RT1170 custom bootloader
2,485 次查看
sandeepc
I want develop custom boot loader using Qspi external flash.
If you have any better document to understand the memory organization to implementation of boot loader please shar with me.
processor: imxrt1170
External flash: winbond(W25Q64JV)
Mode: XIP mode
Sandeep C
@kerryzhou
6 回复数
2,377 次查看
kerryzhou
Hi @sandeepc ,
  About the bootloader, we have a lot of codes for your reference.
1. SBL/SFW
https://www.nxp.com/docs/en/user-guide/MCUOTASBLSFWUG.pdf
2. sdk
https://mcuxpresso.nxp.com/en/builder?hw=MIMXRT1170-EVK
\SDK_2_15_000_MIMXRT1170-EVK\boards\evkmimxrt1170\ota_examples
About the flash operation, you can refer to SDK:
SDK_2_15_000_MIMXRT1170-EVK\boards\evkmimxrt1170\driver_examples\fsl_romapi
SDK_2_15_000_MIMXRT1170-EVK\boards\evkmimxrt1170\driver_examples\flexspi\nor
Wish it helps you!
If you still have question about it, please kindly let me now.
If your question is solved, please help to mark the correct answer, just to close this case, thanks.
Kerry
2,361 次查看
sandeepc
Thanks for the reply.
i will refer...
2,480 次查看
Bkaya
Hi @sandeepc ,
You can use SDK example bootloader or i shared link below that i used while designing my bootloader project. I can not share my code but if you have any question i want to help.
Basri KAYA
https://github.com/NXP/mcu-smhmi
2,475 次查看
sandeepc
i will go through your code.
Do you have any document to understand well xip boot?
Sandeep c
sabdeep C
2,466 次查看
Bkaya
You are welcome. That is not my code but it will be very usefull to start writing your code.
For Xip Boot, you can import SDK example romapi_cm7 for 1170.
2,463 次查看
sandeepc
Ok, thanks i will go through your code.
Sandeep C
