I recently designed an RT1176 system. It uses the SDRAM controller. I can run the example driver app and memory passes read / write tests. I would like to run the memory at 166MHZ. The clocking tree is quite complex and is difficult to get a handle on in short order time. Would someone be able to tell me how to change the memory clock to 166MHZ.
Thank you
已解决! 转到解答。
Jingpan,
Thank you. Went into SEMC clock root and changed SDRAM clock to 166.73MHz.
Memory runs with no errors.
