I have a demoboard of the i.MXRT117H as the bellow link.
However this demoboard have only wifi and I need realize a ethernet wired comunication. I read the datasheet (bellow link) but I hasn't find the pinmap for conect a ethernet circuit (RJ45 conector, PHY IC).
https://www.nxp.com/docs/en/data-sheet/IMXRT1170IEC.pdf
Can anybody help-me?
Hi @rubensjunior,
The RT117H does have capability for ethernet connections. However, as you can see on the SLN-TLHMI-IOT Hardware Design Files, the SLN-TLHMI-IOT does not have any ethernet routings or pads available to use for this module. Most of the ENET pins are routed to port GPIO_AD:
Which are already in use for the RGB and IR cameras:
BR,
Edwin.
Thank you @EdwinHz ! Can I Know a alternative for use the camera and Ethernet too? Our company needs this scenario.
Thank you!
Rubens Junior
RWTECH
