA_SetChannelPreemptionConfig(EXAMPLE_LPUART_DMA_BASEADDR, LPUART_RX_DMA_CHANNEL, &Channel14_preemption_config);
is it correct or not.
please confirm
mayliu1
Hi @hanmant ,
Please review the differences between the following definitions and use them according to your needs.
EDMA_SetChannelPreemptionConfig: It is primarily used to configure the preemption priority of DMA channels, ensuring the most important task can be processed first, when multiple DMA tasks happened at the same time.
NVIC_SetPriority:  It is used to set the priority of interrupts, ensuring that high-priority interrupts can be responded to and processed by the CPU first when multiple interrupts happened at the same time.
Best Regards
mayliu
hanmant
Hi @mayliu,
Thank you for reply
lpuart_config_t lpuartConfig;
lpuart_transfer_t sendXfer;
lpuart_transfer_t receiveXfer;
edma_config_t userConfig = {0};
uint32_t uiCnt = 0;
/* Initialize the LPUART. */
* lpuartConfig.baudRate_Bps = 115200U;
* lpuartConfig.parityMode = kLPUART_ParityDisabled;
* lpuartConfig.stopBitCount = kLPUART_OneStopBit;
* lpuartConfig.txFifoWatermark = 0;
* lpuartConfig.rxFifoWatermark = 0;
* lpuartConfig.enableTx = false;
* lpuartConfig.enableRx = false;
LPUART_GetDefaultConfig(&lpuartConfig);
lpuartConfig.baudRate_Bps = UART3_BAUDRATE;
lpuartConfig.enableTx = true;
lpuartConfig.enableRx = true;
LPUART_Init(DEMO_LPUART, &lpuartConfig, DEMO_LPUART_CLK_FREQ);
// Set NVIC priority for the DMA interrupt to highest priority
NVIC_SetPriority(DMA0_DMA16_IRQn, NVIC_EncodePriority(NVIC_GetPriorityGrouping(), 0, 0)); // Highest priority for DMA0 interrupt
// DMA1_DMA17_IRQn
#if defined(FSL_FEATURE_SOC_DMAMUX_COUNT) && FSL_FEATURE_SOC_DMAMUX_COUNT
/* Init DMAMUX */
DMAMUX_Init(EXAMPLE_LPUART_DMAMUX_BASEADDR);
/* Set channel for LPUART */
DMAMUX_SetSource(EXAMPLE_LPUART_DMAMUX_BASEADDR, LPUART_TX_DMA_CHANNEL, LPUART_TX_DMA_REQUEST);
DMAMUX_SetSource(EXAMPLE_LPUART_DMAMUX_BASEADDR, LPUART_RX_DMA_CHANNEL, LPUART_RX_DMA_REQUEST);
DMAMUX_EnableChannel(EXAMPLE_LPUART_DMAMUX_BASEADDR, LPUART_TX_DMA_CHANNEL);
DMAMUX_EnableChannel(EXAMPLE_LPUART_DMAMUX_BASEADDR, LPUART_RX_DMA_CHANNEL);
#endif
/* Init the EDMA module */
EDMA_GetDefaultConfig(&userConfig);
#if defined(BOARD_GetEDMAConfig)
BOARD_GetEDMAConfig(userConfig);
#endif
EDMA_Init(EXAMPLE_LPUART_DMA_BASEADDR, &userConfig);
EDMA_CreateHandle(&g_lpuartTxEdmaHandle, EXAMPLE_LPUART_DMA_BASEADDR, LPUART_TX_DMA_CHANNEL);
EDMA_CreateHandle(&g_lpuartRxEdmaHandle, EXAMPLE_LPUART_DMA_BASEADDR, LPUART_RX_DMA_CHANNEL);
#if defined(FSL_FEATURE_EDMA_HAS_CHANNEL_MUX) && FSL_FEATURE_EDMA_HAS_CHANNEL_MUX
EDMA_SetChannelMux(EXAMPLE_LPUART_DMA_BASEADDR, LPUART_TX_DMA_CHANNEL, DEMO_LPUART_TX_EDMA_CHANNEL);
EDMA_SetChannelMux(EXAMPLE_LPUART_DMA_BASEADDR, LPUART_RX_DMA_CHANNEL, DEMO_LPUART_RX_EDMA_CHANNEL);
#endif
// Set DMA channel priorities
// EXAMPLE_LPUART_DMA_BASEADDR->DCHPRI[LPUART_TX_DMA_CHANNEL] = (EXAMPLE_LPUART_DMA_BASEADDR->DCHPRI[LPUART_TX_DMA_CHANNEL] & ~DMA_DCHPRI_CHPRI_MASK) | DMA_DCHPRI_CHPRI(15);
// EXAMPLE_LPUART_DMA_BASEADDR->DCHPRI[LPUART_RX_DMA_CHANNEL] = (EXAMPLE_LPUART_DMA_BASEADDR->DCHPRI[LPUART_RX_DMA_CHANNEL] & ~DMA_DCHPRI_CHPRI_MASK) | DMA_DCHPRI_CHPRI(15);
// EXAMPLE_LPUART_DMA_BASEADDR->DCHPRI0
/* Create LPUART DMA handle. */
LPUART_TransferCreateHandleEDMA(DEMO_LPUART, &g_lpuartEdmaHandle, LPUART_UserCallback, NULL, &g_lpuartTxEdmaHandle,
&g_lpuartRxEdmaHandle);
Im thinking to use this way .
%3CLINGO-SUB%20id%3D%22lingo-sub-1978233%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1978233%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI'm%20using%20uart3%20interrupt%20of%20RT1020%20%2Ci'm%20using%20uart3%20for%20rs-485%20communication%20and%20its%20speed%20is%203MBps.%3C%2FP%3E%3CP%3EAlso%2C%20I'm%20using%20LPSPI4%20CMSIS%20driver%20handler%20for%20other%20communication%20.%3C%2FP%3E%3CP%3EIndividually%20uart3%20works%20fine%20but%20after%20adding%20spi%20handler%20%2C%20it%20will%20start%20occurring%20Overrun.%3C%2FP%3E%3CP%3EStill%20im%20clearing%20overrun%20flag%20but%20why%20this%20flag%20is%20getting%20set%20.%3C%2FP%3E%3CP%3EAlso%20%2Cone%20query%20when%20this%20flag%20set%20%2Cin%20this%20case%20will%20i%20receive%20all%20data%20or%20lost%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Uart_status%20register.PNG%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Uart_status%20register.PNG%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F305887iEB71A9C5AA5CAF7A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Uart_status%20register.PNG%22%20alt%3D%22Uart_status%20register.PNG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3CP%3E%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1978233%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MXRT%20102x%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1999613%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1999613%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F226311%22%20target%3D%22_blank%22%3E%40hanmant%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20reply.%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EAccording%20to%20NXP's%20policy%2C%20I%20can%20not%20send%20you%20the%20source%20code%20directly%20.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EMy%20verification%20code%20is%20based%20on%20MIMXRT1020-EVK%20and%20MIMXER1064-EVK%20board%2C%20I%20do%20not%20think%20my%26nbsp%3Bverification%20code%20suitable%20for%20your%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3Ecustomized%20board.%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EAlso%2C%20I%20have%20sent%20you%20a%20screenshot%20of%20the%20critical%20code%20about%20your%20question.%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EI%20merge%20the%20following%20three%20project%20into%20my%26nbsp%3Bverification%20project.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EFor%20MIMXRT1020-EVK%20board%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E1%3A%20evkmimxrt1020_pit%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E2%3A%20evkmimxrt1020_lpi2c_edma_b2b_transfer_master%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E3%3Aevkmimxrt1020_lpuart_edma_transfer%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EFor%20MIMXRT1064-EVK%20board%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E1%3A%20evkmimxrt1064_lpi2c_edma_b2b_transfer_slave%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIf%20your%20I2C%20program%20still%20doesn't%20work%20properly%2C%20I%20suspect%20that%20there%20might%20be%20some%20issues%20with%20your%20I2C%20program.%20I%20suggest%20you%20disable%20other%20functions%20and%20test%20the%20I2C%20alone%20to%20see%20if%20it%20works%20normally.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EI%20think%20the%20current%20issue%20I%20have%20solved.%20Please%20tell%20me%20to%20close%20this%20case.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIf%20you%20still%20have%20problem%2C%20Please%20create%20a%20new%20case%2C%20thanks.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3Emayliu%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1998852%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1998852%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F140104%22%20target%3D%22_blank%22%3E%40mayliu%3C%2FA%3E%2C%3CBR%20%2F%3EThanks%20for%20your%20valuable%20suggest.%3CBR%20%2F%3ECan%20you%20please%20share%20your%20code%20with%20me.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1998819%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1998819%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F226311%22%20target%3D%22_blank%22%3E%40hanmant%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3EI%20use%20MIMXRT1020-EVK%20board%26nbsp%3B%20as%26nbsp%3Bedma_b2b_transfer_master%2C%20MIMXRT1064-EVK%20board%20as%26nbsp%3Bedma_b2b_transfer_slave.%26nbsp%3B%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_4-1732184845065.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_4-1732184845065.jpeg%22%20style%3D%22width%3A%20300px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311702i9BF7D2F128AEE4B0%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_4-1732184845065.jpeg%22%20alt%3D%22mayliu1_4-1732184845065.jpeg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EI%20create%20a%20project%20based%20on%26nbsp%3B%20MIMXRT1020-EVK%20board%2C%20I%20set%20this%20board%20as%20I2C%20master%2C%20add%20UART%20TX%2C%20UART%20RX%2C%20totally%20using%204%20DMA%20channels.%26nbsp%3B%20%26nbsp%3BI%20modify%20some%20code%26nbsp%3B%20both%20of%20MIMXRT1020-EVK%20project%26nbsp%3B%20and%26nbsp%3BMIMXRT1064-EVK%20project.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThe%20result%20is%20both%26nbsp%3Bprojects%20run%20Okay.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_5-1732184992668.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_5-1732184992668.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311703iBDDE299450FDBF42%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_5-1732184992668.png%22%20alt%3D%22mayliu1_5-1732184992668.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ESo%20please%20check%20your%20code%2C%20the%20critical%20code%20I%20have%20shown%20you%20bellow.%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_0-1732184067449.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_0-1732184067449.png%22%20style%3D%22width%3A%20348px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311698i0F09B52DB2483B9E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_0-1732184067449.png%22%20alt%3D%22mayliu1_0-1732184067449.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_1-1732184078401.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_1-1732184078401.png%22%20style%3D%22width%3A%20317px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311699iB4354ECF99235FBF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_1-1732184078401.png%22%20alt%3D%22mayliu1_1-1732184078401.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_2-1732184103892.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_2-1732184103892.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311700i5FDCEB4F48840336%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_2-1732184103892.png%22%20alt%3D%22mayliu1_2-1732184103892.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_3-1732184133614.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_3-1732184133614.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311701iB5DFFD8856354568%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_3-1732184133614.png%22%20alt%3D%22mayliu1_3-1732184133614.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EPlease%20try%20it%2C%20and%20tell%20me%20to%20close%20this%20case.%3C%2FP%3E%0A%3CP%3EIf%20you%20still%20have%20question%2C%20Please%20create%20a%20new%20case.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3Emayliu%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1997866%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1997866%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F140104%22%20target%3D%22_blank%22%3E%40mayliu%3C%2FA%3E%20%2C%3CBR%20%2F%3EThanks%20for%20reply.%3CBR%20%2F%3EI'm%20using%20bare%20matel%20not%20freeRTOS.%3CBR%20%2F%3EPlease%20bare%20board%20project%20and%20check.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1997860%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1997860%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F226311%22%20target%3D%22_blank%22%3E%40hanmant%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThanks%20for%20your%20reply%2C%20I%20will%20try%20do%20it%20on%20my%20side.%3C%2FP%3E%0A%3CP%3EPlease%20let%20me%20know%20if%20your%20project%20is%20using%20the%20FreeRTOS%20operating%20system%20or%20using%20a%20bare%20board.%20I%20will%20try%20to%20create%20a%20project%20as%20you%20do%20and%20validate%20%2C%20It%20is%20very%20import.%3C%2FP%3E%0A%3CP%3EPlease%20keep%20patience%2Cthanks.%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3Emayliu%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1997152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1997152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F140104%22%20target%3D%22_blank%22%3E%40mayliu%3C%2FA%3E%2C%3CBR%20%2F%3EThank%20for%20reply.%3CBR%20%2F%3ECan%20you%20simulate%20these%20things%20at%20your%20side%20by%20just%20adding%20Two%20DMA's%20one%20is%20UART%20and%20another%20is%20I2C%20and%20check%20priority%20get%20conflicts%20or%20not%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1997102%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1997102%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F226311%22%20target%3D%22_blank%22%3E%40hanmant%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThanks%20for%20the%20reply.%3C%2FP%3E%0A%3CP%3EIf%20you%20do%20not%20mind%2C%20Please%20create%20a%20new%20case%20because%20current%20case%20list%20too%20much%20item.%3C%2FP%3E%0A%3CP%3EIf%20you%20want%20your%20modules%20work%20well%20with%20DMA%2C%20especially%20some%20modules%20need%20to%20be%20processed%20in%20a%20timely%20manner%2C%20you%20should%20consider%20the%20prioritization%20of%20all%20DMA%20channels%20used.%3C%2FP%3E%0A%3CP%3EI%20do%20not%20know%20your%20project%20and%20DMA%20priority%20configuration.%20So%20please%20send%20me%20your%20code%20if%20it%20is%20convenient.%3C%2FP%3E%0A%3CP%3EIf%20not%26nbsp%3Bconvenient%2C%20I%20suggest%20you%20consider%20this%20two%20function%2C%20double%20check%20the%20parameters.%3C%2FP%3E%0A%3CDIV%3E%0A%3CDIV%3E%3CSPAN%3Evoid%20EDMA_SetChannelPreemptionConfig(DMA_Type%20*base%2C%20uint32_t%20channel%2C%20const%20edma_channel_Preemption_config_t%20*config)%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%0A%3CDIV%3E%0A%3CDIV%3E%3CSPAN%3ENVIC_SetPriority%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3CP%3EWish%20it%20helps%20you.%3CBR%20%2F%3EIf%20you%20still%20have%20question%20about%20it%2C%20please%20kindly%20let%20me%20know.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%26nbsp%3B%3C%2FP%3E%0A%3CP%3Emayliu%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1995949%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1995949%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F140104%22%20target%3D%22_blank%22%3E%40mayliu%3C%2FA%3E%2C%3CBR%20%2F%3EThank%20for%20reply.%3CBR%20%2F%3ECan%20please%20tell%20me%20how%20to%20resolve%20this%20issue.%3CBR%20%2F%3EStill%20I'm%20facing%20this%20DMA%20priority%20issue.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1995946%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1995946%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F226311%22%20target%3D%22_blank%22%3E%40hanmant%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThanks%20for%20your%20update.%3C%2FP%3E%0A%3CP%3EI%20rechecked%20your%20reply%2C%20I%20think%20you%20are%20right.%26nbsp%3B%3CSPAN%3EMost%20likely%2C%20it%20is%20because%20conflicting%20priority%20between%20I2C%20DMA%20and%20UART%20DMA.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EWish%20it%20helps%20you.%3CBR%20%2F%3EIf%20you%20still%20have%20question%20about%20it%2C%20please%20kindly%20let%20me%20know.%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EBest%20Regards%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3Emayliu%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1995207%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1995207%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F140104%22%20target%3D%22_blank%22%3E%40mayliu%3C%2FA%3E%2C%3CBR%20%2F%3EThank%20for%20update%2C%3CBR%20%2F%3EMy%20custom%20board%20RT1020%20is%20i2c%20master%20and%20it%20is%20connected%20with%20slave%20DAC%20and%20it%20is%20works%20fine.%3CBR%20%2F%3EBut%20my%20problem%20is%20when%20i'm%20tried%20to%20add%20the%20channel%20priority(EDMA_SetChannelPreemptionConfig)%20config%20code%20then%20the%20code%20will%20stuck%20into%20i2c%20dma.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1994503%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1994503%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F226311%22%20target%3D%22_blank%22%3E%40hanmant%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThanks%20for%20your%20update.%3C%2FP%3E%0A%3CP%3EThe%20reason%20of%20your%20Application%20got%20stuck%26nbsp%3B%20is%26nbsp%3Bthe%20I2C%20master%20node%20of%20your%20development%20board%20needs%20to%20be%20connected%20to%20the%20I2C%20slave%20node.%3C%2FP%3E%0A%3CP%3EI%20verified%20it%20with%20my%20development%20board%2C%20and%20if%20I%20don't%20connect%20to%20the%20I2C%20slave%20node%2C%20I%20get%20an%20error%26nbsp%3B%20as%20you.%20If%20I%20use%20two%26nbsp%3Bdevelopment%20board%2C%20one%20is%26nbsp%3B%22lpi2c_edma_b2b_transfer_master%22%2C%20the%20other%20is%20%22lpi2c_edma_b2b_transfer_slave%22.%20connect%20two%20boards%20correctly%2C%20the%20program%20run%20well.%26nbsp%3B%26nbsp%3B%3C%2FP%3E%0A%3CP%3EYou%20can%20create%20a%20%22lpi2c_edma_b2b_transfer_master%22%20project%20and%20don't%20add%20any%20other%20code%20to%20validate.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20Regards%3C%2FP%3E%0A%3CP%3Emayliu%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1993641%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1993641%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F140104%22%20target%3D%22_blank%22%3E%40mayliu%3C%2FA%3E%2C%3CBR%20%2F%3EThis%20is%20%22lpi2c_edma_b2b_transfer_master%22%20my%20whole%20project%20name%20under%20this%20name%20i%20have%20added%20all%20modules%20like%20uart%20dma%20%2Cspi%20and%20i2c%20dma%20etc.%3CBR%20%2F%3EWhen%20i%20removed%20priority%20related%20then%20application%20works%20fine%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1993626%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1993626%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F226311%22%20target%3D%22_blank%22%3E%40hanmant%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3EI%20do%20not%20think%20this%20problem%20related%20with%20current%20case%20subject%22%20UART3%20overrun%20error%20occurs%20RT1020%22.%3C%2FP%3E%0A%3CP%3EI%20import%20SDK%20demo%20as%20you%20do%2C%20I%20find%20that%20this%20demo%20%22lpi2c_edma_b2b_transfer_master%22%20need%26nbsp%3B%20%3CSPAN%3Elpi2c%20instance%20on%20the%20other%20board%20as%20slave.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_0-1731493594740.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_0-1731493594740.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F310265iB4BF0EBBF2DA109B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_0-1731493594740.png%22%20alt%3D%22mayliu1_0-1731493594740.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBecause%20of%20no%20I2C%20slave%2C%26nbsp%3B%26nbsp%3B%3CSPAN%3Elpi2c_master_callback%20can%20not%20be%20called%2C%20so%20you%20application%20got%20stuck.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_1-1731493614957.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_1-1731493614957.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F310266i8310637539CA2B17%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_1-1731493614957.png%22%20alt%3D%22mayliu1_1-1731493614957.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3Emayliu%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1993584%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1993584%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F239163%22%20target%3D%22_blank%22%3E%40mayliu1%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EThanks%20for%20update.%3C%2FP%3E%3CP%3Eit%20is%20getting%20stuck%20into%20I2c%20DMA.%3C%2FP%3E%3CP%3Ehere%20i%20have%20one%20question%20%3A%20Is%20it%20conflicting%20priority%20between%20I2C%20DMA%20and%20UART%20DMA%26nbsp%3B%3C%2FP%3E%3CP%3Ebut%20in%20I2C%20DMA%20i%20have%20not%20set%20the%20Priority.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1993419%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1993419%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F226311%22%20target%3D%22_blank%22%3E%40hanmant%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThanks%20for%20the%20update.%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%3Eyou%20said%20your%20whole%20application%20got%20stuck%20when%20you%20add%20the%20functions.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%20Can%20you%20tell%20me%20the%20detail%20information%20when%20your%20whole%20application%20got%20stuck.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E1%3A%20where%20your%26nbsp%3Bapplication%26nbsp%3Bgot%20stuck%2C%20Please%20tell%20me%20which%20function.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E2%3A%20when%20your%26nbsp%3Bapplication%26nbsp%3Bgot%20stuck%2C%20Please%20read%20your%20RT1020%20Registers%2C%20Faults%2C%20Peripherals%20status%2C%20check%20whether%20something%20unusual.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EThe%20following%20Fig%20is%20just%20a%20demo%20to%20help%20you%20check%20the%20problem.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_0-1731480630949.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_0-1731480630949.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F310206i6CBA1D26659339FE%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_0-1731480630949.png%22%20alt%3D%22mayliu1_0-1731480630949.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EWish%20it%20helps%20you!%3C%2FP%3E%0A%3CP%3EBest%20Regards%3C%2FP%3E%0A%3CP%3Emayliu%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1992573%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1992573%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F140104%22%20target%3D%22_blank%22%3E%40mayliu%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3EThis%20piece%20of%20code%20is%20not%20working%20%2Cmeans%20when%20i%20add%20this%20lines%20code%20in%20my%20code%20then%20whole%20application%20got%20stuck%3CBR%20%2F%3Econst%20edma_channel_Preemption_config_t%20Channel_preemption_config%20%3D%20%7B%3CBR%20%2F%3E.enableChannelPreemption%20%3D%20false%2C%3CBR%20%2F%3E.enablePreemptAbility%20%3D%20true%2C%3CBR%20%2F%3E.channelPriority%20%3D%2015U%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3Econst%20edma_channel_Preemption_config_t%20Channel14_preemption_config%20%3D%20%7B%3CBR%20%2F%3E.enableChannelPreemption%20%3D%20false%2C%3CBR%20%2F%3E.enablePreemptAbility%20%3D%20true%2C%3CBR%20%2F%3E.channelPriority%20%3D%2014U%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%3CBR%20%2F%3EEDMA_SetChannelPreemptionConfig(EXAMPLE_LPUART_DMA_BASEADDR%2CLPUART_TX_DMA_CHANNEL%2C%20%26amp%3BChannel_preemption_config)%3B%3CBR%20%2F%3EEDMA_SetChannelPreemptionConfig(EXAMPLE_LPUART_DMA_BASEADDR%2C%20LPUART_RX_DMA_CHANNEL%2C%20%26amp%3BChannel14_preemption_config)%3B%3CBR%20%2F%3E%3CBR%20%2F%3ENote%3A%20with%20this%20uart%20DMA%20there%20is%20another%20i2c%20DMA%20also%20there%20but%20i%20have%20not%20set%20priority%20of%20i2c%20DMA%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1986170%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1986170%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F226311%22%20target%3D%22_blank%22%3E%40hanmant%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EI%20wish%20you%20success%2C%20and%20also%20I%20have%20a%20little%20advice.%3C%2FP%3E%0A%3CP%3EIt%20is%20better%20put%26nbsp%3B%3CSPAN%3ENVIC_SetPriority%20function%20after%26nbsp%3BLPUART_TransferCreateHandleEDMA%20function.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EI'm%20waiting%20for%20your%20good%20news.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_0-1730453159868.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_0-1730453159868.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F308135i9D54C7CDA95B1647%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_0-1730453159868.png%22%20alt%3D%22mayliu1_0-1730453159868.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBest%20Regards%3C%2FP%3E%0A%3CP%3Emayliu%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1985286%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1985286%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F140104%22%20target%3D%22_blank%22%3E%40mayliu%3C%2FA%3E%2C%3CBR%20%2F%3EThank%20you%20for%20reply%3CBR%20%2F%3Elpuart_config_t%20lpuartConfig%3B%3CBR%20%2F%3E%3CBR%20%2F%3Elpuart_transfer_t%20sendXfer%3B%3CBR%20%2F%3Elpuart_transfer_t%20receiveXfer%3B%3CBR%20%2F%3Eedma_config_t%20userConfig%20%3D%20%7B0%7D%3B%3CBR%20%2F%3Euint32_t%20uiCnt%20%3D%200%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%2F*%20Initialize%20the%20LPUART.%20*%2F%3CBR%20%2F%3E%2F*%3CBR%20%2F%3E*%20lpuartConfig.baudRate_Bps%20%3D%20115200U%3B%3CBR%20%2F%3E*%20lpuartConfig.parityMode%20%3D%20kLPUART_ParityDisabled%3B%3CBR%20%2F%3E*%20lpuartConfig.stopBitCount%20%3D%20kLPUART_OneStopBit%3B%3CBR%20%2F%3E*%20lpuartConfig.txFifoWatermark%20%3D%200%3B%3CBR%20%2F%3E*%20lpuartConfig.rxFifoWatermark%20%3D%200%3B%3CBR%20%2F%3E*%20lpuartConfig.enableTx%20%3D%20false%3B%3CBR%20%2F%3E*%20lpuartConfig.enableRx%20%3D%20false%3B%3CBR%20%2F%3E*%2F%3CBR%20%2F%3ELPUART_GetDefaultConfig(%26amp%3BlpuartConfig)%3B%3CBR%20%2F%3ElpuartConfig.baudRate_Bps%20%3D%20UART3_BAUDRATE%3B%3CBR%20%2F%3ElpuartConfig.enableTx%20%3D%20true%3B%3CBR%20%2F%3ElpuartConfig.enableRx%20%3D%20true%3B%3CBR%20%2F%3E%3CBR%20%2F%3ELPUART_Init(DEMO_LPUART%2C%20%26amp%3BlpuartConfig%2C%20DEMO_LPUART_CLK_FREQ)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%2F%2F%20Set%20NVIC%20priority%20for%20the%20DMA%20interrupt%20to%20highest%20priority%3CBR%20%2F%3ENVIC_SetPriority(DMA0_DMA16_IRQn%2C%20NVIC_EncodePriority(NVIC_GetPriorityGrouping()%2C%200%2C%200))%3B%20%2F%2F%20Highest%20priority%20for%20DMA0%20interrupt%3CBR%20%2F%3E%2F%2F%20DMA1_DMA17_IRQn%3CBR%20%2F%3E%3CBR%20%2F%3E%23if%20defined(FSL_FEATURE_SOC_DMAMUX_COUNT)%20%26amp%3B%26amp%3B%20FSL_FEATURE_SOC_DMAMUX_COUNT%3CBR%20%2F%3E%2F*%20Init%20DMAMUX%20*%2F%3CBR%20%2F%3EDMAMUX_Init(EXAMPLE_LPUART_DMAMUX_BASEADDR)%3B%3CBR%20%2F%3E%2F*%20Set%20channel%20for%20LPUART%20*%2F%3CBR%20%2F%3EDMAMUX_SetSource(EXAMPLE_LPUART_DMAMUX_BASEADDR%2C%20LPUART_TX_DMA_CHANNEL%2C%20LPUART_TX_DMA_REQUEST)%3B%3CBR%20%2F%3EDMAMUX_SetSource(EXAMPLE_LPUART_DMAMUX_BASEADDR%2C%20LPUART_RX_DMA_CHANNEL%2C%20LPUART_RX_DMA_REQUEST)%3B%3CBR%20%2F%3EDMAMUX_EnableChannel(EXAMPLE_LPUART_DMAMUX_BASEADDR%2C%20LPUART_TX_DMA_CHANNEL)%3B%3CBR%20%2F%3EDMAMUX_EnableChannel(EXAMPLE_LPUART_DMAMUX_BASEADDR%2C%20LPUART_RX_DMA_CHANNEL)%3B%3CBR%20%2F%3E%23endif%3CBR%20%2F%3E%2F*%20Init%20the%20EDMA%20module%20*%2F%3CBR%20%2F%3EEDMA_GetDefaultConfig(%26amp%3BuserConfig)%3B%3CBR%20%2F%3E%23if%20defined(BOARD_GetEDMAConfig)%3CBR%20%2F%3EBOARD_GetEDMAConfig(userConfig)%3B%3CBR%20%2F%3E%23endif%3CBR%20%2F%3EEDMA_Init(EXAMPLE_LPUART_DMA_BASEADDR%2C%20%26amp%3BuserConfig)%3B%3CBR%20%2F%3EEDMA_CreateHandle(%26amp%3Bg_lpuartTxEdmaHandle%2C%20EXAMPLE_LPUART_DMA_BASEADDR%2C%20LPUART_TX_DMA_CHANNEL)%3B%3CBR%20%2F%3EEDMA_CreateHandle(%26amp%3Bg_lpuartRxEdmaHandle%2C%20EXAMPLE_LPUART_DMA_BASEADDR%2C%20LPUART_RX_DMA_CHANNEL)%3B%3CBR%20%2F%3E%23if%20defined(FSL_FEATURE_EDMA_HAS_CHANNEL_MUX)%20%26amp%3B%26amp%3B%20FSL_FEATURE_EDMA_HAS_CHANNEL_MUX%3CBR%20%2F%3EEDMA_SetChannelMux(EXAMPLE_LPUART_DMA_BASEADDR%2C%20LPUART_TX_DMA_CHANNEL%2C%20DEMO_LPUART_TX_EDMA_CHANNEL)%3B%3CBR%20%2F%3EEDMA_SetChannelMux(EXAMPLE_LPUART_DMA_BASEADDR%2C%20LPUART_RX_DMA_CHANNEL%2C%20DEMO_LPUART_RX_EDMA_CHANNEL)%3B%3CBR%20%2F%3E%23endif%3CBR%20%2F%3E%2F%2F%20Set%20DMA%20channel%20priorities%3CBR%20%2F%3E%2F%2F%20EXAMPLE_LPUART_DMA_BASEADDR-%26gt%3BDCHPRI%5BLPUART_TX_DMA_CHANNEL%5D%20%3D%20(EXAMPLE_LPUART_DMA_BASEADDR-%26gt%3BDCHPRI%5BLPUART_TX_DMA_CHANNEL%5D%20%26amp%3B%20~DMA_DCHPRI_CHPRI_MASK)%20%7C%20DMA_DCHPRI_CHPRI(15)%3B%3CBR%20%2F%3E%2F%2F%20EXAMPLE_LPUART_DMA_BASEADDR-%26gt%3BDCHPRI%5BLPUART_RX_DMA_CHANNEL%5D%20%3D%20(EXAMPLE_LPUART_DMA_BASEADDR-%26gt%3BDCHPRI%5BLPUART_RX_DMA_CHANNEL%5D%20%26amp%3B%20~DMA_DCHPRI_CHPRI_MASK)%20%7C%20DMA_DCHPRI_CHPRI(15)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%2F%2F%20EXAMPLE_LPUART_DMA_BASEADDR-%26gt%3BDCHPRI0%3CBR%20%2F%3Econst%20edma_channel_Preemption_config_t%20Channel_preemption_config%20%3D%20%7B%3CBR%20%2F%3E.enableChannelPreemption%20%3D%20false%2C%3CBR%20%2F%3E.enablePreemptAbility%20%3D%20true%2C%3CBR%20%2F%3E.channelPriority%20%3D%2014U%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3Econst%20edma_channel_Preemption_config_t%20Channel14_preemption_config%20%3D%20%7B%3CBR%20%2F%3E.enableChannelPreemption%20%3D%20false%2C%3CBR%20%2F%3E.enablePreemptAbility%20%3D%20true%2C%3CBR%20%2F%3E.channelPriority%20%3D%2015U%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%3CBR%20%2F%3EEDMA_SetChannelPreemptionConfig(EXAMPLE_LPUART_DMA_BASEADDR%2CLPUART_TX_DMA_CHANNEL%2C%20%26amp%3BChannel_preemption_config)%3B%3CBR%20%2F%3EEDMA_SetChannelPreemptionConfig(EXAMPLE_LPUART_DMA_BASEADDR%2C%20LPUART_RX_DMA_CHANNEL%2C%20%26amp%3BChannel14_preemption_config)%3B%3CBR%20%2F%3E%2F*%20Create%20LPUART%20DMA%20handle.%20*%2F%3CBR%20%2F%3ELPUART_TransferCreateHandleEDMA(DEMO_LPUART%2C%20%26amp%3Bg_lpuartEdmaHandle%2C%20LPUART_UserCallback%2C%20NULL%2C%20%26amp%3Bg_lpuartTxEdmaHandle%2C%3CBR%20%2F%3E%26amp%3Bg_lpuartRxEdmaHandle)%3B%3CBR%20%2F%3EIm%20thinking%20to%20use%20this%20way%20.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1985264%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1985264%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F226311%22%20target%3D%22_blank%22%3E%40hanmant%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EPlease%20review%20the%20differences%20between%20the%20following%20definitions%20and%20use%20them%20according%20to%20your%20needs.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EEDMA_SetChannelPreemptionConfig%3A%20It%20is%20primarily%20used%20to%20configure%20the%20preemption%20priority%20of%20DMA%20channels%2C%20ensuring%20the%20most%20important%20task%20can%20be%20processed%20first%2C%20when%20multiple%20DMA%20tasks%20happened%20at%20the%20same%20time.%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3ENVIC_SetPriority%3A%26nbsp%3B%20It%20is%20used%20to%20set%20the%20priority%20of%20interrupts%2C%20ensuring%20that%20high-priority%20interrupts%20can%20be%20responded%20to%20and%20processed%20by%20the%20CPU%20first%20when%20multiple%20interrupts%20happened%20at%20the%20same%20time.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EBest%20Regards%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3Emayliu%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1985258%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1985258%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F140104%22%20target%3D%22_blank%22%3E%40mayliu%3C%2FA%3E%2C%3CBR%20%2F%3EI'm%20thinking%20add%20this%20way%2C%3CBR%20%2F%3Econst%20edma_channel_Preemption_config_t%20Channel_preemption_config%20%3D%20%7B%3CBR%20%2F%3E.enableChannelPreemption%20%3D%20false%2C%3CBR%20%2F%3E.enablePreemptAbility%20%3D%20true%2C%3CBR%20%2F%3E.channelPriority%20%3D%2014U%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3Econst%20edma_channel_Preemption_config_t%20Channel14_preemption_config%20%3D%20%7B%3CBR%20%2F%3E.enableChannelPreemption%20%3D%20false%2C%3CBR%20%2F%3E.enablePreemptAbility%20%3D%20true%2C%3CBR%20%2F%3E.channelPriority%20%3D%2015U%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%3CBR%20%2F%3EEDMA_SetChannelPreemptionConfig(EXAMPLE_LPUART_DMA_BASEADDR%2CLPUART_TX_DMA_CHANNEL%2C%20%26amp%3BChannel_preemption_config)%3B%3CBR%20%2F%3EEDMA_SetChannelPreemptionConfig(EXAMPLE_LPUART_DMA_BASEADDR%2C%20LPUART_RX_DMA_CHANNEL%2C%20%26amp%3BChannel14_preemption_config)%3B%3CBR%20%2F%3Eis%20it%20correct%20or%20not.%3CBR%20%2F%3Eplease%20confirm%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1985214%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1985214%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F226311%22%20target%3D%22_blank%22%3E%40hanmant%3C%2FA%3E%26nbsp%3B%EF%BC%8C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThank%20you%20for%20your%20updated%20information.%3C%2FP%3E%0A%3CP%3EI%20suggest%20you%20can%20use%26nbsp%3B%3CSPAN%3ENVIC_SetPriority(IRQn_Type%20IRQn%2C%20uint32_t%20priority)function.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E1%3A%20The%20first%20parameter%20is%26nbsp%3BIRQn_Type%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIt%20depends%20on%20your%20design%2C%20if%20UART3%20using%20DMA%20channel%200(%23define%20LPUART_TX_DMA_CHANNEL%200U)%2C%20then%20the%20first%20parameter%20is%26nbsp%3BDMA0_DMA16_IRQn.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E2%3AThe%20second%20parameter%20is%26nbsp%3Bpriority%2C%20The%20lower%20value%2C%20the%20greater%20the%20priority%26nbsp%3B%20of%20the%20corresponding%20interrupt.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EBest%20Regards%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3Emayliu%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1984465%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1984465%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F140104%22%20target%3D%22_blank%22%3E%40mayliu%3C%2FA%3E%2C%3CBR%20%2F%3E%3CBR%20%2F%3ECan%20you%20please%20tell%20me%20how%20to%20set%20Highest%20the%20Priority%20to%20DMA%20controller%20over%20CPU.%3CBR%20%2F%3EAlso%20in%20DMA%20i%20want%20set%20the%20highest%20priority%20to%20UART%20receive%20and%20TX%20than%20SPI.%3CBR%20%2F%3EPlease%20tell%20me%20the%20process%20and%20API's%20or%20any%20examples.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1980085%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1980085%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F226311%22%20target%3D%22_blank%22%3E%40hanmant%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EJust%20add%20a%20delay%20function%2C%20I%20have%20shown%20to%20you.%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%3ESDK_DelayAtLeastUs(100000%2C%20CLOCK_GetFreq(kCLOCK_CpuClk))%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E1%EF%BC%9AIn%20addition%2C%20I%20suggest%20you%20check%20whether%20the%20data%20format%20for%20UART%20sending%20and%20receiving%20is%20consistent.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E2%EF%BC%9APlease%20confirm%20whether%20your%20NXP%20development%20board%20and%20TI%20development%20board%20share%20a%20common%20ground.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E3%EF%BC%9APlease%20confirm%20whether%20the%20connection%20between%20UART%20transmission%20and%20reception%20is%20secure.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EBR%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3Emayliu%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1980074%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1980074%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EThanks%20for%20reply.%3CBR%20%2F%3ECan%20you%20please%20share%20your%20source%20code%20files.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1979931%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1979931%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F226311%22%20target%3D%22_blank%22%3E%40hanmant%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EI%20think%20I%20know%20the%20reason%20of%20the%20problem.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EContinuous%20data%20transmission%20in%20your%20program%20can%20cause%20Ti%20board%20UART%20receiver%20overrun%2C%20resulting%20in%20abnormal%20data%20transfer.%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EI%20suggest%20adding%20a%20delay%20after%20sending%2052%20bytes%20UART%20data%2C%20Please%20try%20it.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EI%20have%20tested%20and%20verified%20this%20100%20times%20on%20my%20end%2C%20and%20the%20data%20sending%20and%20receiving%20are%20consistent.%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_1-1729667293341.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_1-1729667293341.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F306343i649163166E35E407%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_1-1729667293341.png%22%20alt%3D%22mayliu1_1-1729667293341.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EWish%20it%20helps%20you.%3CBR%20%2F%3EIf%20you%20still%20have%20question%20about%20it%2C%20please%20kindly%20let%20me%20know.%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1979857%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1979857%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F239163%22%20target%3D%22_blank%22%3E%40mayliu1%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3EThanks%20for%20reply.%3CBR%20%2F%3EAs%20of%20now%20im%20not%20using%20uart%20receiver%20.%3CBR%20%2F%3Ewhatever%20i%20shared%20with%20is%20only%20uart%20transmit%20only%20(size%2052%20buffer)but%20i%20dont%20receive%20correct%20data%20on%20my%20Ti%20board%20using%20dma.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1979852%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1979852%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F226311%22%20target%3D%22_blank%22%3E%40hanmant%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThank%20you%20for%20your%20updated%20information.%3C%2FP%3E%0A%3CP%3EAs%20you%20said%2C%20if%20you%20only%20send%20UART%20data%2C%20why%20you%20ask%20me%20UART%20overrun%20error%20happened.%3C%2FP%3E%0A%3CP%3EUART%20overrun%20error%20is%20related%20with%20UART%20receive.%3C%2FP%3E%0A%3CP%3Eand%20if%20you%20want%20to%20send%20UART%20data%2C%20It%20is%20very%20simple%2C%20just%20call%26nbsp%3B%3CSPAN%3ELPUART_SendEDMA.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_0-1729663958271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_0-1729663958271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F306321i25071C6AC0D8CBDB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_0-1729663958271.png%22%20alt%3D%22mayliu1_0-1729663958271.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3Emayliu%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1979842%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1979842%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EThanks%20for%20reply.%3CBR%20%2F%3EIn%20this%20project%20i%20only%20send%20the%20data%20using%20DMA%20uart%20.%3CBR%20%2F%3ESo%20the%20my%20receiver%20is%20Ti%20processor%20device.%3CBR%20%2F%3EI%20think%20priority%20does%20not%20matter%20in%20this%20example%20because%20here%20only%20DMA%20Uart%20is%20running.%3CBR%20%2F%3EI%20have%20tried%20to%20send%202%20bytes%20of%20data%20but%20still%20same%20issue%20.%3CBR%20%2F%3EGive%20me%20solid%20solution%20to%20work%20this%20because%20this%20simple%20uart%20DMA%20transmission%20.%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1979752%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1979752%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22lia-align-justify%22%20style%3D%22text-align%20%3A%20justify%3B%22%20style%3D%22text-align%20%3A%20justify%3B%22%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F226311%22%20target%3D%22_blank%22%3E%40hanmant%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-justify%22%20style%3D%22text-align%20%3A%20justify%3B%22%20style%3D%22text-align%20%3A%20justify%3B%22%3EThank%20you%20for%20your%20updated%20information.%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-justify%22%20style%3D%22text-align%20%3A%20justify%3B%22%20style%3D%22text-align%20%3A%20justify%3B%22%3E%3CSPAN%3ECan%20you%20tell%20me%20when%20and%20where%20you%20call%20the%20DMA%20UART%20receive%20function%20interface%3F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-justify%22%20style%3D%22text-align%20%3A%20justify%3B%22%20style%3D%22text-align%20%3A%20justify%3B%22%3E%3CSPAN%3E%22In%20the%20source%20files(lpuart_edma_transfer.c)%20you%20sent%2C%20I%20didn't%20see%20any%20calls%20to%20the%20DMA%20UART%20data%20receive%20interface.%22%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-justify%22%20style%3D%22text-align%20%3A%20justify%3B%22%20style%3D%22text-align%20%3A%20justify%3B%22%3E%3CSPAN%3EPlease%20try%20to%20verify%20it%20according%20to%20the%20steps%20shown%20below.%3C%2FSPAN%3E%3CBR%20%2F%3E1%3A%20Set%20the%20DMA_UART%20interrupt%20priority%20to%20be%20higher%20than%20other%20modules.%3CBR%20%2F%3E2%3A%20Use%20ping%20pong%20buffer%20to%20receive%20UART%20data.%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-justify%22%20style%3D%22text-align%20%3A%20justify%3B%22%20style%3D%22text-align%20%3A%20justify%3B%22%3EWish%20it%20helps%20you.%3CBR%20%2F%3EIf%20you%20still%20have%20question%20about%20it%2C%20please%20kindly%20let%20me%20know.%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-justify%22%20style%3D%22text-align%20%3A%20justify%3B%22%20style%3D%22text-align%20%3A%20justify%3B%22%3EBest%20Regards%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-justify%22%20style%3D%22text-align%20%3A%20justify%3B%22%20style%3D%22text-align%20%3A%20justify%3B%22%3Emayliu%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1979230%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1979230%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F239163%22%20target%3D%22_blank%22%3E%40mayliu1%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3EAs%20per%20your%20suggestion%20i%20configured%20uart%20in%20DMA%20but%20still%20see%20the%20losses.%3C%2FP%3E%3CP%3EI%20can%20see%20clear%20losses%20at%20receiver%20side(my%20receiver%20is%20another%20device%20comport).%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1979108%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1979108%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F226311%22%20target%3D%22_blank%22%3E%40hanmant%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EI%20highly%20recommend%20you%20using%20the%20DMA%20UART%20%2C%20especially%20when%20UART%20baud%20rate%20is%20particularly%20high.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3Emayliu%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1979103%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1979103%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESo%20%2C%20I%20have%20to%20implement%20DMA%20uart%20then%3F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1979090%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1979090%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F226311%22%20target%3D%22_blank%22%3E%40hanmant%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EQuestion%3A%20This%20overrun%20problem%20is%20coming%20after%20inclusion%20of%20spi%20cmsis%20handler.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EAnswer%3A%20Due%20to%20the%20addition%20of%20spi%20cmsis%20handler%2C%20the%20entry%20of%20UART%20interrupt%20will%20be%20delayed%20and%20the%20UART%20data%20cannot%20be%20received%20in%20time.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3Emayliu%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1979076%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1979076%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EThanks%20for%20reply%20.%3CBR%20%2F%3EThis%20overrun%20problem%20is%20coming%20after%20inclusion%20of%20spi%20cmsis%20handler.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1979065%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1979065%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F226311%22%20target%3D%22_blank%22%3E%40hanmant%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20update%20information.%3C%2FP%3E%0A%3CP%3EIf%20you%20use%20UART%20interrupt%20to%20send%20and%20receive%20UART%20data%2C%20every%20UART%20byte%20will%20trigger%20a%20UART%20interrupt.%3C%2FP%3E%0A%3CP%3EYour%20UART%20baud%20rate%20is%20very%20high(%3CSPAN%3E3MBps%3C%2FSPAN%3E)%20and%20will%20cause%20frequent%20entry%20UART%20interrupt%2C%20which%20is%20unreasonable.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI%20don't%20recommend%20you%20to%20use%20the%20UART%20interrupt%20when%20the%20UART%20baud%20rate%20is%20so%20high.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20Regards%3C%2FP%3E%0A%3CP%3Emayliu%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1979043%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1979043%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F239163%22%20target%3D%22_blank%22%3E%40mayliu1%3C%2FA%3E%20%2C%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3EPlease%20Note%20Currently%20im%20not%20using%20DMA%20uart.%20I'm%20using%20uart%20interrupt.%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1979022%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1979022%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F239163%22%20target%3D%22_blank%22%3E%40mayliu1%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3EThanks%20for%20reply.%3C%2FP%3E%3CP%3ECurrently%20im%20using%20DMA%20uart.%20I'm%20using%20uart%20interrupt.%3C%2FP%3E%3CP%3EPlease%20see%20below%20code%20snippet.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1978958%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20overrun%20error%20occurs%20RT1020%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1978958%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F226311%22%20target%3D%22_blank%22%3E%40hanmant%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-justify%22%20style%3D%22text-align%20%3A%20justify%3B%22%20style%3D%22text-align%20%3A%20justify%3B%22%3EThank%20you%20so%20much%20for%20your%20interest%20in%20our%20products%20and%20for%20using%20our%20community.%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-justify%22%20style%3D%22text-align%20%3A%20justify%3B%22%20style%3D%22text-align%20%3A%20justify%3B%22%3EUsually%2C%20there%20are%20various%20causes%20of%20UART%20overrun%20errors%2C%20and%20it%20is%20necessary%20to%20consider%20various%20aspects%20such%20as%20data%20processing%20speed%20and%20interrupt%20processing.%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-justify%22%20style%3D%22text-align%20%3A%20justify%3B%22%20style%3D%22text-align%20%3A%20justify%3B%22%3E%3CBR%20%2F%3EIn%20order%20to%20better%20help%20you%20solve%20the%20problem%2C%20please%20reply%20to%20the%20question%20below.%3CBR%20%2F%3EFirst%2C%20Please%20tell%20me%20which%20DMA_UART%20interface%20function%20you%20call%20to%20receive%20UART%20data%20%3CBR%20%2F%3ESecond%2C%20Please%20tell%20me%20where%20and%20when%20you%20call%20DMA_UART%20interface%20function.%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-justify%22%20style%3D%22text-align%20%3A%20justify%3B%22%20style%3D%22text-align%20%3A%20justify%3B%22%3EI%20have%20a%20few%20suggestions%20for%20you.%3CBR%20%2F%3E1%3A%20Set%20the%20DMA_UART%20interrupt%20priority%20to%20be%20higher%20than%20other%20modules.%3CBR%20%2F%3E2%3A%20Use%20ping%20pong%20buffer%20to%20receive%20UART%20data.%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-justify%22%20style%3D%22text-align%20%3A%20justify%3B%22%20style%3D%22text-align%20%3A%20justify%3B%22%3EWish%20it%20helps%20you.%3CBR%20%2F%3EIf%20you%20still%20have%20question%20about%20it%2C%20please%20kindly%20let%20me%20know.%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-justify%22%20style%3D%22text-align%20%3A%20justify%3B%22%20style%3D%22text-align%20%3A%20justify%3B%22%3EWish%20you%20a%20nice%20day!%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-justify%22%20style%3D%22text-align%20%3A%20justify%3B%22%20style%3D%22text-align%20%3A%20justify%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-justify%22%20style%3D%22text-align%20%3A%20justify%3B%22%20style%3D%22text-align%20%3A%20justify%3B%22%3EBest%20Regards%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-justify%22%20style%3D%22text-align%20%3A%20justify%3B%22%20style%3D%22text-align%20%3A%20justify%3B%22%3Emayliu%3C%2FP%3E%3C%2FLINGO-BODY%3E
