Ask the masters:
I used two RT685 development boards for testing, one as the master mode as the transmitter, sending a regular data, and the other as the slave mode as the receiver, and found that the data received was not a regular data.
The following is the circuit diagram of the development board:
1、master data-> slave data;
2、master BLCK-> slave BLCK;
3、master WS-> slave WS;
The following is the code from the pattern:
/********slave GPIO Config**********/
const uint32_t port0_pin7_config = (/* Pin is configured as FC1_SCK */
IOPCTL_PIO_FUNC1 |
/* Disable pull-up / pull-down function */
IOPCTL_PIO_PUPD_DI |
/* Enable pull-down function */
IOPCTL_PIO_PULLDOWN_EN |
/* Enables input buffer function */
IOPCTL_PIO_INBUF_EN |
/* Normal mode */
IOPCTL_PIO_SLEW_RATE_NORMAL |
/* Full drive enable */
IOPCTL_PIO_FULLDRIVE_EN |
/* Analog mux is disabled */
IOPCTL_PIO_ANAMUX_DI |
/* Pseudo Output Drain is disabled */
IOPCTL_PIO_PSEDRAIN_DI |
/* Input function is not inverted */
IOPCTL_PIO_INV_DI);
/* PORT0 PIN7 (coords: J2) is configured as FC1_SCK */
IOPCTL_PinMuxSet(IOPCTL, 0U, 7U, port0_pin7_config);
const uint32_t port0_pin8_config = (/* Pin is configured as FC1_TXD_SCL_MISO_WS */
IOPCTL_PIO_FUNC1 |
/* Normal mode */
IOPCTL_PIO_INV_DI);
/* PORT0 PIN8 (coords: K4) is configured as FC1_TXD_SCL_MISO_WS */
IOPCTL_PinMuxSet(IOPCTL, 0U, 8U, port0_pin8_config);
const uint32_t port0_pin9_config = (/* Pin is configured as FC1_RXD_SDA_MOSI_DATA */
IOPCTL_PIO_FUNC1 |
/* Normal mode */
IOPCTL_PIO_INV_DI);
/* PORT0 PIN9 (coords: L3) is configured as FC1_RXD_SDA_MOSI_DATA */
IOPCTL_PinMuxSet(IOPCTL, 0U, 9U, port0_pin9_config);
/********slave I2S Config**********/
#define DEMO_I2S_RX (I2S1)
#define AUX_DMA (DMA0)
#define DEMO_I2S_RX_CHANNEL (2)
#define DEMO_I2S_RX_MODE kI2S_MasterSlaveNormalSlave
/********slave I2S INIT()**********/
I2S_RxGetDefaultConfig(&s_RxConfig);
s_RxConfig.divider = DEMO_I2S_CLOCK_DIVIDER;
s_RxConfig.masterSlave = DEMO_I2S_RX_MODE;
s_RxConfig.frameLength = 64U;
I2S_RxInit(DEMO_I2S_RX, &s_RxConfig);
//AUX I2S RX data buff Config
s_RxTransfer.data = &s_Buffer[0];
s_RxTransfer.dataSize = sizeof(s_Buffer);
I2S_RxTransferCreateHandleDMA(DEMO_I2S_RX, &s_RxHandle, &s_DmaRxHandle, RxCallback, (void *)&s_RxTransfer);
I2S_RxTransferReceiveDMA(DEMO_I2S_RX, &s_RxHandle, s_RxTransfer);
/********master I2S INIT()**********/
DMA_EnableChannel(AMP_DMA, AMP_I2S_TX_CHANNEL);
DMA_SetChannelPriority(AMP_DMA,AMP_I2S_TX_CHANNEL, kDMA_ChannelPriority3);
DMA_CreateHandle(&s_AmpDmaTxHandle, AMP_DMA, AMP_I2S_TX_CHANNEL);
I2S_TxGetDefaultConfig(&s_AmpTxConfig);
s_AmpTxConfig.divider = AMP_I2S_CLOCK_DIVIDER;
s_AmpTxConfig.masterSlave = AMP_I2S_TX_MODE;
//s_AmpTxConfig.leftJust = true;
s_AmpTxConfig.frameLength = 64U;
//tx_config.oneChannel = true; //mono
I2S_TxInit(AMP_I2S_TX, &s_AmpTxConfig);
I2S_TxTransferCreateHandleDMA(AMP_I2S_TX, &s_AmpTxHandle, &s_AmpDmaTxHandle, AmpTxCallback, NULL);
The following screenshot is the data captured by the logic analyzer of the master mode:
The following screenshot captures the data from the mode's emulator:【slave】
