Solved! Go to Solution.
Hello!
Please see my answers below.
1. No, those are the available clock sources.
2. I tested 2 Mbps with my board and it worked correctly, I used lpuart_interrupt example and TeraTerm. Please check it below.
Felipe
- We are following threads for 7 weeks after the last post, later replies are ignored. Please open a new thread and refer to the closed one, if you have a related question at a later point in time.
Hello!
Felipe
5Mbps communication working or not?
You should also take into consideration LPC-Link and windows FTDI driver limitations. I recommend you to measure UART signals directly using oscilloscope or logic analyze.
Felipe
Yeah, I tested in between two UARTS, its working
Okay, Thank you....
I installed Tera Term Software, but maximum baudrate for serial port was 921600, How did you get 2000000 baudarte
You can manually write it even though there is no 2 Mbps option.
Felipe
Thanks for sharing knowledge
