SDRAM Bootable Image on RT1050
1,446 次查看
ndiwathe
Hello All,
I am trying to create SDRAM Bootable image of SDK Example .
Using SDK 2.7 , EVKB-RT1050
I have observed ,if I used “LED” blinky project then SDRAM bootable images works fine.
https://community.nxp.com/docs/DOC-341317
But when I use SDK example which has “WI_FI/ Ethernet & LWIP”.  SDRAM Bootable images are not working .
Examples :
  1. evkbimxrt1050_AWS_aws_greengrass_discovery_enet
  2. evkbimxrt1050_Aws_aws_shadow_wiced
I have added
*(.NonCacheable.init) =>>SDRAM_NCACHE ==>> .BSS
(.NonCacheable) =>>> SDRAM_NCACHE=>>>> . data
Nishi
1,361 次查看
Sabina_Bruce
Hello Nishi,
Hope you are doing well.
Could you please attempt to place the entire application in noncacheable. Please let me know your results.
Sabina
1,362 次查看
ndiwathe
Hello Sabina,
How to place the entire application in noncacheble area & create SDRAM bootable Image?
regards
Nishi
