IDE revision :11.2
EVK: MIMXRT685SEVKA
Thanks for your response! I'm checking this internally, I will give you an update as soon as possible. Thank you for your understanding.
Victor
We’ve identified hardware differences between the board used to prepare the app note and the one you have. We are working on preparing and releasing an updated set of project files that will help the customer run the app note with the revision of the board that you have.
In the meanwhile, you could use the I3C examples that we provide within the SDK/
Victor
什麼時候可以完成更新?
Unfortunately, we cannot provide a release date for the new version of the software. I apologize for the inconvenience that this might cause you.
Victor
什麼時候可以完成更新?
We don't have a release date for the update. I apologize for the inconvenience that this might cause you.
Victor
To provide you better support, could you please tell me which version of MCUXpresso IDE are you using and what revision of the EVK you have?
Victor
