I am trying the "dual image" feature on RT117o EVK.
On Provisioning tool there is Image version field:
in the popup it says: "Image with the higher image version is booted first".
This is openly at odds with flowcharts:
point me to the section in the Reference Manual or Security Reference Manual where this feature is detailed?
However, I also tried (see attached project):
Bottom line: is this feature really present on RT117x? And how is it used?
regards
Max
解決済! 解決策の投稿を見る。
I have progressed in my knowhow. I modified my example a bit to test a theory I had.
PRINTF("input 'y' to switch firmware to run!\r\n");
PRINTF("input other char to stay in the current firmware!\r\n");
ch = GETCHAR();
PUTCHAR(ch);
PRINTF("\r\n");
for(uint32_t i=0;i<0x1000;i++);
if(ch == 'y')
LPUART_Deinit(BOARD_DEBUG_UART_BASEADDR);
if(firmware_index)
bl_firmware_switch(0);
else
bl_firmware_switch(1);
else if(ch == '0' || ch == '1')
int target = ch - '0';
PRINTF("forcing reboot from image %d\r\n", target);
bl_firmware_switch(target);
this example is inspired (or adapted) from AN12255's example. The changes I made are that, in addition to 'y' (which starts the "other" image), you can press '0' or '1' to force the start of the images indicated by the character.
I wrote this FW in both slot 0 and 1. In slot 0 it has image version 2 (0xFFFD0002), while in slot 1 it has 1 (0xFFFE0001). So the one to start must always be slot 0.
Effectively at reset slot 0 starts, and the "jumps" from one slot to another are consistent:
@@@@@@@@@@@@ Hello world! This is firmware image 0
Firmware 0 start to run!
please input char for switching firmware, current count: 1
HADDRSTART 0
HADDREND 0
HADDROFFSET 0
y
************ Hello world! This is firmware index 1
welcome to run firmware 1!
HADDRSTART 30000001
HADDREND 30200000
HADDROFFSET 200000
y
HADDRSTART 0
HADDREND 0
HADDROFFSET 0
y
HADDRSTART 30000001
HADDREND 30200000
HADDROFFSET 200000
y
HADDRSTART 0
HADDREND 0
HADDROFFSET 0
1
forcing reboot from image 1
HADDRSTART 30000001
HADDREND 30200000
HADDROFFSET 200000
1
HADDRSTART 30000001
HADDREND 30200000
HADDROFFSET 200000
0
forcing reboot from image 0
HADDRSTART 0
HADDREND 0
HADDROFFSET 0
0
HADDRSTART 0
HADDREND 0
HADDROFFSET 0
if I swap the version numbers though (slot 1 <- 0xFFFE0001, slot 2 <- 0xFFFD0002), a strange thing happens. On reset slot 1 starts, as I expected, but it looks like the slot indexes are reversed:
HADDRSTART 0
HADDREND 0
HADDROFFSET 0
y
HADDRSTART 30000001
HADDREND 30200000
HADDROFFSET 200000
y
HADDRSTART 0
HADDREND 0
HADDROFFSET 0
1
y
HADDRSTART 0
HADDREND 0
HADDROFFSET 0
y
HADDRSTART 30000001
HADDREND 30200000
HADDROFFSET 200000
y
HADDRSTART 30000001
HADDREND 30200000
HADDROFFSET 200000
y
HADDRSTART 30000001
HADDREND 30200000
HADDROFFSET 200000
y
HADDRSTART 30000001
HADDREND 30200000
HADDROFFSET 200000
0
HADDRSTART 30000001
HADDREND 30200000
HADDROFFSET 200000
0
HADDRSTART 30000001
HADDREND 30200000
HADDROFFSET 200000
1
HADDRSTART 0
HADDREND 0
HADDROFFSET 0
1
HADDRSTART 0
HADDREND 0
HADDROFFSET 0
0
HADDRSTART 30000001
HADDREND 30200000
HADDROFFSET 200000
1
HADDRSTART 0
HADDREND 0
HADDROFFSET 0
Can you explain this strange behavior? Or maybe you can point me to cove this feature/behavior is documented?
regards
Max
Hello @mastupristi,
Could you please take a look at the i.MX RT1170 Processor Reference Manual. Section 10.13.3 Enter Bootloader API or Security Reference Manual for the i.MX RT1170 Processor. Section 2.13.3 Enter Bootloader API. There is the ARG definition table, which explains about the Boot image selection?
Warm regards, Raul.
I got the point (I had missed it on a first reading)
