Secondary boot for XIP-Flash
calvin1
I would like to enable the Secondary boot functionality of iMXRT1010EVK, after writes '1' to the PERSIST_SECONDARY_BOOT bit of SRC_GPR10 register then make a reset,  it seems not working..
I supposed that the secondary boot image is not placed at the right place as I placed it at the default redundant boot image address 0x60040000, I have no idea if it can work as I also saw a setting of XSPI_FLASH_SEC_IMG_OF
FSET that needs to be filled.
My question is where I should place the secondary boot image? and are there any register I should set to indicate BootROM to jump? What are necessary steps I should do to boot from Secondary Boot Image?
jeremyzhou
Hi Calvin Lin,
Thanks for your reply.
I've confirmed that the Flash Remapping Setting feature is only supported by the RT106x, in another word, the RT1010 doesn't support the feature that jumps to the second image.
I've also attached an application note which illustrates the Flash Remapping Setting feature.
Have a great day.
TIC
calvin1
Hi Jeremy,
My evaluation kit is iMXRT1010EVK, in my test, I imported two MCUxpresso projects( "iled_blinky" and "hello world") from SDK, then completes the procedures listed below:
1. Compile the "hello world" project first for generating the binary image;
2. Using NXP-MCUBootUtility tool to program the binary image at address 0x60040000;
3. Add codes to "iled_blinky" for writing '1' to the PERSIST_SECONDARY_BOOT bit of SRC_GPR10 register;
4. Download the project "iled_blinky" through MCUxpresso with LPC-Link2;
5. Erasing the XIP-Flash address from 0x60000000 to 0x6003FFFF;
6. Press POR button on EVK board.
I supposed that as there is no bootable image on address 0x60000000, so BootROM should redirect boot address to 0x60040000 to run the secondary image, but it didn't.
As I couldn't find the way writing XSPI_FLASH_SEC_IMG_OFFSET register, so please explain the procedures what I missed.
thank you.
jeremyzhou
Hi Calvin Lin,
Have a great day.
TIC
olex
Then it makes sense to make corrections to the documentation to reduce the pain for subsequent engineers:)
RT1010 Processor Reference Manual, Rev. 0, 09/2019 (the last avaible for now):
- Chapter 9.6.4 Redundant boot image support
- Chapter 9.10.2 Enter Bootloader API, Boot image selection field.
- Chapter 21.8.14 SRC General Purpose Register 10, PERSIST_SECONDARY_BOOT and PERSIST_REDUNDANT_BOOT fields.
jeremyzhou
Hi Calvin Lin,
for the opportunity to serve you.
I'd like to know more information about the phenomenon, so whether you can introduce the process of secondary boot testing you did, and it may help me to figure it out.
Looking forward to your reply.
Have a great day.
TIC
%3CLINGO-SUB%20id%3D%22lingo-sub-988044%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESecondary%20boot%20for%20XIP-Flash%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-988044%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3EI%20would%20like%20to%20enable%20the%20Secondary%20boot%20functionality%20of%20iMXRT1010EVK%2C%20after%20writes%20'1'%20to%20the%20PERSIST_SECONDARY_BOOT%20bit%20of%26nbsp%3BSRC_GPR10%20register%20then%20make%20a%20reset%2C%26nbsp%3B%20it%20seems%20not%20working..%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3EI%20supposed%20that%20the%20secondary%20boot%20image%20is%20not%20placed%20at%20the%20right%20place%20as%20I%20placed%20it%20at%20the%20default%20redundant%20boot%20image%20address%200x60040000%2C%20I%20have%20no%20idea%20if%20it%20can%20work%20as%20I%20also%20saw%20a%20setting%20of%26nbsp%3BXSPI_FLASH_SEC_IMG_OF%3CBR%20%2F%3EFSET%20that%20needs%20to%20be%20filled.%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3EMy%20question%20is%20where%20I%20should%20place%20the%20secondary%20boot%20image%3F%20and%20are%20there%20any%20register%20I%20should%20set%20to%20indicate%20BootROM%20to%20jump%3F%20What%20are%20necessary%20steps%20I%20should%20do%20to%20boot%20from%20Secondary%20Boot%20Image%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-988044%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MXRT%20101x%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2175084%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Secondary%20boot%20for%20XIP-Flash%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2175084%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EThen%20it%20makes%20sense%20to%20make%20corrections%20to%20the%20documentation%20to%20reduce%20the%20pain%20for%20subsequent%20engineers%3A)%3C%2FP%3E%3CP%3ERT1010%20Processor%20Reference%20Manual%2C%20Rev.%200%2C%2009%2F2019%20(the%20last%20avaible%20for%20now)%3A%3C%2FP%3E%3CP%3E-%20Chapter%209.6.4%20Redundant%20boot%20image%20support%3C%2FP%3E%3CP%3E-%20Chapter%209.10.2%20Enter%20Bootloader%20API%2C%20Boot%20image%20selection%20field.%3C%2FP%3E%3CP%3E-%20Chapter%2021.8.14%20SRC%20General%20Purpose%20Register%2010%2C%20PERSIST_SECONDARY_BOOT%20and%20PERSIST_REDUNDANT_BOOT%20fields.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-988047%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Secondary%20boot%20for%20XIP-Flash%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-988047%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20data-userid%3D%22339607%22%20data-username%3D%22calvin%40picotest.com.tw%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fcalvin%40picotest.com.tw%22%20target%3D%22_blank%22%3ECalvin%20Lin%3C%2FA%3E%2C%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3EThanks%20for%20your%20reply.%3CBR%20%2F%3EI've%20confirmed%20that%20the%20Flash%20Remapping%20Setting%20feature%20is%20only%20supported%20by%20the%20RT106x%2C%20in%20another%20word%2C%20the%20RT1010%20doesn't%20support%20the%20feature%20that%20jumps%20to%20the%20second%20image.%3CBR%20%2F%3EI've%20also%20attached%20an%20application%20note%20which%20illustrates%20the%20Flash%20Remapping%20Setting%20feature.%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3EHave%20a%20great%20day.%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3ETIC%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E-------------------------------------------------------------------------------%3CBR%20%2F%3ENote%3A%3CBR%20%2F%3E-%20If%20this%20post%20answers%20your%20question%2C%20please%20click%20the%20%22Mark%20Correct%22%20button.%20Thank%20you!%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E-%20We%20are%20following%20threads%20for%207%20weeks%20after%20the%20last%20post%2C%20later%20replies%20are%20ignored%3CBR%20%2F%3E%20Please%20open%20a%20new%20thread%20and%20refer%20to%20the%20closed%20one%2C%20if%20you%20have%20a%20related%20question%20at%20a%20later%20point%20in%20time.%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-988046%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Secondary%20boot%20for%20XIP-Flash%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-988046%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Jeremy%2C%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3EMy%20evaluation%20kit%20is%20iMXRT1010EVK%2C%20in%20my%20test%2C%20I%20imported%20two%20MCUxpresso%20projects(%20%22iled_blinky%22%20and%20%22hello%20world%22)%20from%20SDK%2C%20then%26nbsp%3Bcompletes%20the%20procedures%20listed%20below%3A%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E1.%20Compile%20the%20%22hello%20world%22%20project%20first%20for%20generating%20the%20binary%20image%3B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E2.%20Using%26nbsp%3BNXP-MCUBootUtility%26nbsp%3Btool%20to%20program%20the%20binary%20image%20at%20address%200x60040000%3B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E3.%20Add%20codes%20to%20%22iled_blinky%22%20for%20writing%20'1'%20to%20the%26nbsp%3B%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EPERSIST_SECONDARY_BOOT%20bit%20of%26nbsp%3BSRC_GPR10%20register%3B%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E4.%20Download%26nbsp%3Bthe%20project%20%22iled_blinky%22%20through%20MCUxpresso%20with%20LPC-Link2%3B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E5.%20Erasing%20the%20XIP-Flash%20address%20from%200x60000000%20to%200x6003FFFF%3B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E6.%20Press%20POR%20button%20on%20EVK%20board.%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3EI%20supposed%20that%26nbsp%3Bas%20there%20is%20no%20bootable%20image%20on%20address%200x60000000%2C%20so%20BootROM%20should%20redirect%20boot%20address%20to%200x60040000%20to%20run%20the%20secondary%20image%2C%20but%20it%20didn't.%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3EAs%20I%20couldn't%20find%20the%20way%20writing%26nbsp%3B%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EXSPI_FLASH_SEC_IMG_OF%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EFSET%20register%2C%26nbsp%3Bso%20please%20explain%20the%20procedures%20what%20I%20missed.%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3Ethank%20you.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-988045%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Secondary%20boot%20for%20XIP-Flash%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-988045%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20data-userid%3D%22339607%22%20data-username%3D%22calvin%40picotest.com.tw%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fcalvin%40picotest.com.tw%22%20target%3D%22_blank%22%3ECalvin%20Lin%3C%2FA%3E%2C%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3EThank%20you%20for%20your%20interest%20in%20NXP%20Semiconductor%20products%20and%3CBR%20%2F%3Efor%20the%20opportunity%20to%20serve%20you.%3CBR%20%2F%3EI'd%20like%20to%20know%20more%20information%20about%20the%20phenomenon%2C%20so%20whether%20you%20can%20introduce%20the%20process%20of%20secondary%20boot%20testing%20you%20did%2C%20and%20it%20may%20help%20me%20to%20figure%20it%20out.%3CBR%20%2F%3ELooking%20forward%20to%20your%20reply.%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3EHave%20a%20great%20day.%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3ETIC%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E-------------------------------------------------------------------------------%3CBR%20%2F%3ENote%3A%3CBR%20%2F%3E-%20If%20this%20post%20answers%20your%20question%2C%20please%20click%20the%20%22Mark%20Correct%22%20button.%20Thank%20you!%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E-%20We%20are%20following%20threads%20for%207%20weeks%20after%20the%20last%20post%2C%20later%20replies%20are%20ignored%3CBR%20%2F%3E%20Please%20open%20a%20new%20thread%20and%20refer%20to%20the%20closed%20one%2C%20if%20you%20have%20a%20related%20question%20at%20a%20later%20point%20in%20time.%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E
