RT685 i3c port with Zephyr - driver with i2c devices dies after minutes of use
7,184件の閲覧回数
galenc
I have a system based around the MIMXRT685-EVK running Zephyr.  I have the i3c port configured and interfacing with a few i2c devices.  They all work for some time, but depending of frequency of communication the bus/driver will just die after a few minutes.
I experienced this on the evk and on our custom board.  And similarly with all the peripherals on the bus or just a single one.
here you can see the scope (yellow SDA, green SCL, violet device interrupt) it just stops trying any comms on the bus when it should be servicing the interrupt:logic outputlogic output
It happens for this device which is imu - lsm6dso (a zephyr built in driver), sampling at higher frequency from interrupts. Even communicating with another device at slower frequency it will stay up longer but eventually crash (maybe 5-10 minutes with a polling message every second).
Here is the warnings we saw from the i3c_mcux driver just before the bus goes dead.  the errors are failed attempts to read from device registers (the bus in the scope has no activity from subsequent attempts, shown in red as errors):
warning from i3c_mcux before bus crashwarning from i3c_mcux before bus crash
Has anyone seen any issues similar with the i3c bus and zephyr implementation specifically?
our whole bus is essentially i2c devices we don't need the features of i3c (we are using it because we are using all the other ports) if there is a way it might be more stable if we "force" it into i2c mode all the time?
It don't know if there is a bug in the driver or some way to better configure it?  we are using it pretty much as it came.  see device tree sections:
&i3c0 {
	status = "okay";
	i2c-scl-hz = <400000>;
	i3c-scl-hz = <400000>;
	i3c-od-scl-hz = <400000>;
	clk-divider = <12>;
	clk-divider-slow = <1>;
	clk-divider-tc = <1>;
	pinctrl-0 = <&pinmux_i3c>;
	pinctrl-names = "default";
	lsm6dso0: lsm6dso@6a0000000000000050 {
		status = "okay";
		compatible = "st,lsm6dso";
		reg = <0x6a 0x00 0x50>;
		irq-gpios = <&gpio1 10 GPIO_ACTIVE_HIGH>;
	pinmux_i3c: pinmux_i3c {
		group0 {
			pinmux = <I3C0_SCL_PIO2_29>,
					 <I3C0_SDA_PIO2_30>;
			input-enable;
			slew-rate = "slow";
			drive-strength = "high";
		group1 {
			pinmux = <I3C0_PUR_PIO2_31>;
			slew-rate = "normal";
			drive-strength = "normal";
Any help is much appreciated.
Thanks, Galen
タグ(2)
6,181件の閲覧回数
Dezheng_Tang
Glad your I2C bitbang recover bus works. On the master side, several things you should check:
(1) PIN MUX needs to set back to I3C SCL and SDA lines.
(2) Make sure both MSTATUS and MERRWARN registers are reset to default state.
(3) In our SDK code, we have a module called I3C_MasterTransferAbort() to abort the master transfer. Please take a close look on this. I don't know why you would stay in NORMACK state even after you have issued STOP request. After you emit stop, you should wait for CTRL DONE. Once CTRL DONE is seen, it should be back to IDLE state.
(4) If (2) and (3) don't work, I don't know what else you can do, maybe reset I3C by writing 1 to I3C0 bit in RSTCTL1_PRSTCTL2. You may want to check all the I3C registers, especially, MCONFIG and make sure they are the same before and after resetting I3C bit.
25 返答(返信)
1,430件の閲覧回数
galenc
Yes, I agree this is a good idea for debug. I will set this up. I will be traveling for the next two weeks (starting tomorrow) but will report my results when I return.
Thanks for your continued help on this issue.
1,452件の閲覧回数
Dezheng_Tang
I tried to isolate the problem if Zephyr OS causes the problem or not and have run a standalone test on the I2C device using I3C controller. Here is a what I have done: on RT685 EVK board, there is a codec WM8904 on the I3C bus, if you use any audio related SDK example, this codec will be initialized using I3C controller (over I2C), I made minor change to do register reading periodically, monitor the bus and have never seen timeout happened unless you force it into one of these conditions below. It doesn't look our I3C controller could time out easily unless the STALL period is > 100us.
TIMEOUT Time-out error. The module has stalled too long in a frame. This happens:
• When the TX FIFO or RX FIFO is not handled and the bus is stuck in the middle of a
message,
• When no STOP was issued and between messages,
• When IBI manual is used and no decision was made.
The maximum stall period is 10 kHz or 100 us.
It's hard to time how often bus recovery should be called, hopefully, investigate why timeout happens so often first.
I don't know about the IO error, it looks like MCTRL and MSTATUS reading is OK, completion bit is set correctly.
[00:24:52.345,217] <dbg> i3c_mcux: mcux_i3c_has_error: ERROR: MCTRL 0x0000d250 MSTATUS 0x00009403 MERRWARN 0x00100000
1,570件の閲覧回数
Dezheng_Tang
Correction: I DON'T think bus will die if timeout bit is set.
1,580件の閲覧回数
Sam_Gao
Hi @galenc
I chcked the i3c source code from Zephyr https://github.com/zephyrproject-rtos/zephyr/blob/70f55bccf8af2866331f6fd84e05c600f4457704/drivers/i...
These codes in this file which follow Apache-2.0 were contributed from freescale, intel, nxp. I may need a little time to check if I can find right person to deal with this. Also, you can use Zephyr community ( Discussions and Issues ), they will support you directly.
About this I3C question(emit, IBI), I would like to share common driver from NXP:
https://github.com/nxp-mcuxpresso/mcux-sdk/blob/main/drivers/i3c/fsl_i3c.c#L690
1,704件の閲覧回数
Sam_Gao
Hi @galenc
It seems some issues releated to I3C, Zephyr, lsm6dso sensor and SDK. I try to clairfy what I found one by one as below, hope these comments help you find the root cause.
1. It seems support wm8904 codec as default I3C in Zephyr
 https://github.com/zephyrproject-rtos/zephyr/blob/main/boards/nxp/mimxrt685_evk/mimxrt685_evk_mimxrt...
https://github.com/zephyrproject-rtos/zephyr/blob/main/boards/nxp/mimxrt685_evk/mimxrt685_evk-pinctr...
&i3c0 {
	status = "okay";
	audio_codec: wm8904@1a0000000000000000 {
		compatible = "wolfson,wm8904";
		reg = <0x1a 0 0>;
		clock-source = "MCLK";
		clocks = <&clkctl0 MCUX_AUDIO_MCLK>;
		clock-names = "mclk";
 And actually I find it seems only support I2C(not mentioned I3C) from the introdcution https://github.com/zephyrproject-rtos/zephyr/blob/main/boards/nxp/mimxrt685_evk/doc/index.rst
PIO0_17 I2C I2C SDA
PIO0_18 I2C I2C SCL
2. If you use EVKMIMXRT685, I would like to recommend you to use offical SDK instead for testing. Please note the necessary board setting of I3C before your quick start, https://github.com/nxp-mcuxpresso/mcux-sdk-examples/tree/main/evkmimxrt685/driver_examples/i3c/polli...
 3. Also please check the sensor part(salve) independently whether this sensor support I3C or not.
4. Currently it is diffcult to give clear direction or sw/hw issue.
B.R,
Sam
%3CLINGO-SUB%20id%3D%22lingo-sub-2037988%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EZephyr%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9FRT685i3c%E3%83%9D%E3%83%BC%E3%83%88-i2c%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E6%95%B0%E5%88%86%E3%81%AE%E4%BD%BF%E7%94%A8%E5%BE%8C%E3%81%AB%E6%AD%BB%E3%81%AB%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2037988%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%82%BC%E3%83%95%E3%82%A1%E3%83%BC%E3%82%92%E8%B5%B0%E3%82%89%E3%81%9B%E3%82%8BMIMXRT685-EVK%E3%82%92%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%97%E3%81%9F%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82i3c%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AEi2c%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E3%81%97%E3%81%B0%E3%82%89%E3%81%8F%E3%81%AE%E9%96%93%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E9%80%9A%E4%BF%A1%E3%81%AE%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%81%AF%E3%80%81%E3%83%90%E3%82%B9%2F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AF%E6%95%B0%E5%88%86%E5%BE%8C%E3%81%AB%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%82%8C%E3%82%92evk%E3%81%A8%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E7%B5%8C%E9%A8%93%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E3%83%90%E3%82%B9%E4%B8%8A%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E5%91%A8%E8%BE%BA%E6%A9%9F%E5%99%A8%E3%82%841%E3%81%A4%E3%81%AE%E5%91%A8%E8%BE%BA%E6%A9%9F%E5%99%A8%E3%82%82%E5%90%8C%E6%A7%98%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%80%81%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97(%E9%BB%84%E8%89%B2%E3%81%AESDA%E3%80%81%E7%B7%91%E3%81%AESCL%E3%80%81%E7%B4%AB%E8%89%B2%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF)%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%80%81%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E5%87%A6%E7%90%86%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A8%E3%81%8D%E3%81%AB%E3%83%90%E3%82%B9%E4%B8%8A%E3%81%AE%E9%80%9A%E4%BF%A1%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%3A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22logic%20output%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22logic%20output%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F322382i253019A1376CCAE8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22bus_out.png%22%20alt%3D%22logic%20output%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Elogic%20output%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%20logic%E5%87%BA%E5%8A%9B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81imu%20-%20lsm6dso(zephyr%E5%86%85%E8%94%B5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC)%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E7%99%BA%E7%94%9F%E3%81%97%E3%80%81%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%8B%E3%82%89%E3%82%88%E3%82%8A%E9%AB%98%E3%81%84%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%A7%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%88%A5%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E4%BD%8E%E9%80%9F%E3%81%AE%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%A7%E9%80%9A%E4%BF%A1%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E9%95%B7%E6%99%82%E9%96%93%E7%A8%BC%E5%83%8D%E3%81%97%E3%81%9F%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E6%9C%80%E7%B5%82%E7%9A%84%E3%81%AB%E3%81%AF%E3%82%AF%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%BE%E3%81%99(%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F5%E3%80%9C10%E5%88%86%E3%81%A7%E3%80%81%E6%AF%8E%E7%A7%92%E3%83%9D%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99)%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%8C%E3%80%81%E3%83%90%E3%82%B9%E3%81%8C%E6%AD%BB%E3%81%AB%E8%87%B3%E3%82%8B%E7%9B%B4%E5%89%8D%E3%81%ABi3c_mcux%E3%81%AE%E9%81%8B%E8%BB%A2%E6%89%8B%E3%81%8B%E3%82%89%E8%A6%8B%E3%81%9F%E8%AD%A6%E5%91%8A%E3%81%A7%E3%81%99%E3%80%82%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%8B%E3%82%89%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%9F%E8%A9%A6%E8%A1%8C%E3%81%A7%E3%81%99%20(%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%E5%86%85%E3%81%AE%E3%83%90%E3%82%B9%E3%81%AB%E3%81%AF%E3%80%81%E5%BE%8C%E7%B6%9A%E3%81%AE%E8%A9%A6%E8%A1%8C%E3%81%8B%E3%82%89%E3%81%AE%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%93%E3%83%86%E3%82%A3%E3%81%8C%E3%81%AA%E3%81%8F%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E8%B5%A4%E3%81%A7%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99)%E3%80%82%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22warning%20from%20i3c_mcux%20before%20bus%20crash%22%20style%3D%22width%3A%20743px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22warning%20from%20i3c_mcux%20before%20bus%20crash%22%20style%3D%22width%3A%20743px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F322381i8829EEA7B786EBF2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot_20250203_152157.png%22%20alt%3D%22warning%20from%20i3c_mcux%20before%20bus%20crash%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ewarning%20from%20i3c_mcux%20before%20bus%20crash%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E3%83%90%E3%82%B9%E4%BA%8B%E6%95%85%E5%89%8D%E3%81%AEi3c_mcux%E3%81%8B%E3%82%89%E3%81%AE%E8%AD%A6%E5%91%8A%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3Ei3c%E3%83%90%E3%82%B9%E3%81%A8zephyr%E3%81%AE%E5%AE%9F%E8%A3%85%E3%81%AB%E9%A1%9E%E4%BC%BC%E3%81%97%E3%81%9F%E5%95%8F%E9%A1%8C%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%9F%E4%BA%BA%E3%81%AF%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E3%83%90%E3%82%B9%E5%85%A8%E4%BD%93%E3%81%AF%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%ABI2C%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81I3C%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93(%E4%BB%96%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81I3C%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99)%E6%96%B9%E6%B3%95%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AA%E3%82%89%E3%80%81%E5%B8%B8%E3%81%ABI2C%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%80%8C%E5%BC%B7%E5%88%B6%E3%80%8D%E3%81%99%E3%82%8B%E3%81%A8%E3%82%88%E3%82%8A%E5%AE%89%E5%AE%9A%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AB%E3%83%90%E3%82%B0%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E3%82%88%E3%82%8A%E9%81%A9%E5%88%87%E3%81%AB%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E6%9D%A5%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%A8%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E5%90%8C%E3%81%98%E3%82%88%E3%81%86%E3%81%AB%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%26amp%3Bi3c0%20%7B%0A%09status%20%3D%20%22okay%22%3B%0A%0A%09i2c-scl-hz%20%3D%20%26lt%3B400000%26gt%3B%3B%0A%09i3c-scl-hz%20%3D%20%26lt%3B400000%26gt%3B%3B%0A%09i3c-od-scl-hz%20%3D%20%26lt%3B400000%26gt%3B%3B%0A%0A%09clk-divider%20%3D%20%26lt%3B12%26gt%3B%3B%0A%09clk-divider-slow%20%3D%20%26lt%3B1%26gt%3B%3B%0A%09clk-divider-tc%20%3D%20%26lt%3B1%26gt%3B%3B%0A%0A%09pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinmux_i3c%26gt%3B%3B%0A%09pinctrl-names%20%3D%20%22default%22%3B%0A%0A%09lsm6dso0%3A%20lsm6dso%406a0000000000000050%20%7B%0A%09%09status%20%3D%20%22okay%22%3B%0A%09%09compatible%20%3D%20%22st%2Clsm6dso%22%3B%0A%09%09reg%20%3D%20%26lt%3B0x6a%200x00%200x50%26gt%3B%3B%0A%09%09irq-gpios%20%3D%20%26lt%3B%26amp%3Bgpio1%2010%20GPIO_ACTIVE_HIGH%26gt%3B%3B%0A%09%7D%3B%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%09pinmux_i3c%3A%20pinmux_i3c%20%7B%0A%09%09group0%20%7B%0A%09%09%09pinmux%20%3D%20%3CI3C0_SCL_PIO2_29%3E%2C%0A%09%09%09%09%09%20%3CI3C0_SDA_PIO2_30%3E%3B%0A%09%09%09input-enable%3B%0A%09%09%09slew-rate%20%3D%20%22slow%22%3B%0A%09%09%09drive-strength%20%3D%20%22high%22%3B%0A%09%09%7D%3B%0A%0A%09%09group1%20%7B%0A%09%09%09pinmux%20%3D%20%3CI3C0_PUR_PIO2_31%3E%3B%0A%09%09%09slew-rate%20%3D%20%22normal%22%3B%0A%09%09%09drive-strength%20%3D%20%22normal%22%3B%0A%09%09%7D%3B%0A%09%7D%3B%3C%2FI3C0_PUR_PIO2_31%3E%3C%2FI3C0_SDA_PIO2_30%3E%3C%2FI3C0_SCL_PIO2_29%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CBR%20%2F%3E%E3%81%A9%E3%82%93%E3%81%AA%E5%8A%A9%E3%81%91%E3%81%A7%E3%82%82%E5%A4%A7%E6%AD%93%E8%BF%8E%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E3%82%AC%E3%83%AC%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2037988%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MXRT%20600%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2072905%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AZephyr%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9FRT685%20i3c%E3%83%9D%E3%83%BC%E3%83%88%20-%20i2c%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E6%95%B0%E5%88%86%E3%81%AE%E4%BD%BF%E7%94%A8%E5%BE%8C%E3%81%AB%E6%AD%BB%E4%BA%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2072905%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F84797%22%20target%3D%22_blank%22%3E%40Dezheng_Tang%3C%2FA%3E%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%99!%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%E3%80%81bitbang%20recovery%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9F%E5%BE%8C(%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%82%92%E8%A1%8C%E3%81%86)%E3%80%81i3c%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E5%85%A8%E4%BD%93%E3%82%92%E5%86%8D%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%B0%91%E3%81%97%E3%83%9A%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E4%BB%8A%E3%81%AE%E3%81%A8%E3%81%93%E3%82%8D%E3%81%AF%E5%8D%81%E5%88%86%E3%81%A7%E3%81%99%E3%80%82%E6%98%A8%E5%A4%9C%E3%81%AF6%E6%99%82%E9%96%93%E3%81%B6%E3%81%A3%E9%80%9A%E3%81%97%E3%81%A7%E5%8B%95%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E9%9B%BB%E6%BA%90%E3%82%92%E5%88%87%E3%82%8B%E5%89%8D%E3%81%AB3%E5%9B%9E%E5%9B%9E%E5%BE%A9%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E6%8F%B4%E5%8A%A9%E3%81%A8%E5%BF%8D%E8%80%90%E3%81%AB%E6%84%9F%E8%AC%9D%E3%81%97%E3%81%BE%E3%81%99!%3CBR%20%2F%3E-%E3%82%AC%E3%83%AC%E3%83%8E%E3%82%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2071414%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AZephyr%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9FRT685%20i3c%E3%83%9D%E3%83%BC%E3%83%88%20-%20i2c%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E6%95%B0%E5%88%86%E3%81%AE%E4%BD%BF%E7%94%A8%E5%BE%8C%E3%81%AB%E6%AD%BB%E4%BA%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2071414%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AEI2C%E3%83%93%E3%83%83%E3%83%88%E3%83%90%E3%83%B3%E5%9B%9E%E5%BE%A9%E3%83%90%E3%82%B9%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%86%E3%82%8C%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E5%81%B4%E3%81%A7%E3%81%AF%E3%80%81%E7%A2%BA%E8%AA%8D%E3%81%99%E3%81%B9%E3%81%8D%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E7%82%B9%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E(1)%20PIN%20MUX%20%E3%81%AF%20I3C%20SCL%20%E3%81%8A%E3%82%88%E3%81%B3%20SDA%20%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AB%E6%88%BB%E3%81%99%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E(2)%20MSTATUS%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%A8%20MERRWARN%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%8C%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%20%E3%82%B9%E3%83%86%E3%83%BC%E3%83%88%E3%81%AB%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E(3)SDK%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AF%E3%80%81%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E8%BB%A2%E9%80%81%E3%82%92%E4%B8%AD%E6%AD%A2%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AEI3C_MasterTransferAbort()%E3%81%A8%E3%81%84%E3%81%86%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9C%E3%81%B2%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%AA%E3%81%9CSTOP%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%E3%82%92%E5%87%BA%E3%81%97%E3%81%9F%E5%BE%8C%E3%82%82NOMACK%E7%8A%B6%E6%85%8B%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%A7%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82stop%20%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%97%E3%81%9F%E5%BE%8C%E3%81%AF%E3%80%81CTRL%20DONE%20%E3%82%92%E5%BE%85%E3%81%A4%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82CTRL%20DONE%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%9F%E3%82%89%E3%80%81IDLE%E7%8A%B6%E6%85%8B%E3%81%AB%E6%88%BB%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E(4)(2)%E3%81%A8(3)%E3%81%8C%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8B%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E4%BB%96%E3%81%AB%E4%BD%95%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81RSTCTL1_PRSTCTL2%E3%81%A71%E3%82%92I3C0%E3%83%93%E3%83%83%E3%83%88%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7I3C%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AEI3C%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%80%81%E7%89%B9%E3%81%ABMCONFIG%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%97%E3%80%81I3C%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%99%E3%82%8B%E5%89%8D%E3%81%A8%E5%BE%8C%E3%81%A7%E5%90%8C%E3%81%98%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2071392%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AZephyr%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9FRT685%20i3c%E3%83%9D%E3%83%BC%E3%83%88%20-%20i2c%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E6%95%B0%E5%88%86%E3%81%AE%E4%BD%BF%E7%94%A8%E5%BE%8C%E3%81%AB%E6%AD%BB%E4%BA%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2071392%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%8C%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%81%93%E3%81%A8%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%A6%E3%81%84%E3%81%9F%E9%81%85%E5%BB%B6%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F84797%22%20target%3D%22_blank%22%3E%40Dezheng_Tang%3C%2FA%3E%20%E3%80%82%E5%95%8F%E9%A1%8C%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%81%A8%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE1%E3%81%A4%E3%81%AB%E5%88%86%E9%9B%A2%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81%E3%81%9D%E3%81%93%E3%81%AB%E3%81%AF%E3%81%BE%E3%81%A0%E6%B1%BA%E5%AE%9A%E7%9A%84%E3%81%AA%E3%82%B7%E3%82%B0%E3%83%8A%E3%83%AB%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E6%8F%90%E6%A1%88%E3%81%97%E3%81%9F%E3%81%AE%E3%81%A8%E5%90%8C%E6%A7%98%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%AA%E3%82%AB%E3%83%90%E3%83%AA%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%A7%81%E3%81%AF%E5%AE%9F%E9%9A%9B%E3%81%ABi2c_bitbang%20i2c%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%A7%E3%83%AA%E3%82%AB%E3%83%90%E3%83%AA%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92i3c%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AB%E5%BC%95%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Eint%20i2c_bitbang_recover_bus(struct%20i2c_bitbang%20*context)%0A%7B%0A%09int%20i%3B%0A%0A%09%2F*%0A%09%20*%20The%20I2C-bus%20specification%20and%20user%20manual%20(NXP%20UM10204%0A%09%20*%20rev.%206%2C%20section%203.1.16)%20suggests%20the%20master%20emit%209%20SCL%0A%09%20*%20clock%20pulses%20to%20recover%20the%20bus.%0A%09%20*%0A%09%20*%20The%20Linux%20kernel%20I2C%20bitbang%20recovery%20functionality%20issues%0A%09%20*%20a%20START%20condition%20followed%20by%209%20STOP%20conditions.%0A%09%20*%0A%09%20*%20Other%20I2C%20slave%20devices%20(e.g.%20Microchip%20ATSHA204a)%20suggest%0A%09%20*%20issuing%20a%20START%20condition%20followed%20by%209%20SCL%20clock%20pulses%0A%09%20*%20with%20SDA%20held%20high%2Ffloating%2C%20a%20REPEATED%20START%20condition%2C%0A%09%20*%20and%20a%20STOP%20condition.%0A%09%20*%0A%09%20*%20The%20latter%20is%20what%20is%20implemented%20here.%0A%09%20*%2F%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3ESDA%E3%82%92%E9%AB%98%E3%81%8F%E8%BF%94%E3%81%99%E3%82%88%E3%81%86%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22galenc_0-1743449474703.png%22%20style%3D%22width%3A%20705px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22galenc_0-1743449474703.png%22%20style%3D%22width%3A%20705px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F330584i07338F35CFA36B8F%2Fimage-dimensions%2F705x126%3Fv%3Dv2%22%20width%3D%22705%22%20height%3D%22126%22%20role%3D%22button%22%20title%3D%22galenc_0-1743449474703.png%22%20alt%3D%22galenc_0-1743449474703.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E6%95%B0%E5%9B%9E%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22galenc_1-1743449520063.png%22%20style%3D%22width%3A%20710px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22galenc_1-1743449520063.png%22%20style%3D%22width%3A%20710px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F330585iF83217A4F37A38F9%2Fimage-dimensions%2F710x153%3Fv%3Dv2%22%20width%3D%22710%22%20height%3D%22153%22%20role%3D%22button%22%20title%3D%22galenc_1-1743449520063.png%22%20alt%3D%22galenc_1-1743449520063.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81i3c%E3%81%AFIDLE%E3%81%AB%E6%88%BB%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93(%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%80%81STOP%E3%82%92%E6%94%BE%E5%87%BA%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%ABIDLE%E3%81%AB%E5%85%A5%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%99%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BCEHOSTDOWN%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F)%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%5B00%3A17%3A30.601%2C824%5D%20%3CERR%3E%20i3c_mcux%3A%20do_one_xfer_read%20Timeout%20error%0A%5B00%3A17%3A30.601%2C843%5D%20%3CWRN%3E%20i3c_mcux%3A%20ERROR%20from%20transfer%20read%3D1%2C%20error%3D-116%0A%5B00%3A17%3A30.736%2C449%5D%20%3CERR%3E%20i3c_mcux%3A%20Tried%20to%20emit%20stop%2010000times..clearing%20all!%20MCTRL%200x00000052%20MSTATUS%200x00001903%20MERRWARN%200x00000000%20MIBIRULES%200x00000000%0A%5B00%3A17%3A31.736%2C672%5D%20%3CWRN%3E%20i3c_mcux%3A%20EMIT%20STOP%20return%20EHOSTDOWN%0A%5B00%3A17%3A31.736%2C688%5D%20%3CWRN%3E%20i3c_mcux%3A%20Timeout%20on%20emit%20stop%2C%20retrying%0A%5B00%3A17%3A31.871%2C770%5D%20%3CERR%3E%20i3c_mcux%3A%20Tried%20to%20emit%20stop%2010000times..clearing%20all!%20MCTRL%200x00000052%20MSTATUS%200x00001103%20MERRWARN%200x00000000%20MIBIRULES%200x00000000%0A%5B00%3A17%3A32.871%2C977%5D%20%3CWRN%3E%20i3c_mcux%3A%20EMIT%20STOP%20return%20EHOSTDOWN%0A%5B00%3A17%3A32.871%2C993%5D%20%3CWRN%3E%20i3c_mcux%3A%20Timeout%20on%20emit%20stop%2C%20retrying%0A%5B00%3A17%3A33.006%2C332%5D%20%3CERR%3E%20i3c_mcux%3A%20Tried%20to%20emit%20stop%2010000times..clearing%20all!%20MCTRL%200x00000052%20MSTATUS%200x00001103%20MERRWARN%200x00000000%20MIBIRULES%200x00000000%0A%5B00%3A17%3A34.006%2C569%5D%20%3CWRN%3E%20i3c_mcux%3A%20EMIT%20STOP%20return%20EHOSTDOWN%0A%5B00%3A17%3A34.006%2C586%5D%20%3CWRN%3E%20i3c_mcux%3A%20Timeout%20on%20emit%20stop%2C%20retrying%0A%5B00%3A17%3A34.139%2C991%5D%20%3CERR%3E%20i3c_mcux%3A%20Tried%20to%20emit%20stop%2010000times..clearing%20all!%20MCTRL%200x00000052%20MSTATUS%200x00001103%20MERRWARN%200x00000000%20MIBIRULES%200x00000000%0A%5B00%3A17%3A35.140%2C169%5D%20%3CWRN%3E%20i3c_mcux%3A%20EMIT%20STOP%20return%20EHOSTDOWN%0A%5B00%3A17%3A35.140%2C180%5D%20%3CWRN%3E%20i3c_mcux%3A%20Timeout%20on%20emit%20stop%2C%20retrying%0A%5B00%3A17%3A35.274%2C973%5D%20%3CERR%3E%20i3c_mcux%3A%20Tried%20to%20emit%20stop%2010000times..clearing%20all!%20MCTRL%200x00000052%20MSTATUS%200x00001103%20MERRWARN%200x00000000%20MIBIRULES%200x00000000%0A%5B00%3A17%3A36.275%2C072%5D%20%3CWRN%3E%20i3c_mcux%3A%20EMIT%20STOP%20return%20EHOSTDOWN%0A%5B00%3A17%3A36.275%2C088%5D%20%3CWRN%3E%20i3c_mcux%3A%20Timeout%20on%20emit%20stop%2C%20retrying%0A%5B00%3A17%3A36.410%2C054%5D%20%3CERR%3E%20i3c_mcux%3A%20Tried%20to%20emit%20stop%2010000times..clearing%20all!%20MCTRL%200x00000052%20MSTATUS%200x00001103%20MERRWARN%200x00000000%20MIBIRULES%200x00000000%0A%5B00%3A17%3A37.410%2C277%5D%20%3CWRN%3E%20i3c_mcux%3A%20EMIT%20STOP%20return%20EHOSTDOWN%0A%5B00%3A17%3A37.410%2C295%5D%20%3CERR%3E%20i3c_mcux%3A%20Error%20waiting%20for%20stop%20EHOSTDOWN%0A%5B00%3A17%3A37.410%2C303%5D%20%3CERR%3E%20i3c_mcux%3A%20STOP%20ERROR%20%3D%20-117%0A%5B00%3A17%3A37.410%2C306%5D%20%3CWRN%3E%20i3c_mcux%3A%20RETURN%20EHOSTDOWN%0A%5B00%3A17%3A37.543%2C104%5D%20%3CERR%3E%20i3c_mcux%3A%20Tried%20to%20emit%20stop%2010000times..clearing%20all!%20MCTRL%200x00000052%20MSTATUS%200x00001103%20MERRWARN%200x00000000%20MIBIRULES%200x00000000%0Afusion_core%3A~%24i3c_recover%0A---%2021%20messages%20dropped%20---%0A%5B00%3A17%3A38.543%2C281%5D%20%3CWRN%3E%20i3c_mcux%3A%20EMIT%20STOP%20return%20EHOSTDOWN%0A%5B00%3A17%3A38.543%2C297%5D%20%3CWRN%3E%20i3c_mcux%3A%20Timeout%20on%20emit%20stop%2C%20retrying%0A%5B00%3A17%3A38.678%2C129%5D%20%3CERR%3E%20i3c_mcux%3A%20Tried%20to%20emit%20stop%2010000times..clearing%20all!%20MCTRL%200x00000052%20MSTATUS%200x00001103%20MERRWARN%200x00000000%20MIBIRULES%200x00000000%0A%5B00%3A17%3A38.748%2C052%5D%20%3CWRN%3E%20charger%3A%20TRUING%20TO%20RECOVR%20BUS%0A%5B00%3A17%3A38.848%2C277%5D%20%3CWRN%3E%20i3c_mcux%3A%20pnx_mcux_i3c_recover_bus%20...%20using%20i2c%20bus%20reovery!!!!%0A%5B00%3A17%3A39.678%2C370%5D%20%3CWRN%3E%20i3c_mcux%3A%20EMIT%20STOP%20return%20EHOSTDOWN%0A%5B00%3A17%3A39.678%2C388%5D%20%3CWRN%3E%20i3c_mcux%3A%20Timeout%20on%20emit%20stop%2C%20retrying%0A%5B00%3A17%3A39.813%2C108%5D%20%3CERR%3E%20i3c_mcux%3A%20Tried%20to%20emit%20stop%2010000times..clearing%20all!%20MCTRL%200x00000052%20MSTATUS%200x00001103%20MERRWARN%200x00000000%20MIBIRULES%200x00000000%0A%5B00%3A17%3A40.813%2C268%5D%20%3CWRN%3E%20i3c_mcux%3A%20EMIT%20STOP%20return%20EHOSTDOWN%0A%5B00%3A17%3A40.813%2C281%5D%20%3CWRN%3E%20i3c_mcux%3A%20Timeout%20on%20emit%20stop%2C%20retrying%0A%5B00%3A17%3A40.948%2C013%5D%20%3CERR%3E%20i3c_mcux%3A%20Tried%20to%20emit%20stop%2010000times..clearing%20all!%20MCTRL%200x00000052%20MSTATUS%200x00001103%20MERRWARN%200x00000000%20MIBIRULES%200x00000000%0A%5B00%3A17%3A41.948%2C273%5D%20%3CWRN%3E%20i3c_mcux%3A%20EMIT%20STOP%20return%20EHOSTDOWN%0A%5B00%3A17%3A41.948%2C292%5D%20%3CWRN%3E%20i3c_mcux%3A%20Timeout%20on%20emit%20stop%2C%20retrying%0A%5B00%3A17%3A42.081%2C881%5D%20%3CERR%3E%20i3c_mcux%3A%20Tried%20to%20emit%20stop%2010000times..clearing%20all!%20MCTRL%200x00000052%20MSTATUS%200x00001103%20MERRWARN%200x00000000%20MIBIRULES%200x00000000%0A%5B00%3A17%3A43.082%2C069%5D%20%3CWRN%3E%20i3c_mcux%3A%20EMIT%20STOP%20return%20EHOSTDOWN%0A%5B00%3A17%3A43.082%2C087%5D%20%3CWRN%3E%20i3c_mcux%3A%20Timeout%20on%20emit%20stop%2C%20retrying%0A%5B00%3A17%3A43.216%2C617%5D%20%3CERR%3E%20i3c_mcux%3A%20Tried%20to%20emit%20stop%2010000times..clearing%20all!%20MCTRL%200x00000052%20MSTATUS%200x00001103%20MERRWARN%200x00000000%20MIBIRULES%200x00000000%0A%5B00%3A17%3A51.046%2C370%5D%20%3CWRN%3E%20i3c_mcux%3A%20EMIT%20STOP%20return%20EHOSTDOWN%0A%5B00%3A17%3A51.046%2C389%5D%20%3CERR%3E%20i3c_mcux%3A%20Error%20waiting%20for%20stop%20EHOSTDOWN%3C%2FERR%3E%3C%2FWRN%3E%3C%2FERR%3E%3C%2FWRN%3E%3C%2FWRN%3E%3C%2FERR%3E%3C%2FWRN%3E%3C%2FWRN%3E%3C%2FERR%3E%3C%2FWRN%3E%3C%2FWRN%3E%3C%2FERR%3E%3C%2FWRN%3E%3C%2FWRN%3E%3C%2FWRN%3E%3C%2FWRN%3E%3C%2FERR%3E%3C%2FWRN%3E%3C%2FWRN%3E%3C%2FERR%3E%3C%2FWRN%3E%3C%2FERR%3E%3C%2FERR%3E%3C%2FWRN%3E%3C%2FERR%3E%3C%2FWRN%3E%3C%2FWRN%3E%3C%2FERR%3E%3C%2FWRN%3E%3C%2FWRN%3E%3C%2FERR%3E%3C%2FWRN%3E%3C%2FWRN%3E%3C%2FERR%3E%3C%2FWRN%3E%3C%2FWRN%3E%3C%2FERR%3E%3C%2FWRN%3E%3C%2FWRN%3E%3C%2FERR%3E%3C%2FWRN%3E%3C%2FERR%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CBR%20%2F%3E%E7%A7%81%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AF%3AGPIO%E3%83%88%E3%82%B0%E3%83%AB%2F%E3%83%93%E3%83%83%E3%83%88%E3%83%90%E3%83%B3%E3%82%A4%E3%83%B3%E3%82%B0%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6SDA%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E5%9B%9E%E5%BE%A9%E3%81%A7%E3%81%8D%E3%81%9F%E5%BE%8C%E3%80%81i3c%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%82%92%E5%85%83%E3%81%AB%E6%88%BB%E3%81%99%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E6%89%8B%E9%A0%86%E3%82%92%E8%B8%8F%E3%82%80%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%20NORMACT%E3%81%AE%E3%81%A9%E3%81%93%E3%81%8B%E3%81%A7%E3%81%BE%E3%81%A0%E5%8B%95%E3%81%8B%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E4%BD%95%E3%82%82%E9%80%81%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3EZephyr%E3%81%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%80%8C%E5%86%8D%E5%88%9D%E6%9C%9F%E5%8C%96%E3%80%8D%E3%82%92%E8%A8%B1%E5%8F%AF%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%82%BC%E3%83%AD%E3%81%8B%E3%82%89%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E7%A7%81%E3%81%8C%E3%82%84%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%84%9F%E8%AC%9D%3CBR%20%2F%3E%E3%82%AC%E3%83%AC%E3%83%8E%E3%82%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2068960%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AZephyr%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9FRT685%20i3c%E3%83%9D%E3%83%BC%E3%83%88%20-%20i2c%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E6%95%B0%E5%88%86%E3%81%AE%E4%BD%BF%E7%94%A8%E5%BE%8C%E3%81%AB%E6%AD%BB%E4%BA%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2068960%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%82%E3%81%861%E3%81%A4%E4%BB%98%E3%81%91%E5%8A%A0%E3%81%88%E3%82%8B%E3%81%A8%E3%80%81RT685%E3%81%A8%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%AE%E9%96%93%E3%81%AB%E3%83%AC%E3%83%99%E3%83%AB%E3%82%B7%E3%83%95%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%83%AC%E3%83%99%E3%83%AB%E3%82%B7%E3%83%95%E3%82%BF%E3%83%BC%E3%82%92%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9%E3%81%97%E3%81%A6%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E5%BD%B9%E7%AB%8B%E3%81%A4%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%E4%BF%A1%E5%8F%B7%E3%81%AE%E5%93%81%E8%B3%AA%E3%81%8C%E3%83%90%E3%82%B9%E3%81%AE%E3%83%AD%E3%83%83%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%AB%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E5%BD%B9%E5%89%B2%E3%82%92%E6%9E%9C%E3%81%9F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2068934%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AZephyr%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9FRT685%20i3c%E3%83%9D%E3%83%BC%E3%83%88%20-%20i2c%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E6%95%B0%E5%88%86%E3%81%AE%E4%BD%BF%E7%94%A8%E5%BE%8C%E3%81%AB%E6%AD%BB%E4%BA%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2068934%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E3%80%8C%E6%AD%BB%E3%82%93%E3%81%A7%E3%81%84%E3%82%8B%E3%80%8D%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%88%E3%80%81SDA%E3%82%92%E6%B0%B8%E9%81%A0%E3%81%AB%E4%BD%8E%E3%81%8F%E4%BF%9D%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E5%A0%B4%E5%90%88%E3%80%81I3C%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%81%AE%E5%86%8D%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%84%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%82%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82RT68x%E3%81%A8%E3%81%AF%E9%96%A2%E4%BF%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BF%9D%E8%A8%BC%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%8F%E3%81%91%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E(1)I2C%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E5%B0%91%E3%81%97%E9%81%85%E3%81%8F%E3%81%97%E3%80%81%E3%83%87%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%80%81%E7%AB%8B%E3%81%A1%E4%B8%8A%E3%81%8C%E3%82%8A%2F%E7%AB%8B%E3%81%A1%E4%B8%8B%E3%81%8C%E3%82%8A%E6%99%82%E9%96%93%E3%82%92%E5%BE%AE%E8%AA%BF%E6%95%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E(2)H%20%2F%20W%E3%81%AE%E8%80%83%E6%85%AE%E4%BA%8B%E9%A0%85%E3%80%81LSM6DSO%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81VDD%E3%81%AB%E3%82%B0%E3%83%AA%E3%83%83%E3%83%81%E3%81%8C%E3%81%AA%E3%81%8F%E3%80%811.71V%E3%82%92%E4%B8%8B%E5%9B%9E%E3%82%89%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%9F%E3%81%B6%E3%82%93%E3%80%81%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB3.3V%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8Bi2c%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E9%81%95%E5%8F%8D%E3%81%8C%E5%BF%83%E9%85%8D%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E(3)%E3%83%90%E3%82%B9%E3%81%AESCL%20%2F%20SDA%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%8C%E3%81%8D%E3%82%8C%E3%81%84%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%82%88%E3%82%8A%E5%BC%B7%E5%8A%9B%E3%81%AA%E3%83%97%E3%83%AB%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E(4)%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%91%E3%81%B0%E3%80%81IOCON%E3%83%95%E3%83%AB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FP%3E%0A%3CP%3E(5)%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E9%80%9F%E5%BA%A6%E3%82%92%E5%B0%91%E3%81%97%E9%81%85%E3%81%8F%E3%81%97%E3%81%A6%E3%80%81%E5%BD%B9%E7%AB%8B%E3%81%A4%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E(6)%20GPIO%E3%83%94%E3%83%B3%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%80%8120~30%E5%9B%9E%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%80%81I3C%20SCL%20%2F%20SDA%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%A6%E3%80%81%E3%83%90%E3%82%B9%E3%81%8C%E3%82%A2%E3%82%A4%E3%83%89%E3%83%AB%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82SCL%E3%81%A8SDA%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%8C%E3%83%8F%E3%82%A4%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2068877%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AZephyr%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9FRT685%20i3c%E3%83%9D%E3%83%BC%E3%83%88%20-%20i2c%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E6%95%B0%E5%88%86%E3%81%AE%E4%BD%BF%E7%94%A8%E5%BE%8C%E3%81%AB%E6%AD%BB%E4%BA%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2068877%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%AD%E3%82%B0%E3%81%AE%E4%B8%80%E9%83%A8%E3%82%92%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%BE%E3%81%A0%E3%81%9D%E3%81%AE%E6%B3%A2%E5%BD%A2%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%20SDA%20%E3%81%8C%20Low%20%E3%81%A7%E3%80%81High%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%81%AE%E3%83%97%E3%83%AD%E3%83%83%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%922%E5%9B%9E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%9F%E5%BE%8C%E3%81%AB%E3%81%AE%E3%81%BF%E5%9B%9E%E5%BE%A9%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22galenc_0-1743009758872.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22galenc_0-1743009758872.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F329926i4F041587DA79F6F9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22galenc_0-1743009758872.png%22%20alt%3D%22galenc_0-1743009758872.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E4%B8%AD%E5%A4%AE%E3%81%AE%E3%80%8C%E3%83%91%E3%83%AB%E3%82%B9%E3%80%8D%E3%82%92%E8%A9%B3%E3%81%97%E3%81%8F%E8%A6%8B%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%82%87%E3%81%86(%E5%88%9D%E3%82%81%E3%81%A6%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E6%8A%BC%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D)%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22galenc_1-1743009799689.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22galenc_1-1743009799689.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F329927i03004D32CF00222B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22galenc_1-1743009799689.png%22%20alt%3D%22galenc_1-1743009799689.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EZephyr%E3%81%AF%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%A7pre-main%E3%81%AEinit%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E9%80%9A%E9%81%8E%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E3%83%90%E3%82%B9%E3%81%AF%E3%80%81SDA%E3%81%8C%E6%9C%80%E7%B5%82%E7%9A%84%E3%81%AB%E3%83%8F%E3%82%A4%E3%81%AB%E9%81%B7%E7%A7%BB%E3%81%99%E3%82%8B2%E5%9B%9E%E7%9B%AE%E3%81%AE%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E5%BE%8C%E3%81%AB%E3%81%AE%E3%81%BF%E5%9B%9E%E5%BE%A9%E3%81%97%E3%81%BE%E3%81%99%E3%80%82SDA%E3%81%8C%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E4%BD%8E%E3%81%8F%E6%8A%91%E3%81%88%E3%82%89%E3%82%8C%E3%82%8B%E5%8E%9F%E5%9B%A0%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%E3%83%A9%E3%82%A4%E3%83%B3%E4%B8%8A%E3%81%AB%E3%81%AF%E8%A4%87%E6%95%B0%E3%81%AE%E3%83%97%E3%83%AB%E3%82%A2%E3%83%83%E3%83%97%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%E4%BD%95%E3%81%8B%E3%81%8C%E3%81%9D%E3%82%8C%E3%82%92%E4%BD%8E%E3%81%8F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AB%E9%81%95%E3%81%84%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82GPIO%E3%83%9E%E3%83%AB%E3%83%81%E3%83%97%E3%83%AC%E3%82%AF%E3%82%B5%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%A6%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E6%8F%90%E6%A1%88%E3%81%AF%E3%81%93%E3%82%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2068108%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AZephyr%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9FRT685%20i3c%E3%83%9D%E3%83%BC%E3%83%88%20-%20i2c%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E6%95%B0%E5%88%86%E3%81%AE%E4%BD%BF%E7%94%A8%E5%BE%8C%E3%81%AB%E6%AD%BB%E4%BA%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2068108%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%AD%E3%82%B0%E3%81%AF%E3%80%81%E5%89%8D%E3%81%AB%E8%A6%8B%E3%81%9F%E3%82%82%E3%81%AE%E3%81%A8%E3%81%AF%E5%A4%A7%E3%81%8D%E3%81%8F%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E5%89%8D%E3%81%AB%E6%8A%95%E7%A8%BF%E3%81%97%E3%81%9F%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E6%B3%A2%E5%BD%A2%E3%81%AF%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6I2C%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81MCTRL%E3%83%93%E3%83%83%E3%83%880~7%E3%81%AF0x50%E3%81%BE%E3%81%9F%E3%81%AF0x52%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E3%81%93%E3%82%8C%E3%82%82I2C%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81EmitStop()%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81IBI%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E3%83%90%E3%82%B9%E3%81%AFNORMACK%E3%81%A7I2C%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%82%82%E3%81%8A%E3%81%A3%E3%81%97%E3%82%83%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3EMCTRL%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%E3%83%93%E3%83%83%E3%83%88%205~4%20TYPE%20%E3%81%8C%E3%81%84%E3%81%A4%E3%80%81%E3%81%A9%E3%81%93%E3%81%A7%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%9F%E3%81%AE%E3%81%8B%E3%80%81%E3%81%AA%E3%81%9C%E7%AA%81%E7%84%B6%20IBI%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%A3%9B%E3%81%B3%E5%87%BA%E3%81%99%E3%81%AE%E3%81%8B%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%82%82%E3%81%86%E4%B8%80%E3%81%A4%E8%88%88%E5%91%B3%E6%B7%B1%E3%81%84%E3%81%AE%E3%81%AF%E3%80%81FORCE%20EXIT%E3%81%8CHDR%2FDDR%E7%94%A8%E3%81%A7%E3%80%81EMIT%20STOP%E3%81%8CSDR%E7%94%A8%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82FORCE%20EXIT%20%E3%81%A8%20EMIT%20STOP%20%E3%81%8C%E5%90%8C%E6%99%82%E3%81%AB%E3%83%AD%E3%82%B0%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2068090%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AZephyr%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9FRT685%20i3c%E3%83%9D%E3%83%BC%E3%83%88%20-%20i2c%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E6%95%B0%E5%88%86%E3%81%AE%E4%BD%BF%E7%94%A8%E5%BE%8C%E3%81%AB%E6%AD%BB%E4%BA%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2068090%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%BF%83%E9%85%8D%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%81%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E9%96%A2%E4%BF%82%E3%81%AA%E3%81%8F%E3%81%A9%E3%82%8C%E3%81%BB%E3%81%A9%E8%BF%85%E9%80%9F%E3%81%A7%E3%81%82%E3%82%8B%E3%81%8B%E3%81%AB%E6%84%9F%E8%AC%9D%E3%81%97%E3%81%BE%E3%81%99%20%3CLI-EMOJI%20id%3D%22lia_slightly-smiling-face%22%20title%3D%22%3Aslightly_smiling_face%3A%22%3E%3C%2FLI-EMOJI%3E%20%E3%81%88%E3%81%88%E3%80%81GPIO%E3%81%AF%E3%81%86%E3%81%BE%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81EVK%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%ABGPIO%E3%83%88%E3%82%B0%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E6%A9%9F%E8%83%BD%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9D%E3%81%93%E3%81%A7IO%E3%82%92%E5%86%8D%E5%88%A9%E7%94%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BB%8A%E3%81%AE%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF10%E3%80%9C20%E5%88%86%E5%BE%8C%E3%81%AB%E3%83%90%E3%82%B9%E3%82%92%E3%81%8B%E3%81%AA%E3%82%8A%E7%A2%BA%E5%AE%9F%E3%81%AB%E9%99%8D%E3%82%8D%E3%81%99%E3%81%A8%E8%A6%8B%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C(%E3%81%93%E3%82%8C%E3%81%AF%E3%81%AF%E3%82%8B%E3%81%8B%E3%81%AB%E8%A4%87%E9%9B%91%E3%81%AA%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E3%81%99)%E3%80%81EVK%E3%81%A7%E3%81%AF%E3%81%8B%E3%81%AA%E3%82%8A%E5%AE%89%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AFGPIO%E3%81%A8%E3%81%97%E3%81%A6SCL%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E5%BC%B7%E5%88%B6%E3%81%99%E3%82%8B%E3%81%9D%E3%81%AE%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%8C%E5%A5%BD%E3%81%8D%E3%81%A7%E3%81%99%E3%80%81%E7%A7%81%E3%81%AF%E3%81%9F%E3%81%A0Zephyr%E3%81%A7%E3%81%93%E3%82%8C%E3%82%92%E8%A1%8C%E3%81%86%E3%81%9F%E3%82%81%E3%81%AE%E8%89%AF%E3%81%84%E6%96%B9%E6%B3%95%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E5%87%BA%E3%81%95%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%81%AA%E3%82%89%E3%81%AA%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%BE%E3%81%A7%E3%81%AE%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E4%BB%96%E3%81%AB%E8%A9%B1%E3%81%99%E3%81%93%E3%81%A8%E3%81%AF%E3%81%82%E3%81%BE%E3%82%8A%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81MCTRL%E3%81%8CI3C%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E8%A8%80%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%88%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E3%81%A5%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%820x42%E3%80%81%E3%83%93%E3%83%83%E3%83%88%205%3A4%20%E3%81%8C%200%20%3D%20I3C%20%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82I2C%E3%81%A7%E3%81%99%E3%81%B9%E3%81%A6%E3%81%8C%E3%81%9D%E3%81%86%E3%81%82%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%AA%E3%81%AE%E3%81%AB%E3%80%81%E3%81%AA%E3%81%9C%E3%81%9D%E3%81%86%E3%81%AA%E3%82%8B%E3%81%AE%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82I3C%E3%81%8C%E5%8F%AF%E8%83%BD%E3%81%AA%E5%94%AF%E4%B8%80%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%E3%80%81OTS%20zephyr%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%A7%E3%81%82%E3%82%8BLSM6DSOX%E3%81%A7%E3%81%99(%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%E8%B5%B7%E5%8B%95%E6%99%82%E3%81%AB%E6%95%B0%E5%88%86%E9%96%93%E3%81%97%E3%81%8B%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93)%E3%81%8C%E3%80%81init%E3%81%A7i2c%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%BC%B7%E5%88%B6%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%5B00%3A38%3A31.275%2C094%5D%20%3CINF%3E%20charger%3A%20Vin%3D260mV%2C%20State%3D0%2C%20Tj%3D31.701500%20DegC%2C%20NTC%3D0.461914%2C%20TS%3D0.283203%3A%20Battery%20V%3D7970mV%20I%3D0mA%2C%20cell_count%3D2%2C%20per_cell%3D3985%20ADC_s%3D1%20ADC_c%3D1%0A%5B00%3A38%3A32.282%2C810%5D%20%3CERR%3E%20i3c_mcux%3A%20IBI%20Timeout%20error%0A%5B00%3A38%3A32.282%2C825%5D%20%3CWRN%3E%20i3c_mcux%3A%20ERROR%20from%20transfer%20read%3D1%2C%20error%3D-116%0A%5B00%3A38%3A32.415%2C111%5D%20%3CERR%3E%20i3c_mcux%3A%20Tried%20to%20emit%20stop%2010000times..clearing%20all!%20MCTRL%200x00000042%20MSTATUS%200x00001803%20MERRWARN%200x00000000%20MIBIRULES%200x00000000%0A%5B00%3A38%3A33.415%2C389%5D%20%3CERR%3E%20i3c_mcux%3A%20FORCE%20EXIT%0A%5B00%3A38%3A33.515%2C582%5D%20%3CWRN%3E%20i3c_mcux%3A%20EMIT%20STOP%20return%20timeout%0A%5B00%3A38%3A33.515%2C597%5D%20%3CWRN%3E%20i3c_mcux%3A%20Timeout%20on%20emit%20stop%2C%20retrying%0A%5B00%3A38%3A33.648%2C417%5D%20%3CERR%3E%20i3c_mcux%3A%20Tried%20to%20emit%20stop%2010000times..clearing%20all!%20MCTRL%200x00000002%20MSTATUS%200x00001003%20MERRWARN%200x00000000%20MIBIRULES%200x00000000%3C%2FERR%3E%3C%2FWRN%3E%3C%2FWRN%3E%3C%2FERR%3E%3C%2FERR%3E%3C%2FWRN%3E%3C%2FERR%3E%3C%2FINF%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%E3%83%90%E3%82%B9%E3%81%8C%E6%AD%BB%E3%81%AC%E3%81%A8%E3%81%8D%E3%81%AE%E3%83%97%E3%83%AD%E3%83%83%E3%83%88%E3%81%A7%E3%81%99(%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AF%E6%B0%B8%E9%81%A0%E3%81%AB%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%AE%9A%E5%B8%B8%E7%8A%B6%E6%85%8B%E3%81%A7%E3%81%99%E3%80%82SDA%20Low%20%E3%81%8A%E3%82%88%E3%81%B3%20SCL%20High)%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22galenc_0-1742937195999.png%22%20style%3D%22width%3A%20783px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22galenc_0-1742937195999.png%22%20style%3D%22width%3A%20783px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F329708i6EE41DF96F4ED553%2Fimage-dimensions%2F783x124%3Fv%3Dv2%22%20width%3D%22783%22%20height%3D%22124%22%20role%3D%22button%22%20title%3D%22galenc_0-1742937195999.png%22%20alt%3D%22galenc_0-1742937195999.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2068007%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AZephyr%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9FRT685%20i3c%E3%83%9D%E3%83%BC%E3%83%88%20-%20i2c%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E6%95%B0%E5%88%86%E3%81%AE%E4%BD%BF%E7%94%A8%E5%BE%8C%E3%81%AB%E6%AD%BB%E4%BA%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2068007%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%AB%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%E6%9B%B4%E6%96%B0%E5%BE%8C%E3%81%AE%E9%80%9A%E7%9F%A5%E3%81%8COutlook%E3%81%AB%E8%BB%A2%E9%80%81%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8B%E7%90%86%E7%94%B1%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81EIO%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E4%BD%BF%E7%94%A8%E3%82%92%E6%9C%80%E5%B0%8F%E9%99%90%E3%81%AB%E6%8A%91%E3%81%88%E3%80%81GPIO%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%80%81%E3%81%A9%E3%81%A1%E3%82%89%E3%82%92%E3%82%88%E3%82%8A%E4%BF%A1%E9%A0%BC%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%82%92%E9%98%B2%E3%81%90%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%E9%9A%9C%E5%AE%B3%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E5%AE%89%E5%AE%9A%E6%80%A7%E3%81%8C%E7%A2%BA%E5%AE%9F%E3%81%AB%E5%90%91%E4%B8%8A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%B8%80%E6%96%B9%E3%80%81%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AEI2C%E3%81%8C%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B9%E3%83%88%E3%83%AC%E3%83%83%E3%83%81%E3%82%92%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%81%A6%E3%80%81EmitStop()%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%82%82%E8%88%88%E5%91%B3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3ERT68x%E3%81%A7%E3%81%AF%E3%80%81I3C%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%81%A7%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B9%E3%83%88%E3%83%AC%E3%83%83%E3%83%81%E3%81%8C%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%82%8C%E3%81%8CI2C%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%AE%E5%88%B6%E9%99%90%E3%81%AE1%E3%81%A4%E3%81%A7%E3%81%99%E3%80%82I3C%E3%81%AE%E7%AB%A0%E3%81%AE%E5%86%92%E9%A0%AD%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82I2C%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B9%E3%83%88%E3%83%AC%E3%83%83%E3%83%81%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E5%90%8C%E6%A7%98%E3%81%AE%E6%8A%95%E7%A8%BF%E3%82%92%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E8%A6%8B%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMCX-Microcontrollers%2FI3C-timeout-due-to-target-clock-stretching%2Ftd-p%2F1933964%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMCX-Microcontrollers%2FI3C-timeout-due-to-target-clock-stretching%2Ftd-p%2F1933964%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81I2C%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%A8%E9%80%9A%E4%BF%A1%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%20I2C%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%BE%E3%81%A7%E3%80%81%E3%83%90%E3%82%B9%E3%81%AB%E3%80%8C%E3%83%87%E3%83%83%E3%83%89%E3%80%8DI2C%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%8C%E3%81%82%E3%82%8B%E3%81%9F%E3%81%B3%E3%81%AB%E3%80%81SCL%E3%82%92GPIO%E3%83%94%E3%83%B3%E3%81%AB%E6%A7%8B%E6%88%90%E3%81%97%E3%80%81~20%E5%9B%9E%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%80%81%E3%83%90%E3%82%B9%E3%81%8C%E3%82%A2%E3%82%A4%E3%83%89%E3%83%AB%E3%81%AB%E6%88%BB%E3%81%A3%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8B%E3%82%89%E3%80%81%E3%83%94%E3%83%B3%E3%82%92SCL%E6%A9%9F%E8%83%BD%E3%81%AB%E6%88%BB%E3%81%99%E3%81%AA%E3%81%A9%E3%80%81%E3%83%90%E3%82%B9%E3%83%AA%E3%82%AB%E3%83%90%E3%83%AA%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E3%82%82%E5%AE%9F%E8%A3%85%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2067901%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AZephyr%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9FRT685%20i3c%E3%83%9D%E3%83%BC%E3%83%88%20-%20i2c%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E6%95%B0%E5%88%86%E3%81%AE%E4%BD%BF%E7%94%A8%E5%BE%8C%E3%81%AB%E6%AD%BB%E4%BA%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2067901%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F84797%22%20target%3D%22_blank%22%3E%40Dezheng_Tang%3C%2FA%3E%20%E3%81%AF%E3%81%84%E3%80%81irq_lock()%E3%81%AF%E3%80%81%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%2F%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%82%92%E3%83%A9%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%E3%81%A8%E3%81%86%E3%81%BE%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B6%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E9%80%94%E4%B8%AD%E3%81%A7%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%81%AE%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%81%AE%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82mcux_i3c_do_one_xfer()%E3%81%AE%E5%A4%A7%E9%83%A8%E5%88%86%E3%82%92%E3%83%A9%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F(%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%82%E3%80%81%E5%81%9C%E6%AD%A2%E3%82%92%E7%99%BA%E3%81%99%E3%82%8B%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99)%E3%80%82FIFO%E3%81%8B%E3%82%89%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB~70uS%E3%81%97%E3%81%8B%E3%81%8B%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AB~250uS%E3%81%AE%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%80%81%E7%A7%81%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%81%AE%E6%AE%8B%E3%82%8A%E3%81%AE%E9%83%A8%E5%88%86%E3%81%A7%E5%8F%97%E3%81%91%E5%85%A5%E3%82%8C%E3%82%89%E3%82%8C%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%81%9D%E3%81%93%E3%81%A7%E3%81%95%E3%82%89%E3%81%AB%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E8%A1%8C%E3%81%86%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22galenc_0-1742916351117.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22galenc_0-1742916351117.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F329653iC997D9EA497D4D9E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22galenc_0-1742916351117.png%22%20alt%3D%22galenc_0-1742916351117.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%8C%E5%BE%97%E3%81%A6%E3%81%84%E3%81%9FEIO%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AFmcux_i3c_error_is_timeout()%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%95%E3%81%AA%E3%81%84%E5%A0%B4%E6%89%80%E3%81%A7%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%A7%E3%82%82%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%99%BA%E8%A6%8B%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82I3C%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AF%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%A7%E3%82%82%E3%80%81%E3%81%93%E3%82%8C%E3%82%92%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%A8%E5%91%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82FIFO%20%E3%81%AB%E6%AD%A3%E3%81%97%E3%81%84%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%A7%E3%82%82%E3%80%81MERRWARN%20%3D%200x00100000%20(%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88)%20%E3%81%AF%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E7%84%A1%E8%A6%96%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A8%E4%BF%A1%E3%81%98%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99(%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B6%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E6%9C%9F%E9%96%93%E5%85%A8%E4%BD%93%E3%81%AB%E3%82%8F%E3%81%9F%E3%81%A3%E3%81%A6irq_lock%E3%81%A8%E4%B8%80%E7%B7%92%E3%81%AB%E6%9A%AE%E3%82%89%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99)%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E9%96%8B%E3%81%84%E3%81%A6%E3%81%84%E3%82%8B%E9%A0%85%E7%9B%AE%E3%81%AF%E3%80%81%E3%80%8C%E5%81%9C%E6%AD%A2%E3%82%92%E6%94%BE%E5%87%BA%E3%81%99%E3%82%8B%E3%80%8D%E3%81%A8%E3%81%8D%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%81%9D%E3%82%8C%E3%81%8C%E5%8E%9F%E5%9B%A0%E3%81%A7%E3%83%90%E3%82%B9%E3%81%8C%E5%AE%8C%E5%85%A8%E3%81%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%8D%E3%80%81%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AF%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%81%BE%E3%81%A7%E3%81%AB%E6%95%B0%E6%99%82%E9%96%93%E3%81%8B%E3%81%8B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E4%BB%8A%E6%97%A5%E3%81%AF%E3%81%BE%E3%81%A0%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E7%9B%A3%E8%A6%96%E3%82%92%E7%B6%9A%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%81%8C%E3%81%BE%E3%81%A0%E8%B5%B7%E3%81%93%E3%82%8B%E5%8E%9F%E5%9B%A0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E4%BD%95%E3%81%8B%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%82%92%E9%98%B2%E3%81%90%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%E3%81%9D%E3%81%AE%E9%9A%9C%E5%AE%B3%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E5%AE%89%E5%AE%9A%E6%80%A7%E3%82%82%E5%90%91%E4%B8%8A%E3%81%99%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2067464%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AZephyr%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9FRT685%20i3c%E3%83%9D%E3%83%BC%E3%83%88%20-%20i2c%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E6%95%B0%E5%88%86%E3%81%AE%E4%BD%BF%E7%94%A8%E5%BE%8C%E3%81%AB%E6%AD%BB%E4%BA%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2067464%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%81%AE%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%82%8F%E3%82%8C%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81irq_lock()%E3%82%84irq_unlock()%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E9%87%8D%E8%A6%81%E3%81%AA%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E4%BF%9D%E8%AD%B7%E3%81%97%E3%80%81%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%A8%E3%82%82%E6%94%B9%E5%96%84%E3%81%95%E3%82%8C%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2067449%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AZephyr%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9FRT685%20i3c%E3%83%9D%E3%83%BC%E3%83%88%20-%20i2c%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E6%95%B0%E5%88%86%E3%81%AE%E4%BD%BF%E7%94%A8%E5%BE%8C%E3%81%AB%E6%AD%BB%E4%BA%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2067449%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E6%8F%90%E6%A1%88%E3%81%A9%E3%81%8A%E3%82%8A%E3%81%AB%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E5%87%BA%E5%8A%9B%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F84797%22%20target%3D%22_blank%22%3E%40Dezheng_Tang%3C%2FA%3E%20%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E8%A9%A6%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%9F%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AB%203%20%E7%95%AA%E7%9B%AE%E3%81%AE%20GPIO%20%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Estatic%20int%20mcux_i3c_do_one_xfer_read(I3C_Type%20*base%2C%20uint8_t%20*buf%2C%20uint8_t%20buf_sz%2C%20bool%20ibi)%0A%7B%0A%09int%20ret%20%3D%200%3B%0A%09int%20offset%20%3D%200%3B%0A%09%0A%09while%20(offset%20%26lt%3B%20buf_sz)%20%7B%0A%09%09%2F*%0A%09%09%20*%20Transfer%20data%20from%20FIFO%20into%20buffer.%20Read%0A%09%09%20*%20in%20a%20tight%20loop%20to%20reduce%20chance%20of%20losing%0A%09%09%20*%20FIFO%20data%20when%20the%20i3c%20speed%20is%20high.%0A%09%09%20*%2F%0A%09%09while%20(offset%20%26lt%3B%20buf_sz)%20%7B%0A%09%09%09gpio_pin_set_dt(%26amp%3Bdbg_2%2C%201)%3B%0A%09%09%09if%20(mcux_i3c_fifo_rx_count_get(base)%20%3D%3D%200)%20%7B%0A%09%09%09%09gpio_pin_set_dt(%26amp%3Bdbg_2%2C%200)%3B%0A%09%09%09%09break%3B%0A%09%09%09%7D%0A%09%09%09gpio_pin_set_dt(%26amp%3Bdbg_1%2C%201)%3B%0A%09%09%09buf%5Boffset%2B%2B%5D%20%3D%20(uint8_t)base-%26gt%3BMRDATAB%3B%0A%09%09%09gpio_pin_set_dt(%26amp%3Bdbg_1%2C%200)%3B%0A%09%09%7D%0A%09%09%2F*%0A%09%09%20*%20If%20controller%20says%20timed%20out%2C%20we%20abort%20the%20transaction.%0A%09%09%20*%2F%0A%09%09if%20(mcux_i3c_has_error(base))%20%7B%0A%09%09%09if%20(mcux_i3c_error_is_timeout(base))%20%7B%0A%09%09%09%09gpio_pin_set_dt(%26amp%3Bdbg_0%2C%201)%3B%0A%09%09%09%09LOG_WRN(%22Flushing%20fifo%20due%20to%20timeout%20offset%3D%25d%2C%20buf_sz%3D%25d%22%2C%20offset%2C%20buf_sz)%3B%0A%09%09%09%09mcux_i3c_fifo_flush(base)%3B%20%2F%2Fnxp%20succestion%20to%20add%0A%09%09%09%09ret%20%3D%20-ETIMEDOUT%3B%0A%09%09%09%09gpio_pin_set_dt(%26amp%3Bdbg_0%2C%200)%3B%0A%09%09%09%7D%0A%09%09%09%2F*%20clear%20error%20%20*%2F%0A%09%09%09base-%26gt%3BMERRWARN%20%3D%20base-%26gt%3BMERRWARN%3B%0A%0A%09%09%09%2F*%20for%20ibi%2C%20ignore%20timeout%20err%20if%20any%20bytes%20were%0A%09%09%09%20*%20read%2C%20since%20the%20code%20doesn't%20know%20how%20many%0A%09%09%09%20*%20bytes%20will%20be%20sent%20by%20device.%20for%20regular%0A%09%09%09%20*%20application%20read%20request%2C%20return%20err%20always.%0A%09%09%09%20*%2F%0A%09%09%09if%20((ret%20%3D%3D%20-ETIMEDOUT)%20%26amp%3B%26amp%3B%20ibi%20%26amp%3B%26amp%3B%20offset)%20%7B%0A%09%09%09%09break%3B%0A%09%09%09%7D%20else%20%7B%0A%09%09%09%09if%20(ret%20%3D%3D%20-ETIMEDOUT)%20%7B%0A%09%09%09%09%09LOG_ERR(%22Timeout%20error%22)%3B%0A%09%09%09%09%7D%0A%09%09%09%09goto%20one_xfer_read_out%3B%0A%09%09%09%7D%0A%09%09%7D%0A%09%7D%0A%0A%09ret%20%3D%20offset%3B%0A%0Aone_xfer_read_out%3A%0A%09gpio_pin_set_dt(%26amp%3Bdbg_2%2C%200)%3B%0A%09return%20ret%3B%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%80%81%E8%89%AF%E3%81%84%E8%AA%AD%E3%81%BF%E7%89%A9%E3%82%92%E3%81%94%E7%B4%B9%E4%BB%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22good%20read%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22good%20read%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F329554iC36C853EBA3F04CA%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22good_read.png%22%20alt%3D%22good%20read%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Egood%20read%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E8%89%AF%E3%81%84%E8%AA%AD%E3%81%BF%E7%89%A9%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C%E5%AE%9F%E9%9A%9B%E3%81%AB%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%89%E3%82%8C%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22timeout%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22timeout%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F329555i54EB2F836C8F234A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22timeout_read.png%22%20alt%3D%22timeout%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Etimeout%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%AF%E3%80%810%20%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E5%AE%9F%E9%9A%9B%E3%81%AB%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%201%20%E3%81%8C%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%89%E3%82%8C%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E4%B8%A1%E6%96%B9%E3%81%8C%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%89%E3%82%8C%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AB%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E3%81%9D%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%8CFIFO%E3%81%8B%E3%82%89%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%AE%E3%81%AB%E6%99%82%E9%96%93%E3%81%8C%E3%81%8B%E3%81%8B%E3%82%8A%E3%81%99%E3%81%8E%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%80%81%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8Fzephyr%E3%81%8B%E3%82%89%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%83%90%E3%82%B9%E3%82%92%E9%99%8D%E3%82%8D%E3%81%99%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E3%81%BE%E3%81%A0%E3%82%AD%E3%83%A3%E3%83%83%E3%83%81%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2056421%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AZephyr%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9FRT685%20i3c%E3%83%9D%E3%83%BC%E3%83%88%20-%20i2c%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E6%95%B0%E5%88%86%E3%81%AE%E4%BD%BF%E7%94%A8%E5%BE%8C%E3%81%AB%E6%AD%BB%E4%BA%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2056421%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%AF%E3%81%84%E3%80%81%E3%81%93%E3%82%8C%E3%81%8C%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%AB%E9%81%A9%E3%81%97%E3%81%9F%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E5%90%8C%E6%84%8F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%92%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%E3%81%93%E3%82%8C%E3%81%8B%E3%82%892%E9%80%B1%E9%96%93(%E6%98%8E%E6%97%A5%E3%81%8B%E3%82%89)%E6%97%85%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E6%88%BB%E3%81%A3%E3%81%9F%E3%82%89%E7%B5%90%E6%9E%9C%E3%82%92%E5%A0%B1%E5%91%8A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E5%BC%95%E3%81%8D%E7%B6%9A%E3%81%8D%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2055786%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AZephyr%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9FRT685%20i3c%E3%83%9D%E3%83%BC%E3%83%88%20-%20i2c%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E6%95%B0%E5%88%86%E3%81%AE%E4%BD%BF%E7%94%A8%E5%BE%8C%E3%81%AB%E6%AD%BB%E4%BA%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2055786%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%ABLOG_DBG%E3%81%BE%E3%81%9F%E3%81%AFLOG_ERR%E3%83%97%E3%83%AA%E3%83%B3%E3%83%88%E3%82%A2%E3%82%A6%E3%83%88%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%ABgpio%E3%83%88%E3%82%B0%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3EGPIO1%E3%81%AFMSTATUS%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E6%99%82%E3%81%AB%E3%83%88%E3%82%B0%E3%83%AB%E3%81%97%E3%80%81%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%8B%E3%82%89MRDATAB%E3%81%8C%E8%AA%AD%E3%81%BF%E5%87%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%81%A8GPIO2%E3%81%8C%E5%88%87%E3%82%8A%E6%9B%BF%E3%82%8F%E3%82%8A%E3%80%81GPIO1%E3%81%AE%E3%82%A8%E3%83%83%E3%82%B8%E3%81%A7%E3%83%88%E3%83%AA%E3%82%AC%E3%81%A7%E3%81%8D%E3%80%81I2C%20SCL%E3%81%A8GPIO2%E3%81%AFSCL%E3%81%AE%E7%AB%8B%E3%81%A1%E4%B8%8B%E3%81%8C%E3%82%8A%E3%82%A8%E3%83%83%E3%82%B8%E3%81%A7%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%89%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%86%E3%81%BE%E3%81%8F%E5%90%8C%E6%9C%9F%E3%81%95%E3%81%9B%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3ESCL%20%E3%81%8C%20Low%20%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%9F%E5%BE%8C%E3%81%AB%20MRDATAB%20%E3%81%A7%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%89%E3%82%8C%E3%81%AA%E3%81%84%E9%95%B7%E3%81%84%E9%81%85%E5%BB%B6%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2055051%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AZephyr%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9FRT685%20i3c%E3%83%9D%E3%83%BC%E3%83%88%20-%20i2c%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E6%95%B0%E5%88%86%E3%81%AE%E4%BD%BF%E7%94%A8%E5%BE%8C%E3%81%AB%E6%AD%BB%E4%BA%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2055051%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EZephyr%20OS%E3%81%8C%E5%95%8F%E9%A1%8C%E3%82%92%E5%BC%95%E3%81%8D%E8%B5%B7%E3%81%93%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%A7%E5%95%8F%E9%A1%8C%E3%82%92%E5%88%87%E3%82%8A%E5%88%86%E3%81%91%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%80%81I3C%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6I2C%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%89%E3%82%A2%E3%83%AD%E3%83%B3%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82RT685%20EVK%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81I3C%E3%83%90%E3%82%B9%E3%81%AB%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AFWM8904%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E9%96%A2%E9%80%A3%E3%81%AESDK%E3%81%AE%E4%BE%8B%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%93%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%81%AFI3C%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC(I2C%E7%B5%8C%E7%94%B1)%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%92%E5%AE%9A%E6%9C%9F%E7%9A%84%E3%81%AB%E8%A1%8C%E3%81%86%E3%81%9F%E3%82%81%E3%81%AB%E3%83%9E%E3%82%A4%E3%83%8A%E3%83%BC%E3%81%AA%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%80%81%E3%83%90%E3%82%B9%E3%82%92%E7%9B%A3%E8%A6%96%E3%81%97%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E6%9D%A1%E4%BB%B6%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%81%AB%E5%BC%B7%E5%88%B6%E3%81%97%E3%81%AA%E3%81%84%E9%99%90%E3%82%8A%E3%80%81%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82I3C%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%81%AF%E3%80%81STALL%E6%9C%9F%E9%96%93%E3%81%8C100us%26gt%3B%E3%81%AA%E3%81%84%E9%99%90%E3%82%8A%E3%80%81%E7%B0%A1%E5%8D%98%E3%81%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%20%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%82%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E5%86%85%E3%81%A7%E9%95%B7%E6%99%82%E9%96%93%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AB%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E2%80%A2%20TX%20FIFO%20%E3%81%BE%E3%81%9F%E3%81%AF%20RX%20FIFO%20%E3%81%8C%E5%87%A6%E7%90%86%E3%81%95%E3%82%8C%E3%81%9A%E3%80%81%E3%83%90%E3%82%B9%E3%81%8C%20%3CBR%20%2F%3E%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%3CBR%20%2F%3E%E2%80%A2%20STOP%E3%81%8C%E7%99%BA%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%96%93%E3%81%A7%E3%80%81%3CBR%20%2F%3E%E2%80%A2IBI%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81%E6%B1%BA%E5%AE%9A%E3%81%8C%E4%B8%8B%E3%81%95%E3%82%8C%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%82%3CBR%20%2F%3E%E6%9C%80%E5%A4%A7%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E6%9C%9F%E9%96%93%E3%81%AF10kHz%E3%81%BE%E3%81%9F%E3%81%AF100us%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%90%E3%82%B9%E3%83%AA%E3%82%AB%E3%83%90%E3%83%AA%E3%83%BC%E3%82%92%E3%81%A9%E3%81%AE%E3%81%8F%E3%82%89%E3%81%84%E3%81%AE%E9%A0%BB%E5%BA%A6%E3%81%A7%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E3%81%B9%E3%81%8D%E3%81%8B%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%82%92%E8%A8%88%E3%82%8B%E3%81%AE%E3%81%AF%E9%9B%A3%E3%81%97%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%91%E3%81%B0%E3%80%81%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%8C%E9%A0%BB%E7%B9%81%E3%81%AB%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E7%90%86%E7%94%B1%E3%82%92%E6%9C%80%E5%88%9D%E3%81%AB%E8%AA%BF%E6%9F%BB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3EIO%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81MCTRL%E3%81%A8MSTATUS%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%80%81%E5%AE%8C%E4%BA%86%E3%83%93%E3%83%83%E3%83%88%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%8F%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%5B00%3A24%3A52.345%2C217%5D%20%3CDBG%3E%20i3c_mcux%3A%20mcux_i3c_has_error%3A%20ERROR%3A%20MCTRL%200x0000d250%20MSTATUS%200x00009403%20MERRWARN%200x00100000%3C%2FDBG%3E%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2054034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AZephyr%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9FRT685%20i3c%E3%83%9D%E3%83%BC%E3%83%88%20-%20i2c%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E6%95%B0%E5%88%86%E3%81%AE%E4%BD%BF%E7%94%A8%E5%BE%8C%E3%81%AB%E6%AD%BB%E4%BA%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2054034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AF%E8%80%83%E6%85%AE%E3%81%99%E3%81%B9%E3%81%8D%E6%9C%89%E7%94%A8%E3%81%AA%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AB%E7%AD%94%E3%81%88%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%3A%3CBR%20%2F%3E1)%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%99%E3%82%8B%E3%81%9F%E3%81%B3%E3%81%AB%E3%81%9D%E3%81%AE%E8%A1%8C%E3%81%8C%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%80%81%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E8%A6%81%E6%B1%82%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%20'mcux_i3c_do_one_xfer()%20%E3%81%AE%201%20%E5%9B%9E%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%A7%203%20%E5%9B%9E%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E2)%E3%81%93%E3%82%8C%E3%82%92%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3CBR%20%2F%3E3)%E7%A7%81%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%20'mcux_i3c_recover_bus()'%E3%81%A7%E5%AE%9F%E8%A3%85%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20-%20%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AB%E3%80%8110%E5%80%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E9%80%A3%E7%B6%9A%E3%81%97%E3%81%A6(%E6%88%90%E5%8A%9F%E3%81%9B%E3%81%9A%E3%81%AB)%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E8%B5%B7%E3%81%93%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9F%E3%81%B6%E3%82%93%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E5%91%BC%E3%81%B6%E3%81%AE%E3%81%AB%E3%82%82%E3%81%A3%E3%81%A8%E8%89%AF%E3%81%84%E6%99%82%E6%9C%9F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3E4)%20%26amp%3B%205)%20%E3%81%93%E3%82%8C%E3%82%89%E3%81%AF%E8%88%88%E5%91%B3%E6%B7%B1%E3%81%84%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%A7%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E3%82%82%E3%81%86%E5%B0%91%E3%81%97%E3%83%AD%E3%82%B0%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%80%81%E3%81%93%E3%82%8C%E3%82%92%E3%82%88%E3%82%8A%E3%82%88%E3%81%8F%E7%90%86%E8%A7%A3%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%81%93%E3%81%A8%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E8%BB%A2%E9%80%81%E4%B8%AD%E3%81%AB%E5%84%AA%E5%85%88%E5%BA%A6%E3%81%AE%E9%AB%98%E3%81%84%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%81%8C%E3%82%B3%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%81%8C%E5%88%87%E3%82%8A%E6%9B%BF%E3%82%8F%E3%82%8A%E3%80%81%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E8%80%83%E3%81%88%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81%E4%B8%80%E9%83%A8%E3%81%AE%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%92%E8%AA%BF%E6%95%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%AF%E5%AE%9A%E6%9C%9F%E7%9A%84%E3%81%AB%E7%99%BA%E7%94%9F%E3%81%97%E3%80%81%E3%81%93%E3%81%AE%E3%83%90%E3%82%B9%E3%81%AF%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%A7%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%82%8C%E3%82%92%E6%AF%94%E8%BC%83%E7%9A%84%E4%BD%8E%E3%81%84%E5%84%AA%E5%85%88%E5%BA%A6%E3%81%AB%E4%BF%9D%E3%81%A4%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3EIO%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%82%E6%99%82%E3%80%85%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E3%81%A5%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%86%8D%E3%81%B3%E5%BD%BC%E3%82%89%E3%81%AF%E5%9B%9E%E5%BE%A9%E3%81%97%E3%81%A6%E5%85%88%E3%81%AB%E9%80%B2%E3%81%BF%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%90%E3%82%B9%E3%81%8C%E3%82%AF%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%9F%E3%81%AE%E3%81%AF%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%AE%E6%99%82%E9%96%93%E3%81%A0%E3%81%91%E3%81%A7%E5%AE%8C%E5%85%A8%E3%81%AB%E6%AD%BB%E3%81%AB%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%5B00%3A24%3A52.345%2C217%5D%20%3CDBG%3E%20i3c_mcux%3A%20mcux_i3c_has_error%3A%20ERROR%3A%20MCTRL%200x0000d250%20MSTATUS%200x00009403%20MERRWARN%200x00100000%0A%5B00%3A24%3A52.345%2C228%5D%20%3CDBG%3E%20i3c_mcux%3A%20mcux_i3c_has_error%3A%20ERROR%3A%20MCTRL%200x0000d250%20MSTATUS%200x00009403%20MERRWARN%200x00100000%0A%5B00%3A24%3A52.345%2C249%5D%20%3CERR%3E%20mp2651%3A%20failed%20to%20read%20CONFIG_REGISTER_2%20err%3D-5%0A%5B00%3A24%3A52.345%2C256%5D%20%3CERR%3E%20charger%3A%20error%20with%20battery%20data.%20recover%20count%20%3D%201%3C%2FERR%3E%3C%2FERR%3E%3C%2FDBG%3E%3C%2FDBG%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2053335%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AZephyr%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9FRT685%20i3c%E3%83%9D%E3%83%BC%E3%83%88%20-%20i2c%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E6%95%B0%E5%88%86%E3%81%AE%E4%BD%BF%E7%94%A8%E5%BE%8C%E3%81%AB%E6%AD%BB%E4%BA%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2053335%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E8%A8%82%E6%AD%A3%3A%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%83%93%E3%83%83%E3%83%88%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%A6%E3%82%82%E3%83%90%E3%82%B9%E3%81%8C%E6%AD%BB%E3%81%AC%E3%81%A8%E3%81%AF%E6%80%9D%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2053333%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AZephyr%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9FRT685%20i3c%E3%83%9D%E3%83%BC%E3%83%88%20-%20i2c%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E6%95%B0%E5%88%86%E3%81%AE%E4%BD%BF%E7%94%A8%E5%BE%8C%E3%81%AB%E6%AD%BB%E4%BA%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2053333%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CPRE%20class%3D%22lia-code-sample%20%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%5B00%3A07%3A29.338%2C707%5D%20%3CDBG%3E%20i3c_mcux%3A%20mcux_i3c_has_error%3A%20ERROR%3A%20MCTRL%200x0002d350%20MSTATUS%200x00009003%20MERRWARN%200x00100000%0A%5B00%3A07%3A29.338%2C719%5D%20%3CDBG%3E%20i3c_mcux%3A%20mcux_i3c_has_error%3A%20ERROR%3A%20MCTRL%200x0002d350%20MSTATUS%200x00009003%20MERRWARN%200x00100000%0A%5B00%3A07%3A29.338%2C723%5D%20%3CDBG%3E%20i3c_mcux%3A%20mcux_i3c_has_error%3A%20ERROR%3A%20MCTRL%200x0002d350%20MSTATUS%200x00009003%20MERRWARN%200x00100000%0A%5B00%3A07%3A29.338%2C729%5D%20%3CERR%3E%20i3c_mcux%3A%20Timeout%20error%3C%2FERR%3E%3C%2FDBG%3E%3C%2FDBG%3E%3C%2FDBG%3E%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%3CSPAN%3E%E3%82%BC%E3%83%95%E3%82%A1%E3%83%BC%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E8%A6%97%E3%81%8D%E8%BE%BC%E3%82%80%E3%81%A8%E3%80%81%E3%81%9D%E3%81%AE%E5%86%85%E9%83%A8%E3%81%AF%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%2F*%3CBR%20%2F%3E*%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%A8%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B6%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E4%B8%AD%E6%AD%A2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%2F%3CBR%20%2F%3Eif%20(mcux_i3c_has_error(%E3%83%99%E3%83%BC%E3%82%B9))%20%7B%3CBR%20%2F%3Eif%20(mcux_i3c_error_is_timeout(%E3%83%99%E3%83%BC%E3%82%B9))%20%7B%3CBR%20%2F%3Eret%20%3D%20-ETIMEDOUT%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%2F*%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E3%82%AF%E3%83%AA%E3%82%A2%20*%2F%3CBR%20%2F%3Ebase-%26gt%3BMERRWARN%20%3D%20base-%26gt%3BMERRWARN%3B%3C%2FP%3E%0A%3CP%3E%2F*%20IBI%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%20err%20%E3%82%92%E7%84%A1%E8%A6%96%E3%81%99%E3%82%8B%3CBR%20%2F%3E*%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E3%81%84%E3%81%8F%E3%81%A4%E3%81%82%E3%82%8B%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%99%3CBR%20%2F%3E*%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%94%E3%81%A8%E3%81%AB%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%A9%E3%83%BC%E5%90%91%E3%81%91%3CBR%20%2F%3E*%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E8%A6%81%E6%B1%82%E3%81%AF%E3%80%81%E5%B8%B8%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%2F%3CBR%20%2F%3Eif%20((ret%20%3D%3D%20-ETIMEDOUT)%20%26amp%3B%26amp%3B%20ibi%20%26amp%3B%20offset)%20%7B%3CBR%20%2F%3E%E5%A3%8A%E3%81%99%3B%3CBR%20%2F%3E%7D%20%E3%81%9D%E3%81%AE%E4%BB%96%20%7B%3CBR%20%2F%3Eif%20(ret%20%3D%3D%20-ETIMEDOUT)%20%7B%3CBR%20%2F%3ELOG_ERR(%22%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%82%A8%E3%83%A9%E3%83%BC%22)%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%E5%BE%8C%E8%97%A4one_xfer_read_out%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%7D%3C%2FP%3E%0A%3CP%3E%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E(1)%20%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89%E3%80%81dbg%20msg%E3%81%8C%E5%87%BAmcux_i3c_has_error%E3%80%81%E3%81%99%E3%81%90%E3%81%AB%E3%80%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%8D%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82dbg%20msg%E3%81%8C3%E5%9B%9E%E5%87%BA%E3%81%A6%E3%80%81%E6%9C%80%E5%BE%8C%E3%81%AB%E3%80%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%8D%E3%81%8C%E5%87%BA%E3%82%8B%E3%81%AE%E3%81%AF%E3%81%AA%E3%81%9C%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E(2)%20MERRWARN%E3%81%ABTIMEOUT%E3%83%93%E3%83%83%E3%83%88%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81mcux_i3c_fifo_flush()%E3%82%92%E8%A1%8C%E3%81%86%E3%81%B9%E3%81%8D%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E4%BB%A5%E5%A4%96%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E4%B8%8B%E3%81%AE%E8%A1%8C%E3%81%AF%E5%95%8F%E9%A1%8C%E3%82%92%E9%9A%A0%E3%81%99%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%2F*%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E3%82%AF%E3%83%AA%E3%82%A2%20*%2F%3CBR%20%2F%3Ebase-%26gt%3BMERRWARN%20%3D%20base-%26gt%3BMERRWARN%3B%3C%2FP%3E%0A%3CP%3E(3)%20%3CSPAN%3Emcux_i3c_xfer_reset()%20%E3%81%AF%E3%80%81%E3%83%90%E3%82%B9%E3%82%92%20IDLE%20%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E4%BD%95%E3%82%82%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82mcux_i3c_recover_bus()%20%E3%81%AF%E3%80%81%E3%83%90%E3%82%B9%E3%82%92%20idle%20%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E9%81%A9%E3%81%97%E3%81%9F%20API%20%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%99%E3%80%82mcux_i3c_fifo_rx_drain()%E3%81%A8mcux_i3c_fifo_flush()%E3%81%AE%E4%B8%A1%E6%96%B9%E3%82%92%E3%83%90%E3%82%B9%E3%83%AA%E3%82%AB%E3%83%90%E3%83%AAAPI%E5%86%85%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E(4)%E3%81%AA%E3%81%9C%E6%95%B0%E5%88%86%E3%81%8A%E3%81%8D%E3%81%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%81%AE%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%83%93%E3%83%83%E3%83%88%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%83%90%E3%82%B9%E3%81%8C%E6%AD%BB%E3%81%AC%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%AE%E3%82%B9%E3%83%86%E3%83%BC%E3%83%88%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%81%93%E3%81%AE%E3%83%93%E3%83%83%E3%83%88%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9F%E5%BE%8C%E3%81%AEFIFO%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E5%87%A6%E7%90%86%E6%96%B9%E6%B3%95%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%AA%E3%82%AB%E3%83%90%E3%83%AA%E3%83%BC%E3%83%A1%E3%82%AB%E3%83%8B%E3%82%BA%E3%83%A0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%80%83%E3%81%88%E3%82%8B%E5%89%8D%E3%81%AB%E3%80%81%E3%81%AA%E3%81%9C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%81%AE%E3%81%8B%E3%82%92%E7%90%86%E8%A7%A3%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E(5)mcux_i3c_transfer()%E5%86%85%E3%81%A7%E3%80%81%E3%81%93%E3%81%93%E3%81%A7OS%E3%81%8C%E4%B8%8D%E8%B6%B3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%20%3C%2FSPAN%3E%3CSPAN%3EI3C%E8%BB%A2%E9%80%81%E3%82%92%E8%A1%8C%E3%81%86%E5%A0%B4%E5%90%88%E3%80%81%E3%83%9F%E3%83%A5%E3%83%BC%E3%83%86%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%90%E3%82%B9%E3%81%AF%E3%82%A2%E3%82%A4%E3%83%89%E3%83%AB%E7%8A%B6%E6%85%8B%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82mcux_i3c_wait_idle()%E3%81%AF%E3%83%9D%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%82%88%E3%81%AD%3F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3Ek_mutex_lock(%26amp%3Bdev_data-%26gt%3B%E3%83%AD%E3%83%83%E3%82%AF%E3%80%81K_FOREVER)%3B%3C%2FP%3E%0A%3CP%3Emcux_i3c_wait_idle(dev_data%E3%80%81%E3%83%99%E3%83%BC%E3%82%B9)%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2053184%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AZephyr%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9FRT685%20i3c%E3%83%9D%E3%83%BC%E3%83%88%20-%20i2c%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E6%95%B0%E5%88%86%E3%81%AE%E4%BD%BF%E7%94%A8%E5%BE%8C%E3%81%AB%E6%AD%BB%E4%BA%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2053184%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%BE%E3%81%82%E3%80%81%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AB%E3%81%AF1%E6%99%82%E9%96%93%E4%BD%95%E5%BA%A6%E3%82%82%E4%BD%95%E5%BA%A6%E3%82%82%E4%BD%95%E5%8D%83%E3%82%82%E3%81%AE%E5%8F%96%E5%BC%95%E3%81%A7%E5%90%8C%E3%81%98%E3%81%93%E3%81%A8%E3%82%92%E3%82%84%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%9C%80%E5%96%84%E3%82%92%E5%B0%BD%E3%81%8F%E3%81%97%E3%81%A6%E3%80%81%E7%A7%81%E3%81%AF%E7%89%A9%E4%BA%8B%E3%82%92%E8%BF%85%E9%80%9F%E3%81%AB%E5%87%A6%E7%90%86%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E4%BF%A1%E3%81%98%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%82%BC%E3%83%95%E3%82%A1%E3%83%BC%E3%81%AB%E3%81%AF%E5%A4%9A%E3%81%8F%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%81%93%E3%81%AE%E6%99%82%E7%82%B9%E3%81%A7%E3%83%90%E3%82%B9%20%3CEM%3E%E3%82%92%E5%9B%9E%E5%BE%A9%E3%81%99%E3%82%8B%3C%2FEM%3E%20%E6%96%B9%E6%B3%95%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E7%A7%81%E3%81%AE%E4%B8%BB%E8%A6%81%E3%81%AA%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%81%AE%E3%82%92%E9%98%B2%E3%81%90%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%E3%80%81%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B6%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%8C%E6%95%B0%E5%88%86%E3%81%94%E3%81%A8%E3%81%AB%E7%99%BA%E7%94%9F%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C%E3%83%90%E3%82%B9%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%A7%E3%81%99%E3%80%82%E7%89%B9%E6%AE%8A%E3%81%AA%E3%82%BF%E3%82%A4%E3%83%97%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E6%9D%A1%E4%BB%B6%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%83%90%E3%82%B9%E3%81%8C%E5%AE%8C%E5%85%A8%E3%81%AB%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%87%A6%E7%90%86%E3%81%97%E3%81%A6%E9%80%9A%E5%B8%B8%E3%81%AE%E5%8B%95%E4%BD%9C%E3%81%AB%E6%88%BB%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%E5%8B%95%E3%81%8B%E3%81%AA%E3%81%8F%E3%81%AA%E3%81%A3%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AB%E3%80%8Cmcux_i3c_xfer_reset()%E3%80%8D%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%8A%B9%E6%9E%9C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%AD%E3%82%B0%E3%81%AF%E5%B0%91%E3%81%97%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E6%9C%80%E5%BE%8C%E3%81%AE%E8%A1%8C%E3%81%AF%E6%B0%B8%E9%81%A0%E3%81%AB%E7%B9%B0%E3%82%8A%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%5B00%3A07%3A29.338%2C707%5D%20%3CDBG%3E%20i3c_mcux%3A%20mcux_i3c_has_error%3A%20ERROR%3A%20MCTRL%200x0002d350%20MSTATUS%200x00009003%20MERRWARN%200x00100000%0A%5B00%3A07%3A29.338%2C719%5D%20%3CDBG%3E%20i3c_mcux%3A%20mcux_i3c_has_error%3A%20ERROR%3A%20MCTRL%200x0002d350%20MSTATUS%200x00009003%20MERRWARN%200x00100000%0A%5B00%3A07%3A29.338%2C723%5D%20%3CDBG%3E%20i3c_mcux%3A%20mcux_i3c_has_error%3A%20ERROR%3A%20MCTRL%200x0002d350%20MSTATUS%200x00009003%20MERRWARN%200x00100000%0A%5B00%3A07%3A29.338%2C729%5D%20%3CERR%3E%20i3c_mcux%3A%20Timeout%20error%0A%5B00%3A07%3A29.464%2C782%5D%20%3CERR%3E%20i3c_mcux%3A%20Tried%20to%20emit%20stop%2010000times..clearing%20all!%20MCTRL%200x00000052%20MSTATUS%200x00001803%20MERRWARN%200x00000000%20MIBIRULES%200x00000000%0A%5B00%3A07%3A30.592%2C655%5D%20%3CERR%3E%20i3c_mcux%3A%20Tried%20to%20emit%20stop%2010000times..clearing%20all!%20MCTRL%200x00000052%20MSTATUS%200x00001003%20MERRWARN%200x00000000%20MIBIRULES%200x00000000%0A%5B00%3A07%3A31.718%2C942%5D%20%3CERR%3E%20i3c_mcux%3A%20Tried%20to%20emit%20stop%2010000times..clearing%20all!%20MCTRL%200x00000052%20MSTATUS%200x00001003%20MERRWARN%200x00000000%20MIBIRULES%200x00000000%0A%5B00%3A07%3A32.846%2C540%5D%20%3CERR%3E%20i3c_mcux%3A%20Tried%20to%20emit%20stop%2010000times..clearing%20all!%20MCTRL%200x00000052%20MSTATUS%200x00001003%20MERRWARN%200x00000000%20MIBIRULES%200x00000000%0A%5B00%3A07%3A33.974%2C438%5D%20%3CERR%3E%20i3c_mcux%3A%20Tried%20to%20emit%20stop%2010000times..clearing%20all!%20MCTRL%200x00000052%20MSTATUS%200x00001003%20MERRWARN%200x00000000%20MIBIRULES%200x00000000%3C%2FERR%3E%3C%2FERR%3E%3C%2FERR%3E%3C%2FERR%3E%3C%2FERR%3E%3C%2FERR%3E%3C%2FDBG%3E%3C%2FDBG%3E%3C%2FDBG%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2052151%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AZephyr%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9FRT685%20i3c%E3%83%9D%E3%83%BC%E3%83%88%20-%20i2c%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E6%95%B0%E5%88%86%E3%81%AE%E4%BD%BF%E7%94%A8%E5%BE%8C%E3%81%AB%E6%AD%BB%E4%BA%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2052151%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI3C%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%81%AFNORMAL%E7%8A%B6%E6%85%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%A7%E3%80%81%E6%A7%8B%E6%88%90%E3%82%82%E5%95%8F%E9%A1%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82MCTRL%E3%81%A8MSTATUS%E3%81%AF%E3%81%A9%E3%81%A1%E3%82%89%E3%82%82%E5%95%8F%E9%A1%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81EMIT%20STOP%E3%82%92%E8%A6%81%E6%B1%82%E3%81%99%E3%82%8B%E5%89%8D%E3%81%A7%E3%82%82TIMEOUT%E3%83%93%E3%83%83%E3%83%88(%E3%83%93%E3%83%83%E3%83%8820)%E3%81%8CMERRWARN%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E7%90%86%E7%94%B1%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81TIMEOUT%20%E3%83%93%E3%83%83%E3%83%88%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AE%E6%9D%A1%E4%BB%B6%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E2%80%A2%20%E9%80%81%E4%BF%A1%20FIFO%20%E3%81%BE%E3%81%9F%E3%81%AF%E5%8F%97%E4%BF%A1%20FIFO%20%E3%81%8C%E5%87%A6%E7%90%86%E3%81%95%E3%82%8C%E3%81%9A%E3%80%81%E3%83%90%E3%82%B9%E3%81%8C%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E9%80%94%E4%B8%AD%E3%81%A7%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E2%80%A2%20%E3%83%87%E3%83%BC%E3%82%BF%E8%BB%A2%E9%80%81%E5%BE%8C%E3%81%ABSTOP%E3%81%8C%E7%99%BA%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84(%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E9%96%93%E3%81%AB%E3%82%AE%E3%83%A3%E3%83%83%E3%83%97%E3%81%8C%E3%81%82%E3%82%8B)%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8CFIFO%E3%81%AB%E4%B8%80%E5%AE%9A%E6%9C%9F%E9%96%93%E5%AD%98%E5%9C%A8%E3%81%97%E3%80%81%E3%81%99%E3%81%90%E3%81%AB%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%89%E3%81%AA%E3%81%84%E3%81%A8%E3%81%84%E3%81%86%E6%9D%A1%E4%BB%B6%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E3%83%90%E3%82%B9%E3%81%8C%E6%95%85%E9%9A%9C%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%82%E3%82%8A%E3%80%81stop%E3%82%92%E5%87%BA%E3%81%99%E5%89%8D%E3%81%A7%E3%82%82%E3%82%A2%E3%82%A4%E3%83%89%E3%83%AB%E7%8A%B6%E6%85%8B%E3%81%AB%E6%88%BB%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AFmcux_i3c_do_request_emit_stop()%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%5B01%3A09%3A10.791%2C063%5D%20%3CDBG%3E%20i3c_mcux%3A%20mcux_i3c_has_error%3A%20ERROR%3A%20MCTRL%200x0002d350%20MSTATUS%200x00009003%20MERRWARN%200x0010000%3C%2FDBG%3E%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2051815%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AZephyr%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9FRT685%20i3c%E3%83%9D%E3%83%BC%E3%83%88%20-%20i2c%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E6%95%B0%E5%88%86%E3%81%AE%E4%BD%BF%E7%94%A8%E5%BE%8C%E3%81%AB%E6%AD%BB%E4%BA%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2051815%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E8%BF%85%E9%80%9F%E3%81%AA%E5%AF%BE%E5%BF%9C%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81%E4%B8%80%E9%83%A8%E3%81%AE%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B6%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E9%9A%9C%E5%AE%B3%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%AA%E3%81%84%E6%96%AD%E7%B6%9A%E7%9A%84%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99(%E5%BF%85%E8%A6%81%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E3%81%9D%E3%82%8C%E3%82%89%E3%82%92%E5%85%B1%E6%9C%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99)%E3%81%8C%E3%80%81%E3%83%90%E3%82%B9%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%99%E3%82%8B%E7%9B%B4%E5%89%8D%E3%81%AB%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E6%AC%A1%E3%81%AB%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%811%20%E6%99%82%E9%96%93%E4%BB%A5%E4%B8%8A%E3%81%AB%E3%82%8F%E3%81%9F%E3%81%A3%E3%81%A6%201%20%E7%A7%92%E3%81%AB%E6%95%B0%E5%9B%9E%E5%91%A8%E8%BE%BA%E6%A9%9F%E5%99%A8%E3%81%A8%E9%80%9A%E4%BF%A1%E3%81%97%E3%81%9F%E5%BE%8C%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%5B01%3A09%3A10.791%2C048%5D%20%3CDBG%3E%20i3c_mcux%3A%20mcux_i3c_has_error%3A%20ERROR%3A%20MCTRL%200x0002d350%20MSTATUS%200x00009003%20MERRWARN%200x00100000%0A%5B01%3A09%3A10.791%2C059%5D%20%3CDBG%3E%20i3c_mcux%3A%20mcux_i3c_has_error%3A%20ERROR%3A%20MCTRL%200x0002d350%20MSTATUS%200x00009003%20MERRWARN%200x00100000%0A%5B01%3A09%3A10.791%2C063%5D%20%3CDBG%3E%20i3c_mcux%3A%20mcux_i3c_has_error%3A%20ERROR%3A%20MCTRL%200x0002d350%20MSTATUS%200x00009003%20MERRWARN%200x00100000%0A%5B01%3A09%3A10.791%2C067%5D%20%3CERR%3E%20i3c_mcux%3A%20Timeout%20error%0A%5B01%3A09%3A10.916%2C786%5D%20%3CERR%3E%20i3c_mcux%3A%20Tried%20to%20emit%20stop%2010000times..clearing%20all!%20MCTRL%200x00000052%20MSTATUS%200x00001003%20MERRWARN%200x00000000%20MIBIRULES%200x00000000%0A%5B01%3A09%3A12.042%2C217%5D%20%3CERR%3E%20i3c_mcux%3A%20Tried%20to%20emit%20stop%2010000times..clearing%20all!%20MCTRL%200x00000052%20MSTATUS%200x00001003%20MERRWARN%200x00000000%20MIBIRULES%200x00000000%0A%5B01%3A09%3A13.169%2C180%5D%20%3CERR%3E%20i3c_mcux%3A%20Tried%20to%20emit%20stop%2010000times..clearing%20all!%20MCTRL%200x00000052%20MSTATUS%200x00001003%20MERRWARN%200x00000000%20MIBIRULES%200x00000000%3C%2FERR%3E%3C%2FERR%3E%3C%2FERR%3E%3C%2FERR%3E%3C%2FDBG%3E%3C%2FDBG%3E%3C%2FDBG%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CBR%20%2F%3E%E7%A7%81%E3%81%AF%20'mcux_i3c_do_request_emit_stop()'%E3%82%92%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%80%81%E3%82%88%E3%82%8A%E8%89%AF%E3%81%84%E3%83%AD%E3%82%AE%E3%83%B3%E3%82%B0%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F(%E3%81%9D%E3%81%97%E3%81%A6%E3%81%99%E3%81%B9%E3%81%A6%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%97%E3%81%A6%E5%9B%9E%E5%BE%A9%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%BE%E3%81%99...%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%83%AD%E3%82%B0%E3%81%8C%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%9F%E5%BE%8C%E3%82%82%E3%83%90%E3%82%B9%E3%81%8C%E3%81%BE%E3%81%A0%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%AE%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Estatic%20inline%20int%20mcux_i3c_do_request_emit_stop(I3C_Type%20*base%2C%20bool%20wait_stop)%0A%7B%0A%09reg32_update(%26amp%3Bbase-%26gt%3BMCTRL%2C%0A%09%09%20%20%20%20%20I3C_MCTRL_REQUEST_MASK%20%7C%20I3C_MCTRL_DIR_MASK%20%7C%20I3C_MCTRL_RDTERM_MASK%2C%0A%09%09%20%20%20%20%20I3C_MCTRL_REQUEST_EMIT_STOP)%3B%0A%0A%09%2F*%0A%09%20*%20EMIT_STOP%20request%20doesn't%20result%20in%20MCTRLDONE%20being%20cleared%0A%09%20*%20so%20don't%20wait%20for%20it.%0A%09%20*%2F%0A%0A%09if%20(wait_stop)%20%7B%0A%09%09%2F*%0A%09%09%20*%20Note%20that%20we%20don't%20exactly%20wait%20for%20I3C_MSTATUS_STATE_IDLE.%0A%09%09%20*%20If%20there%20is%20an%20incoming%20IBI%2C%20it%20will%20get%20stuck%20forever%0A%09%09%20*%20as%20state%20would%20be%20I3C_MSTATUS_STATE_SLVREQ.%0A%09%09%20*%2F%0A%09%09int%20stop_tries%20%3D%200%3B%0A%09%09while%20(reg32_test_match(%26amp%3Bbase-%26gt%3BMSTATUS%2C%20I3C_MSTATUS_STATE_MASK%2C%0A%09%09%09%09%09I3C_MSTATUS_STATE_NORMACT))%20%7B%0A%09%09%09if%20(mcux_i3c_has_error(base))%20%7B%0A%09%09%09%09%2F*%0A%09%09%09%09%20*%20A%20timeout%20error%20has%20been%20observed%20on%0A%09%09%09%09%20*%20an%20EMIT_STOP%20request.%20Refman%20doesn't%20say%0A%09%09%09%09%20*%20how%20that%20could%20occur%20but%20clear%20it%0A%09%09%09%09%20*%20and%20return%20the%20error.%0A%09%09%09%09%20*%2F%0A%09%09%09%09if%20(reg32_test(%26amp%3Bbase-%26gt%3BMERRWARN%2C%0A%09%09%09%09%09%20%20%20%20%20%20%20I3C_MERRWARN_TIMEOUT_MASK))%20%7B%0A%09%09%09%09%09mcux_i3c_errwarn_clear_all_nowait(base)%3B%0A%09%09%09%09%09return%20-ETIMEDOUT%3B%0A%09%09%09%09%7D%0A%09%09%09%09return%20-EIO%3B%0A%09%09%09%7D%0A%09%09%09k_busy_wait(10)%3B%0A%09%09%09stop_tries%2B%2B%3B%0A%09%09%09if%20(stop_tries%20%26gt%3B%2010000)%7B%0A%09%09%09%09uint32_t%20mstatus%2C%20merrwarn%2C%20ibirules%2C%20mctrl%3B%0A%09%09%09%09int%20err%3B%0A%09%09%09%09mstatus%20%3D%20base-%26gt%3BMSTATUS%3B%0A%09%09%09%09merrwarn%20%3D%20base-%26gt%3BMERRWARN%3B%0A%09%09%09%09ibirules%20%3D%20base-%26gt%3BMIBIRULES%3B%0A%09%09%09%09mctrl%20%3D%20base-%26gt%3BMCTRL%3B%0A%09%09%09%09LOG_ERR(%22Tried%20to%20emit%20stop%2010000times..clearing%20all!%20MCTRL%200x%2508x%20MSTATUS%200x%2508x%20MERRWARN%200x%2508x%20MIBIRULES%200x%2508x%22%2C%0A%09%09%09%09%09mctrl%2C%20mstatus%2C%20merrwarn%2C%20ibirules)%3B%0A%09%09%09%09stop_tries%20%3D%200%3B%0A%09%09%09%09k_msleep(1000)%3B%0A%09%09%09%09mcux_i3c_errwarn_clear_all_nowait(base)%3B%0A%0A%09%09%09%09%2F%2Fsame%20mask%20as%20clear%20all%20but%20no%20inf%20busy%20wait%0A%09%09%09%09uint32_t%20clear_mask%20%3D%20I3C_MSTATUS_MCTRLDONE_MASK%20%7C%0A%09%09%09%09%09I3C_MSTATUS_COMPLETE_MASK%20%7C%0A%09%09%09%09%09I3C_MSTATUS_IBIWON_MASK%20%7C%0A%09%09%09%09%09I3C_MSTATUS_ERRWARN_MASK%3B%0A%09%09%09%09if((err%20%3D%20mcux_i3c_status_clear_timeout(base%2C%20clear_mask%2C%201000))%20!%3D%200)%7B%20%20%2F%2Fclear%20all%20with%20wait%201ms%0A%09%09%09%09%09LOG_WRN(%22timeout%20clearing%20status%20mask%20%3D%200x%2508x%22%2C%20clear_mask)%3B%0A%09%09%09%09%7D%3B%0A%09%09%09%09%2F%2F%20return%20-ETIMEDOUT%3B%0A%09%09%09%7D%0A%09%09%7D%0A%09%7D%0A%09return%200%3B%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%3CBR%20%2F%3E%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81IBI%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E3%83%90%E3%82%B9%E3%81%AFNORMACT%E3%81%8A%E3%82%88%E3%81%B3I2C%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E7%84%A1%E6%9C%9F%E9%99%90%E3%81%AB%E3%82%A8%E3%83%9F%E3%83%83%E3%83%88%E3%82%B9%E3%83%88%E3%83%83%E3%83%97%E3%81%AB%E9%96%89%E3%81%98%E8%BE%BC%E3%82%81%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E7%A7%81%E3%81%8C%E3%82%A2%E3%82%A4%E3%83%89%E3%83%AB%E7%8A%B6%E6%85%8B%E3%81%A8POR%E7%8A%B6%E6%85%8B%E3%81%A7%E3%81%82%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%A0%E3%81%A8%E8%A8%80%E3%81%86%E3%81%A8%E3%81%8D%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E5%BC%B7%E5%88%B6%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%81%93%E3%81%93%E3%81%A7%E3%81%A9%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AB%E3%81%A9%E3%81%AE%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%84%9F%E8%AC%9D%3CBR%20%2F%3E%E3%82%AC%E3%83%AC%E3%83%8E%E3%82%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2051098%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AZephyr%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9FRT685%20i3c%E3%83%9D%E3%83%BC%E3%83%88%20-%20i2c%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E6%95%B0%E5%88%86%E3%81%AE%E4%BD%BF%E7%94%A8%E5%BE%8C%E3%81%AB%E6%AD%BB%E4%BA%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2051098%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20Galen%2C%3C%2FP%3E%0A%3CP%3EIBI%20%E3%81%AF%20I3C%20%E3%81%AE%E3%81%BF%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81I2C%20%E9%80%9A%E4%BF%A1%E3%81%AE%E3%81%BF%E3%82%92%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%82MIBIRULES%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E4%BD%95%E3%82%82%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81I2C%20%E3%81%BE%E3%81%9F%E3%81%AF%20I3C%20%E3%81%AB%E9%96%A2%E4%BF%82%E3%81%AA%E3%81%8F%E3%80%81I2C%20%E3%81%AE%E9%96%8B%E5%A7%8B%2F%E5%81%9C%E6%AD%A2%E6%9D%A1%E4%BB%B6%E3%81%AE%E7%94%9F%E6%88%90%E3%81%AB%E3%81%AF%20Emit%20Start%2FStop%20%E8%A6%81%E6%B1%82%E3%81%8C%E5%BC%95%E3%81%8D%E7%B6%9A%E3%81%8D%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%80%8C%E9%80%9A%E5%B8%B8%E3%81%AE%E6%96%B9%E6%B3%95%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%20I2C%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%A8%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%80%8D%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BB%96%E3%81%AB%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AAI3C%E6%A9%9F%E8%83%BD%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%9F%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81IBI%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%AA%E3%82%AB%E3%83%90%E3%83%AA%E3%83%BC%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%81%AF%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AB%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E5%87%BA%E3%81%9F%E3%81%8B%E3%81%AB%E3%82%88%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%8C%E8%80%83%E3%81%88%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%81%93%E3%81%A8%3A%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%8CIDLE%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%80%81%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E6%A7%8B%E6%88%90%E3%81%8CPOR%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E7%8A%B6%E6%85%8B%E3%81%AB%E6%88%BB%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%80%81%E4%BF%9D%E7%95%99%E4%B8%AD%E3%81%AE%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%8C%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2050665%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AZephyr%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9FRT685%20i3c%E3%83%9D%E3%83%BC%E3%83%88%20-%20i2c%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E6%95%B0%E5%88%86%E3%81%AE%E4%BD%BF%E7%94%A8%E5%BE%8C%E3%81%AB%E6%AD%BB%E4%BA%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2050665%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246390%22%20target%3D%22_blank%22%3E%40galenc%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E7%A7%81%E3%81%AFZephyr%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fzephyrproject-rtos%2Fzephyr%2Fblob%2F70f55bccf8af2866331f6fd84e05c600f4457704%2Fdrivers%2Fi3c%2Fi3c_mcux.c%23L626%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fzephyrproject-rtos%2Fzephyr%2Fblob%2F70f55bccf8af2866331f6fd84e05c600f4457704%2Fdrivers%2Fi3c%2Fi3c_mcux.c%23L626%3C%2FA%3E%20%E3%81%8B%E3%82%89i3c%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92chck%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fzephyrproject-rtos%2Fzephyr%2Fblob%2F70f55bccf8af2866331f6fd84e05c600f4457704%2Fdrivers%2Fi3c%2Fi3c_mcux.c%23L626%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%86%85%E3%81%AE%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81Apache-2.0%E3%81%AB%E6%BA%96%E6%8B%A0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99Freescale%E3%80%81Intel%E3%80%81NXP%E3%81%8B%E3%82%89%E5%AF%84%E7%A8%BF%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E5%AF%BE%E5%87%A6%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E9%81%A9%E3%81%97%E3%81%9F%E4%BA%BA%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E5%B0%91%E3%81%97%E6%99%82%E9%96%93%E3%81%8C%E3%81%8B%E3%81%8B%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%3CSPAN%3EZephyr%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3(%3C%2FSPAN%3E%3CSPAN%20data-fm-marker%3D%22221%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20data-fm-marker%3D%22222%22%3E%3CA%20class%3D%22external-link%22%20href%3D%22https%3A%2F%2Fgithub.com%2Fzephyrproject-rtos%2Fzephyr%2Fdiscussions%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20data-fm-marker%3D%22223%22%20target%3D%22_blank%22%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FA%3E%3C%2FSPAN%3E%3CSPAN%20data-fm-marker%3D%22224%22%3E%E3%81%A8%3C%2FSPAN%3E%3CSPAN%20data-fm-marker%3D%22225%22%3E%3CA%20class%3D%22external-link%22%20href%3D%22https%3A%2F%2Fgithub.com%2Fzephyrproject-rtos%2Fzephyr%2Fissues%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20data-fm-marker%3D%22226%22%20target%3D%22_blank%22%3E%E5%95%8F%E9%A1%8C%3C%2FA%3E%3C%2FSPAN%3E%3CSPAN%20data-fm-marker%3D%22227%22%3E%26nbsp%3B%3C%2FSPAN%3E)%E3%82%92%E5%88%A9%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%3CSPAN%20data-fm-marker%3D%22228%22%3E%E3%80%81%E5%BD%BC%E3%82%89%E3%81%8C%E7%9B%B4%E6%8E%A5%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%93%E3%81%AEI3C%E3%81%AE%E8%B3%AA%E5%95%8F(emit%E3%80%81IBI)%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81NXP%E3%81%AE%E5%85%B1%E9%80%9A%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-mcuxpresso%2Fmcux-sdk%2Fblob%2Fmain%2Fdrivers%2Fi3c%2Ffsl_i3c.c%23L690%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-mcuxpresso%2Fmcux-sdk%2Fblob%2Fmain%2Fdrivers%2Fi3c%2Ffsl_i3c.c%23L690%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2050264%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AZephyr%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9FRT685%20i3c%E3%83%9D%E3%83%BC%E3%83%88%20-%20i2c%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E6%95%B0%E5%88%86%E3%81%AE%E4%BD%BF%E7%94%A8%E5%BE%8C%E3%81%AB%E6%AD%BB%E4%BA%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2050264%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%A0%E3%81%8B%E3%82%89%E7%A7%81%E3%81%AF%E5%A4%9A%E3%81%8F%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%92%E8%A1%8C%E3%81%84%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E9%9A%9C%E5%AE%B3%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%9C%80%E5%BE%8C%E3%81%AE%E3%82%82%E3%81%AE%E3%81%AF%E3%80%81zephyr%E3%81%AEi3c%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E8%A1%8C%E3%81%AB%E7%B5%9E%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fzephyrproject-rtos%2Fzephyr%2Fblob%2F70f55bccf8af2866331f6fd84e05c600f4457704%2Fdrivers%2Fi3c%2Fi3c_mcux.c%23L659%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fzephyrproject-rtos%2Fzephyr%2Fblob%2F70f55bccf8af2866331f6fd84e05c600f4457704%2Fdrivers%2Fi3c%2Fi3c_mcux.c%23L659%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AB%E3%81%AF%E3%80%81%20'drivers%2Fi3c%20%2F%20i3c_mcux.c'%E3%81%AE%20'mcux_i3c_do_request_emit_stop()'%E6%A9%9F%E8%83%BD%E3%81%93%E3%81%AE%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AB%E9%99%A5%E3%82%8A%E3%80%81k_busy_wait(10)%E3%81%8C%E6%B0%B8%E4%B9%85%E3%81%AB%E5%81%9C%E6%AD%A2%E3%82%92%E7%99%BA%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%9A%E3%80%81%E3%83%93%E3%82%B8%E3%83%BC%E3%81%AA%E5%BE%85%E6%A9%9F%E3%81%A7%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81Zephyr%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%82%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AB%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%95%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E5%85%A8%E4%BD%93%E3%81%8C%E6%AD%BB%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%A7%81%E3%81%8C%E8%BF%B0%E3%81%B9%E3%81%9F%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AFi3c%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E5%91%A8%E8%BE%BA%E6%A9%9F%E5%99%A8%E3%81%AF%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AFi2c%E3%81%A7%E3%81%99%E3%80%82%E3%82%B9%E3%83%88%E3%83%83%E3%83%97%E3%82%92%E7%99%BA%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E4%BD%95%E3%82%92%E3%81%99%E3%82%8B%E3%81%AE%E3%81%8B%E6%AD%A3%E7%A2%BA%E3%81%AB%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81IBI%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%81%8B%3F%20%E3%82%B5%E3%83%96%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E3%83%90%E3%82%B9%E3%81%AE%E5%88%B6%E5%BE%A1%E3%82%92%E5%AE%8C%E5%85%A8%E3%81%AB%E5%A4%B1%E3%81%A3%E3%81%9F%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%AF%E3%81%AA%E3%81%9C%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%E3%81%93%E3%82%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%89%AF%E3%81%84%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E7%A7%81%E3%81%8C%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F2%E3%81%A4%E3%81%AE%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E3%81%8B%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E1.%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AEi3c%E6%A9%9F%E8%83%BD%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%A8%E3%82%82%E5%81%9C%E6%AD%A2%E3%82%92%E7%99%BA%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8B(%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%BE%E3%81%A3%E3%81%9F%E3%81%8F%E7%99%BA%E7%94%9F%E3%81%95%E3%81%9B%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B)%E6%A9%9F%E8%83%BD%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81%E5%81%9C%E6%AD%A2%E6%9D%A1%E4%BB%B6%E3%82%92%E7%84%A1%E8%A6%96%E3%81%A7%E3%81%8D%E3%82%8B%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%BC%B7%E5%88%B6%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E2.%20%E3%81%93%E3%81%93%E3%81%A7%E3%83%90%E3%82%B9%E3%81%AE%E5%88%B6%E5%BE%A1%E3%82%92%E5%88%9D%E6%9C%9F%E7%8A%B6%E6%85%8B%E3%81%AB%E6%88%BB%E3%81%99%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%9D%E3%82%8C%E4%BB%A5%E5%A4%96%E3%81%AB%E3%80%81%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%A7%E4%BD%95%E3%81%8C%E8%B5%B7%E3%81%93%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E3%80%81%E3%81%A4%E3%81%BE%E3%82%8A%E6%AD%A3%E7%A2%BA%E3%81%AB%E4%BD%95%E3%82%92%E5%BE%85%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%9D%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%8C%E6%9C%80%E7%B5%82%E7%9A%84%E3%81%AB%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%A9%E3%81%86%E3%82%84%E3%81%A3%E3%81%A6%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%84%9F%E8%AC%9D%3CBR%20%2F%3E%E3%82%AC%E3%83%AC%E3%83%8E%E3%82%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2039166%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AZephyr%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9FRT685%20i3c%E3%83%9D%E3%83%BC%E3%83%88%20-%20i2c%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E6%95%B0%E5%88%86%E3%81%AE%E4%BD%BF%E7%94%A8%E5%BE%8C%E3%81%AB%E6%AD%BB%E4%BA%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2039166%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246390%22%20target%3D%22_blank%22%3E%40galenc%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI3C%E3%80%81Zephyr%E3%80%81%3CSPAN%3Elsm6dso%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3SDK%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%82%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E4%B8%80%E3%81%A4%E4%B8%80%E3%81%A4%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%9F%E3%82%82%E3%81%AE%E3%82%92%E6%95%B4%E7%90%86%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E6%A0%B9%E6%9C%AC%E7%9A%84%E3%81%AA%E5%8E%9F%E5%9B%A0%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%AE%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A4%E3%81%93%E3%81%A8%E3%82%92%E9%A1%98%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E1.Zephyr%E3%81%A7%E3%81%AF%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AEI8904C%E3%81%A8%E3%81%97%E3%81%A6wm3%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fzephyrproject-rtos%2Fzephyr%2Fblob%2Fmain%2Fboards%2Fnxp%2Fmimxrt685_evk%2Fmimxrt685_evk_mimxrt685s_cm33.dts%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fzephyrproject-rtos%2Fzephyr%2Fblob%2Fmain%2Fboards%2Fnxp%2Fmimxrt685_evk%2Fmimxrt685_evk_mimxrt685s_cm33.dts%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fzephyrproject-rtos%2Fzephyr%2Fblob%2Fmain%2Fboards%2Fnxp%2Fmimxrt685_evk%2Fmimxrt685_evk-pinctrl.dtsi%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fzephyrproject-rtos%2Fzephyr%2Fblob%2Fmain%2Fboards%2Fnxp%2Fmimxrt685_evk%2Fmimxrt685_evk-pinctrl.dtsi%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%26amp%3Bi3c0%20%7B%0A%09pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinmux_i3c%26gt%3B%3B%0A%09pinctrl-names%20%3D%20%22default%22%3B%0A%0A%09status%20%3D%20%22okay%22%3B%0A%0A%09audio_codec%3A%20wm8904%401a0000000000000000%20%7B%0A%09%09compatible%20%3D%20%22wolfson%2Cwm8904%22%3B%0A%09%09reg%20%3D%20%26lt%3B0x1a%200%200%26gt%3B%3B%0A%0A%09%09clock-source%20%3D%20%22MCLK%22%3B%0A%0A%09%09clocks%20%3D%20%26lt%3B%26amp%3Bclkctl0%20MCUX_AUDIO_MCLK%26gt%3B%3B%0A%09%09clock-names%20%3D%20%22mclk%22%3B%0A%09%7D%3B%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%E3%80%81%E7%B4%B9%E4%BB%8B%E3%81%8B%E3%82%89I2C(I3C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E8%A8%80%E5%8F%8A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93)%E3%81%AE%E3%81%BF%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fzephyrproject-rtos%2Fzephyr%2Fblob%2Fmain%2Fboards%2Fnxp%2Fmimxrt685_evk%2Fdoc%2Findex.rst%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fzephyrproject-rtos%2Fzephyr%2Fblob%2Fmain%2Fboards%2Fnxp%2Fmimxrt685_evk%2Fdoc%2Findex.rst%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CTABLE%3E%0A%3CTBODY%20valign%3D%22top%22%3E%0A%3CTR%3E%0A%3CTD%3EPIO0_17%3C%2FTD%3E%0A%3CTD%3EI2C%E3%81%AE%3C%2FTD%3E%0A%3CTD%3EI2C%20SDA%E3%81%AE%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3EPIO0_18%3C%2FTD%3E%0A%3CTD%3EI2C%E3%81%AE%3C%2FTD%3E%0A%3CTD%3EI2C%20SCL%E3%81%AE%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E2.%20EVKMIMXRT685%E3%82%92%E3%81%8A%E4%BD%BF%E3%81%84%E3%81%AE%E6%96%B9%E3%81%AF%E3%80%81%E3%83%86%E3%82%B9%E3%83%88%E7%94%A8%E3%81%A8%E3%81%97%E3%81%A6%20%3CA%20href%3D%22https%3A%2F%2Fmcuxpresso.nxp.com%2Fen%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Eoffical%20SDK%3C%2FA%3E%20%E3%82%92%E3%81%94%E4%BD%BF%E7%94%A8%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8F%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%AF%E3%82%A4%E3%83%83%E3%82%AF%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%81%AE%E5%89%8D%E3%81%AB%E3%80%81I3C%E3%81%AE%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%9C%E3%83%BC%E3%83%89%E8%A8%AD%E5%AE%9A%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-mcuxpresso%2Fmcux-sdk-examples%2Ftree%2Fmain%2Fevkmimxrt685%2Fdriver_examples%2Fi3c%2Fpolling_b2b_transfer%2Fmaster%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-mcuxpresso%2Fmcux-sdk-examples%2Ftree%2Fmain%2Fevkmimxrt685%2Fdriver_examples%2Fi3c%2Fpolling_b2b_transfer%2Fmaster%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E3.%E3%81%BE%E3%81%9F%E3%80%81%E3%81%93%E3%81%AE%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%8CI3C%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AF%E3%80%81%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E9%83%A8%E5%88%86(%E8%BB%9F%E8%86%8F)%E3%81%94%E3%81%A8%E3%81%AB%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E4.%E7%8F%BE%E5%9C%A8%E3%80%81%E6%98%8E%E7%A2%BA%E3%81%AA%E6%96%B9%E5%90%91%E6%80%A7%E3%82%84sw%20%2F%20hw%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E4%B8%8E%E3%81%88%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%9B%B0%E9%9B%A3%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EB.R%2C%3C%2FP%3E%0A%3CP%3ESam%3C%2FP%3E%3C%2FLINGO-BODY%3E
