The test data for P2020 Ethernet forwarding performance
1,056 次查看
wqking1000
1.Where are you about performance test data for p2020 Ethernet forwarding? And corresponding methods and test tools?
2.Where are you about performance test data for p2020 Ethernet Nat Firewall forwarding? And corresponding methods and test tools?
3.Where are you about performance test data for p2020 Ethernet ipsec ? And corresponding methods and test tools?
标记 (2)
1,027 次查看
yipingwang
Hello 琦 王,
Please refer to the following test data, the test tool is Spirent TestCenter.
1. IPv4 fwd 2 cores 2G
FrameSize(Bytes)  Throughputs(Mbps)
64               400
128              700.63
256              1286.5
390              1901.39
512              2000.0
1024             2000.0
1280             2000.0
1518             2000.0
2.Ipv4 Nat firewall 2 core 1 flow
FrameSize(Bytes)       Throughput(Mbps)
66                                95.08
128                             163.72
256                             304.87
512                             584.28
1024                          999.03
1280                          999.03
1518                          999.03
3. IPv4 SEC 3DES_SHA1 2core 2G
FrameSize(Bytes)    Througput(Mbps)
82                 112.81
408                385.45
1442               1282.64
IPv4 SEC AES_SHA1 2core 2G
82                 112.81
408                387.38
1442               1286.5
Yiping
