RT1170 EVKB Multicore project and LinkServer Flash programmer not working (mcuxpresso vs code)
cyberhelmer
I have a project based on the freeRTOS multicore message buffers example from nxp SDK.
There seem to be a problem with the LinkServer Flash Programmer in the mcuxpresso for vs code extension.
I am sometimes able to flash the m7 firmware which loads the M4 to the correct ocram adress. Very often the flash programmer fails and the board stops running it's code.
What is the cause of this and how can I fix it so that I'm always able to flash the m7 correctly?
Thanks!
Log when failing:
2025-09-18T00:58:40.377] [proc] [info] Cmd: /Users/melker/.mcuxpressotools/pemicrogdbserver/pegdbserver_console -showhardware
[2025-09-18T00:58:40.379] [proc] [info] Cmd: /Applications/LinkServer_25.7.33/LinkServer probes --json
[2025-09-18T00:58:40.380] [proc] [info] Cmd: /Applications/SEGGER/JLink_V824/JLinkGDBServerCLExe -listprobes USB
[2025-09-18T00:58:41.772] [proc] [info] Cmd: /Users/melker/.mcuxpressotools/pemicrogdbserver/pegdbserver_console -showhardware
[2025-09-18T00:58:41.773] [proc] [info] Cmd: /Applications/SEGGER/JLink_V824/JLinkGDBServerCLExe -listprobes USB
[2025-09-18T00:58:41.773] [proc] [info] Cmd: /Applications/LinkServer_25.7.33/LinkServer probes --json
[2025-09-18T00:58:44.950] [proc] [info] Cmd: /Applications/LinkServer_25.7.33/LinkServer flash --probe H3RHID4AC30FD --no-boot MIMXRT1176xxxxx:MIMXRT1170-EVKB load /Users/melker/CodeProjects/AudioBox/code/code_primary_core/armgcc/flexspi_nor_debug/freertos_message_buffers_primary_core.elf
[2025-09-18T00:58:48.405] [proc] [error] /Applications/LinkServer_25.7.33/LinkServer exited with code 255
[2025-09-18T00:58:48.405] [proc] [error] Firmware update `check`: not required - forced update can be performed using: `./LinkServer probe #1 update forced`
Ns: LinkServer RedlinkMulti Driver v25.7 (Jul 21 2025 20:37:00 - crt_emu_cm_redlink build 1038)
Pc: ( 0) Reading remote configuration
Wc(03). No cache support.
Nc: Found generic directory XML file in /var/folders/8x/1csc34zn7pq1_ksyf9k3x24h0000gn/T/tmp3tmcfgxp/crt_directory.xml
Pc: ( 5) Remote configuration complete
Nc: Reconnected to existing LinkServer process.
Wc: ============= SCRIPT: RT1170_connect_M7_wake_M4.scp =============
Wc: RT1170 Connect M7 and Wake M4 Script
Wc: DpID = 6BA02477
Wc: APID = 0x84770001
Wc: Setting M4 spin code
Wc: Setting M4 clock
Wc: Resetting M4 core
Wc: View cores on the DAP AP
Wc: DpID = 6BA02477
Wc: TAP 0: 6BA02477 Core 0: M7 APID: 84770001 ROM Table: E00FD003*
Wc: TAP 0: 6BA02477 Core 1: M4 APID: 24770011 ROM Table: E00FF003
Wc: ============= END SCRIPT ========================================
Nc: Probe Firmware: MCU-LINK on-board (r0E2) CMSIS-DAP V3.160 (NXP Semiconductors)
Nc: Serial Number: H3RHID4AC30FD
Nc: VID:PID: 1FC9:0143
Nc: USB Path: 0014:0002:00
Nc: Using memory from core 0 after searching for a good core
Pc: ( 30) Emulator Connected
Pc: ( 40) Debug Halt
Pc: ( 50) CPU ID
Nc: debug interface type = CoreSight DP (DAP DP ID 6BA02477) over SWD TAP 0
Nc: processor type = Cortex-M7 (CPU ID 00000C27) on DAP AP 0
Nc: number of h/w breakpoints = 8
Nc: number of flash patches = 0
Nc: number of h/w watchpoints = 4
Nc: Probe(0 Connected&Reset. DpID: 6BA02477. CpuID: 00000C27. Info: <None>
Nc: Debug protocol: SWD. RTCK: Disabled. Vector catch: Disabled.
Ns: Content of CoreSight Debug ROM(s):
Nc: RBASE E00FD000: CID B105100D PID 000008E88C ROM (type 0x1)
Nc: ROM 1 E00FE000: CID B105100D PID 04000BB4C8 ROM (type 0x1)
Nc: ROM 2 E00FF000: CID B105100D PID 04000BB4C7 ROM (type 0x1)
Nc: ROM 3 E000E000: CID B105E00D PID 04000BB00C Gen SCS (type 0x0)
Nc: ROM 3 E0001000: CID B105E00D PID 04000BB002 Gen DWT (type 0x0)
Nc: ROM 3 E0002000: CID B105E00D PID 04000BB00E Gen (type 0x0)
Nc: ROM 3 E0000000: CID B105E00D PID 04000BB001 Gen ITM (type 0x0)
Nc: ROM 2 E0041000: CID B105900D PID 04001BB975 CSt ARM ETMv4.0 type 0x13 Trace Source - Core
Nc: ROM 2 E0042000: CID B105900D PID 04004BB906 CSt type 0x14 Debug Control - Trigger, e.g. ECT
Nc: ROM 1 E0043000: CID B105900D PID 04001BB908 CSt CSTF type 0x12 Trace Link - Trace funnel/router
Nc: NXP: MIMXRT1176xxxxx
Nc: DAP stride is 1024 bytes (256 words)
Nc: Inspected v.2 External Flash Device on SPI using SFDP JEDEC ID MIMXRT1170_SFDP_QSPI.cfx
Nc: Image 'iMXRT1170_SFDP_FlexSPI1_A_QSPI Jul 21 2025 18:35:07'
Nc: Opening flash driver MIMXRT1170_SFDP_QSPI.cfx
Nc: Sending VECTRESET to run flash driver
Nc: Flash variant 'iMXRT1170_SFDP_FlexSPI1_A_QSPI Jul 21 2025 18:35:07' detected (64MB = 1024*64K at 0x30000000)
Nc: Closing flash driver MIMXRT1170_SFDP_QSPI.cfx
Pc: ( 65) Chip Setup Complete
Pc: ( 70) License Check Complete
Nt: Loading 'freertos_message_buffers_primary_core.elf' ELF 0x30000400 len 0x200
Nc: Opening flash driver MIMXRT1170_SFDP_QSPI.cfx (already resident)
Nc: Warning - failed to start flash driver (at 0x2000009D?) - rc Nn(05). Wire ACK Fault in DAP access
Nc: Flash Driver V.2 startup failed - rc Nn(05). Wire ACK Fault in DAP access
Pb: (100) Writing Flash ended with an error.
Ed:05: File 'freertos_message_buffers_primary_core.elf' load failure: Nn(05). Wire ACK Fault in DAP access
Nt: Loading 'freertos_message_buffers_primary_core.elf' ELF 0x30001000 len 0x30
Nc: request to clear DAP error failed - status 5
Nt: Loading 'freertos_message_buffers_primary_core.elf' ELF 0x30002000 len 0x12044
Nt: Loading 'freertos_message_buffers_primary_core.elf' ELF 0x33FC0000 len 0x7144
Pc: (100) Target Operation Failed
Nc: error closing down debug session - Nn(05). Wire ACK Fault in DAP access
INFO: Exact match for MIMXRT1176xxxxx:MIMXRT1170-EVKB found
INFO: Selected device MIMXRT1176xxxxx:MIMXRT1170-EVKB
INFO: Getting available probes
INFO: Selecting probe by serial substring
INFO: Selected probe #1 H3RHID4AC30FD (MCU-LINK on-board (r0E2) CMSIS-DAP V3.160)
INFO: MCU-Link firmware update `check`: Probe ([H3RHID4AC30FD] [MCU-LINK on-board (r0E2) CMSIS-DAP V3.160]) is already running the same firmware version as the included firmware version [3.160]
CRITICAL: Critical error
ERRMSG: Exception: Flash operation exited with code 1
This is the log when the flashing actually succeeds:
[2025-09-18T01:03:12.927] [proc] [info] Cmd: /Users/melker/.mcuxpressotools/pemicrogdbserver/pegdbserver_console -showhardware
[2025-09-18T01:03:12.928] [proc] [info] Cmd: /Applications/SEGGER/JLink_V824/JLinkGDBServerCLExe -listprobes USB
[2025-09-18T01:03:12.928] [proc] [info] Cmd: /Applications/LinkServer_25.7.33/LinkServer probes --json
[2025-09-18T01:03:14.329] [proc] [info] Cmd: /Users/melker/.mcuxpressotools/pemicrogdbserver/pegdbserver_console -showhardware
[2025-09-18T01:03:14.338] [proc] [info] Cmd: /Applications/SEGGER/JLink_V824/JLinkGDBServerCLExe -listprobes USB
[2025-09-18T01:03:14.346] [proc] [info] Cmd: /Applications/LinkServer_25.7.33/LinkServer probes --json
[2025-09-18T01:03:17.511] [proc] [info] Cmd: /Applications/LinkServer_25.7.33/LinkServer flash --probe H3RHID4AC30FD --no-boot MIMXRT1176xxxxx:MIMXRT1170-EVKB load /Users/melker/CodeProjects/AudioBox/code/code_primary_core/armgcc/flexspi_nor_debug/freertos_message_buffers_primary_core.elf
[2025-09-18T01:03:23.784] [proc] [info] INFO: Exact match for MIMXRT1176xxxxx:MIMXRT1170-EVKB found
[2025-09-18T01:03:23.784] [LinkServer] [info] LinkServer flash operation completed successfully:
Nc: Found generic directory XML file in /var/folders/8x/1csc34zn7pq1_ksyf9k3x24h0000gn/T/tmpci6yg1l_/crt_directory.xml
Wc: DpID = 6BA02477
Wc: Releasing M4
Wc: DpID = 6BA02477
Pc: ( 50) CPU ID
Pb: 1 of 1 ( 0) Writing sectors 0-0 at 0x30000400 with 512 bytes
Ps: ( 0) at 30000000: 0 bytes - 0/1536
Ps: (100) at 30000000: 16384 bytes - 16384/1536
Nc: 30004000 done 100% (16384 out of 1536)
Nc: Sectors written: 1, unchanged: 0, total: 1
Pb: (100) Finished writing Flash successfully.
Nt: Loaded 0x200 bytes in 295ms (about 1kB/s)
Pb: 1 of 1 ( 0) Writing sectors 0-0 at 0x30001000 with 48 bytes
Ps: ( 0) at 30000000: 0 bytes - 0/4144
Ps: (100) at 30000000: 16384 bytes - 16384/4144
Nc: 30004000 done 100% (16384 out of 4144)
Nt: Loaded 0x30 bytes in 310ms (about 0kB/s)
Pb: 1 of 1 ( 0) Writing sectors 0-1 at 0x30002000 with 73796 bytes
Ps: ( 0) at 30000000: 0 bytes - 0/81988
Ps: ( 19) at 30000000: 16384 bytes - 16384/81988
Nc: 30004000 done 19% (16384 out of 81988)
Ps: ( 39) at 30004000: 16384 bytes - 32768/81988
Nc: 30008000 done 39% (32768 out of 81988)
Ps: ( 59) at 30008000: 16384 bytes - 49152/81988
Nc: 3000C000 done 59% (49152 out of 81988)
Ps: ( 79) at 3000C000: 16384 bytes - 65536/81988
Nc: 30010000 done 79% (65536 out of 81988)
Ps: (100) at 30010000: 65536 bytes - 131072/81988
Nc: Sectors written: 1, unchanged: 1, total: 2
Nt: Loaded 0x12044 bytes in 499ms (about 147kB/s)
Pb: 1 of 1 ( 0) Writing sectors 1020-1020 at 0x33FC0000 with 28996 bytes
Ps: ( 0) at 33FC0000: 0 bytes - 0/28996
Ps: ( 56) at 33FC0000: 16384 bytes - 16384/28996
Nc: 33FC4000 done 56% (16384 out of 28996)
Ps: (100) at 33FC4000: 16384 bytes - 32768/28996
Nc: 33FC8000 done 100% (32768 out of 28996)
Nt: Loaded 0x7144 bytes in 550ms (about 52kB/s)
Nt: Reset target (system)
Wc: ============= SCRIPT: RT1170_reset.scp =============
Wc: This probe = 1
Wc: This TAP = 0
Wc: This core = 0
Wc: SYSTEM Reset
Wc: Wirespeed = 10000000 Hz
Wc: DpID = 6BA02477
Wc: TAP 0: 6BA02477 AP 1: APID: 24770011 ROM Table: E00FF003
Wc: TAP 0: 6BA02477 AP 2: APID: 54770002 ROM Table: 00000002
Wc: Releasing M4
Wc: DpID = 6BA02477
Wc: R15 = 0x00223104
Wc: Vector table SP/PC is the reset context.
Wc: PC = 0x3000247D
Wc: SP = 0x20040000
Wc: XPSR = 0x01000000
Wc: VTOR = 0x30002000
Wc: Set DEMCR = 0x010007F1
Ns: Stopped: Halt
Ns: restart on reset
cyberhelmer
Also, sometimes when I make changes to both cores and do a clean and rebuild of both projects only the m7 is updated with the correct code, m4 still runs an older version.
Gavin_Jia
Hi @cyberhelmer ,
Thanks for  your interest in NXP MIMXRT series!
During the failed operation, I noticed it was missing from the logs:
Releasing M4
This led to subsequent failures. We recommend updating the MCU-Link firmware and performing the following operation when debugging or programming again:
On the other hand, based on my personal experience, using JLink firmware provides better stability. If possible, try replacing the MCU-Link firmware with JLink firmware.
Gavin
cyberhelmer
I do have have latest firmware for the MCU-Link.
Resetting the probe before a flash as you suggested does not make a difference unfortunately. Still get this error most of the time:
[2025-09-18T09:09:34.034] [proc] [info] Cmd: /Users/melker/.mcuxpressotools/pemicrogdbserver/pegdbserver_console -showhardware
[2025-09-18T09:09:34.035] [proc] [info] Cmd: /Applications/SEGGER/JLink_V824/JLinkGDBServerCLExe -listprobes USB
[2025-09-18T09:09:34.035] [proc] [info] Cmd: /Applications/LinkServer_25.7.33/LinkServer probes --json
[2025-09-18T09:09:35.433] [proc] [info] Cmd: /Applications/MCUXpressoIDE_24.12.148/ide/tools/bin/arm-none-eabi-gcc --version
[2025-09-18T09:09:35.436] [proc] [info] Cmd: /Users/melker/.mcuxpressotools/arm-gnu-toolchain-13.2.Rel1-darwin-x86_64-arm-none-eabi/bin/arm-none-eabi-gcc --version
[2025-09-18T09:09:35.458] [proc] [info] Cmd: /Applications/MCUXpressoIDE_24.12.148/ide/tools/bin/arm-none-eabi-gcc --version
[2025-09-18T09:09:35.470] [proc] [info] Cmd: /Users/melker/.mcuxpressotools/arm-gnu-toolchain-13.2.Rel1-darwin-x86_64-arm-none-eabi/bin/arm-none-eabi-gcc --version
[2025-09-18T09:09:35.481] [proc] [info] Cmd: /Users/melker/.mcuxpressotools/arm-gnu-toolchain-13.2.Rel1-darwin-x86_64-arm-none-eabi/bin/arm-none-eabi-gcc --version
[2025-09-18T09:09:35.482] [proc] [info] Cmd: /Applications/MCUXpressoIDE_24.12.148/ide/tools/bin/arm-none-eabi-gcc --version
[2025-09-18T09:10:30.963] [proc] [info] Cmd: /Users/melker/.mcuxpressotools/pemicrogdbserver/pegdbserver_console -showhardware
[2025-09-18T09:10:30.965] [proc] [info] Cmd: /Applications/SEGGER/JLink_V824/JLinkGDBServerCLExe -listprobes USB
[2025-09-18T09:10:30.966] [proc] [info] Cmd: /Applications/LinkServer_25.7.33/LinkServer probes --json
[2025-09-18T09:10:32.425] [proc] [info] Cmd: /Users/melker/.mcuxpressotools/pemicrogdbserver/pegdbserver_console -showhardware
[2025-09-18T09:10:32.426] [proc] [info] Cmd: /Applications/SEGGER/JLink_V824/JLinkGDBServerCLExe -listprobes USB
[2025-09-18T09:10:32.427] [proc] [info] Cmd: /Applications/LinkServer_25.7.33/LinkServer probes --json
[2025-09-18T09:10:35.933] [proc] [info] Cmd: /Applications/LinkServer_25.7.33/LinkServer flash --probe H3RHID4AC30FD --no-boot MIMXRT1176xxxxx:MIMXRT1170-EVKB load /Users/melker/CodeProjects/AudioBox/code/code_primary_core/armgcc/flexspi_nor_debug/freertos_message_buffers_primary_core.elf
[2025-09-18T09:10:39.480] [proc] [error] /Applications/LinkServer_25.7.33/LinkServer exited with code 255
[2025-09-18T09:10:39.480] [proc] [error] Firmware update `check`: not required - forced update can be performed using: `./LinkServer probe #1 update forced`
Nc: Found generic directory XML file in /var/folders/8x/1csc34zn7pq1_ksyf9k3x24h0000gn/T/tmps1gdrldt/crt_directory.xml
Wc: DpID = 6BA02477
Wc: DpID = 6BA02477
Nc: USB Path: 0014:0003:00
Pc: ( 50) CPU ID
Nc: After error Nn(05). Wire ACK Fault in DAP access -
Nc: Failed to read address register in DAP - Nn(05). Wire ACK Fault in DAP access
Nc: flash driver polled mailbox (8 bytes at 0x2000A840) read failed (on poll 1/301) - retrying after 1ms - rc Em(17). Debug port inaccessible after access at location 0x2000A840
Wc: flash driver polled mailbox (8 bytes at 0x2000A840) read failed (on poll 1/301) - halting for postmortem - rc Em(17). Debug port inaccessible after access at location 0x2000A840
Wc: failed to halt target for postmortem - rc Nn(05). Wire ACK Fault in DAP access
Nc: failed to read registers - Nn(05). Wire ACK Fault in DAP access
Nc: Flash Driver V.2 startup failed - rc Em(17). Debug port inaccessible after access at location 0x2000A840
Ed:05: File 'freertos_message_buffers_primary_core.elf' load failure: Em(17). Debug port inaccessible after access at location 0x2000A840
Also I've noticed that when when the flashing actually succeeds the M4 core is most of the time one or more versions behind even though I do a clean and rebuild of both projects before flashing. However sometimes, seemingly randomly both cores does get the correct version.
This is the build log:
Executing task: CMake: build M4
Workspace is /Users/melker/CodeProjects/AudioBox/code/code_secondary_core
build task started....
/Users/melker/.mcuxpressotools/cmake-3.30.0-macos10.10-universal/CMake.app/Contents/bin/cmake --build /Users/melker/CodeProjects/AudioBox/code/code_secondary_core/armgcc/debug --clean-first --target all --
[1/2] Cleaning additional files...
[2/2] Cleaning all built files...
Cleaning... 39 files.
[1/39] Building ASM object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/gcc/startup_MIMXRT1176_cm4.S.obj
[2/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/system_MIMXRT1176_cm4.c.obj
[3/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_common_arm.c.obj
[4/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_gpio.c.obj
[5/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_common.c.obj
[6/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/code/code_secondary_core/hardware_init.c.obj
[7/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/code/code_secondary_core/pin_mux.c.obj
[8/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_anatop_ai.c.obj
[9/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/code/code_secondary_core/board.c.obj
[10/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_mu.c.obj
[11/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/components/uart/fsl_adapter_lpuart.c.obj
[12/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_gpc.c.obj
[13/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/code/code_secondary_core/main.c.obj
[14/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/rtos/freertos/freertos-kernel/croutine.c.obj
[15/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/code/code_secondary_core/clock_config.c.obj
[16/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/rtos/freertos/freertos-kernel/list.c.obj
[17/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_pgmc.c.obj
[18/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/cm4/fsl_cache.c.obj
[19/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/rtos/freertos/freertos-kernel/timers.c.obj
[20/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/rtos/freertos/freertos-kernel/event_groups.c.obj
[21/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/rtos/freertos/freertos-kernel/portable/GCC/ARM_CM4F/port.c.obj
[22/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_dcdc.c.obj
[23/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/middleware/multicore/mcmgr/src/mcmgr.c.obj
[24/39] Building ASM object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/utilities/fsl_memcpy.S.obj
[25/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/utilities/fsl_sbrk.c.obj
[26/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/utilities/fsl_syscall_stub.c.obj
[27/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/rtos/freertos/freertos-kernel/stream_buffer.c.obj
[28/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/rtos/freertos/freertos-kernel/queue.c.obj
[29/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_lpuart.c.obj
[30/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_clock.c.obj
[31/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_soc_src.c.obj
[32/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/rtos/freertos/freertos-kernel/tasks.c.obj
[33/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/middleware/multicore/mcmgr/src/mcmgr_mu_internal.c.obj
[34/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/drivers/fsl_pmu.c.obj
[35/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/middleware/multicore/mcmgr/src/mcmgr_internal_core_api_imxrt1170.c.obj
[36/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/utilities/debug_console_lite/fsl_assert.c.obj
[37/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/utilities/debug_console_lite/fsl_debug_console.c.obj
[38/39] Building C object CMakeFiles/freertos_message_buffers_secondary_core.elf.dir/Users/melker/CodeProjects/AudioBox/sdk/SDK_25_03_00_MIMXRT1170-EVKB/devices/MIMXRT1176/utilities/str/fsl_str.c.obj
[39/39] Linking C executable freertos_message_buffers_secondary_core.elf
Memory region Used Size Region Size %age Used
m_interrupts: 1 KB 1 KB 100.00%
m_text: 27876 B 127 KB 21.44%
m_data: 3280 B 127 KB 2.52%
m_ncache: 0 GB 256 KB 0.00%
m_data2: 0 GB 256 KB 0.00%
m_heap: 1 KB 1 KB 100.00%
rpmsg_sh_mem: 6 KB 8 KB 75.00%
build finished successfully.
* Terminal will be reused by tasks, press any key to close it.
* Executing task: CMake: build
Workspace is /Users/melker/CodeProjects/AudioBox/code/code_primary_core
/Users/melker/.mcuxpressotools/cmake-3.30.0-macos10.10-universal/CMake.app/Contents/bin/cmake --build /Users/melker/CodeProjects/AudioBox/code/code_primary_core/armgcc/flexspi_nor_debug --target all --
[1/2] Building C object CMakeFiles/freertos_message_buffers_primary_core.elf.dir/Users/melker/CodeProjects/AudioBox/code/code_primary_core/main.c.obj
[2/2] Linking C executable freertos_message_buffers_primary_core.elf
m_flash_config: 512 B 3 KB 16.67%
m_ivt: 48 B 4 KB 1.17%
m_text: 72188 B 65271 KB 0.11%
m_qacode: 0 GB 256 KB 0.00%
m_data: 22968 B 256 KB 8.76%
m_data2: 0 GB 504 KB 0.00%
m_core1_image: 28996 B 256 KB 11.06%
What could be causing this?
I will try J-link firmware and see if that helps.
%3CLINGO-SUB%20id%3D%22lingo-sub-2171441%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERT1170%20EVKB%20Multicore%20project%20and%20LinkServer%20Flash%20programmer%20not%20working%20(mcuxpresso%20vs%20code)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2171441%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3EI%20have%20a%20project%20based%20on%20the%20freeRTOS%20multicore%20message%20buffers%20example%20from%20nxp%20SDK.%26nbsp%3B%3CBR%20%2F%3EThere%20seem%20to%20be%20a%20problem%20with%20the%20LinkServer%20Flash%20Programmer%20in%20the%20mcuxpresso%20for%20vs%20code%20extension.%3CBR%20%2F%3E%3CBR%20%2F%3EI%20am%20sometimes%20able%20to%20flash%20the%20m7%20firmware%20which%20loads%20the%20M4%20to%20the%20correct%20ocram%20adress.%20Very%20often%20the%20flash%20programmer%20fails%20and%20the%20board%20stops%20running%20it's%20code.%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EWhat%20is%20the%20cause%20of%20this%20and%20how%20can%20I%20fix%20it%20so%20that%20I'm%20always%20able%20to%20flash%20the%20m7%20correctly%3F%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EThanks!%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSTRONG%3ELog%20when%20failing%3A%26nbsp%3B%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T00%3A58%3A40.377%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FUsers%2Fmelker%2F.mcuxpressotools%2Fpemicrogdbserver%2Fpegdbserver_console%20-showhardware%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T00%3A58%3A40.379%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FApplications%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E33%3C%2FSPAN%3E%3CSPAN%3E%2FLinkServer%20probes%20--json%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T00%3A58%3A40.380%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FApplications%2FSEGGER%2FJLink_V824%2FJLinkGDBServerCLExe%20-listprobes%20USB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T00%3A58%3A41.772%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FUsers%2Fmelker%2F.mcuxpressotools%2Fpemicrogdbserver%2Fpegdbserver_console%20-showhardware%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T00%3A58%3A41.773%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FApplications%2FSEGGER%2FJLink_V824%2FJLinkGDBServerCLExe%20-listprobes%20USB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T00%3A58%3A41.773%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FApplications%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E33%3C%2FSPAN%3E%3CSPAN%3E%2FLinkServer%20probes%20--json%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T00%3A58%3A44.950%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FApplications%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E33%3C%2FSPAN%3E%3CSPAN%3E%2FLinkServer%20flash%20--probe%20H3RHID4AC30FD%20--no-boot%20MIMXRT1176xxxxx%3AMIMXR%3C%2FSPAN%3E%3CSPAN%3ET1170%3C%2FSPAN%3E%3CSPAN%3E-EVKB%20load%20%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_primary_core%2Farmgcc%2Fflexspi_nor_debug%2Ffreertos_message_buffers_primary_core.elf%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T00%3A58%3A48.405%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Berror%5D%3C%2FSPAN%3E%3CSPAN%3E%20%2FApplications%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E33%3C%2FSPAN%3E%3CSPAN%3E%2FLinkServer%20exited%20with%20code%20%3C%2FSPAN%3E%3CSPAN%3E255%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T00%3A58%3A48.405%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Berror%5D%3C%2FSPAN%3E%3CSPAN%3E%20Firmware%20update%20%60check%60%3A%20not%20required%20-%20forced%20update%20can%20be%20performed%20using%3A%20%60.%2FLinkServer%20probe%20%23%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%20update%20forced%60%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENs%3A%20LinkServer%20RedlinkMulti%20Driver%20%3C%2FSPAN%3E%3CSPAN%3Ev25.7%3C%2FSPAN%3E%3CSPAN%3E%20(Jul%20%3C%2FSPAN%3E%3CSPAN%3E21%3C%2FSPAN%3E%20%3CSPAN%3E2025%3C%2FSPAN%3E%20%3CSPAN%3E20%3A37%3A00%3C%2FSPAN%3E%3CSPAN%3E%20-%20crt_emu_cm_redlink%20build%20%3C%2FSPAN%3E%3CSPAN%3E1038%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPc%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E)%20Reading%20remote%20configuration%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc(%3C%2FSPAN%3E%3CSPAN%3E03%3C%2FSPAN%3E%3CSPAN%3E).%20No%20cache%20support.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Found%20generic%20directory%20XML%20file%20in%20%2Fvar%2Ffolders%2F8x%2F1csc34zn7pq1_ksyf9k3x24h0000gn%2FT%2Ftmp3tmcfgxp%2Fcrt_directory.xml%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPc%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3CSPAN%3E)%20Remote%20configuration%20complete%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Reconnected%20to%20existing%20LinkServer%20process.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20SCRIPT%3A%20%3C%2FSPAN%3E%3CSPAN%3ERT1170_connect_M7_wake_M4.scp%3C%2FSPAN%3E%3CSPAN%3E%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20R%3C%2FSPAN%3E%3CSPAN%3ET1170%3C%2FSPAN%3E%3CSPAN%3E%20Connect%20M7%20and%20Wake%20M4%20Script%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20DpID%20%3D%206BA02477%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20APID%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0x84770001%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20Setting%20M4%20spin%20code%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20Setting%20M4%20clock%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20Resetting%20M4%20core%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20View%20cores%20on%20the%20DAP%20AP%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20DpID%20%3D%206BA02477%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20TAP%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3A%206BA02477%20Core%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3A%20M7%20APID%3A%20%3C%2FSPAN%3E%3CSPAN%3E84770001%3C%2FSPAN%3E%3CSPAN%3E%20ROM%20Table%3A%20E00FD003*%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20TAP%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3A%206BA02477%20Core%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%3A%20M4%20APID%3A%20%3C%2FSPAN%3E%3CSPAN%3E24770011%3C%2FSPAN%3E%3CSPAN%3E%20ROM%20Table%3A%20E00FF003%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20END%20SCRIPT%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Probe%20Firmware%3A%20MCU-LINK%20on-board%20(r0E2)%20CMSIS-DAP%20%3C%2FSPAN%3E%3CSPAN%3EV3.160%3C%2FSPAN%3E%3CSPAN%3E%20(NXP%20Semiconductors)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Serial%20Number%3A%20H3RHID4AC30FD%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20VID%3APID%3A%20%3C%2FSPAN%3E%3CSPAN%3E1FC9%3A0143%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20USB%20Path%3A%20%3C%2FSPAN%3E%3CSPAN%3E0014%3A0002%3A00%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Using%20memory%20from%20core%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%20after%20searching%20for%20a%20good%20core%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPc%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E30%3C%2FSPAN%3E%3CSPAN%3E)%20Emulator%20Connected%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPc%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E40%3C%2FSPAN%3E%3CSPAN%3E)%20%3C%2FSPAN%3E%3CSPAN%3EDebug%3C%2FSPAN%3E%3CSPAN%3E%20Halt%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPc%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E50%3C%2FSPAN%3E%3CSPAN%3E)%20CPU%20ID%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20debug%20interface%20type%20%3D%20CoreSight%20DP%20(DAP%20DP%20ID%206BA02477)%20over%20SWD%20TAP%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20processor%20type%20%3D%20Cortex-M7%20(CPU%20ID%2000000C27)%20on%20DAP%20AP%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20number%20of%20h%2Fw%20breakpoints%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E8%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20number%20of%20flash%20patches%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20number%20of%20h%2Fw%20watchpoints%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E4%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Probe(%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3CLI-EMOJI%20id%3D%22lia_disappointed-face%22%20title%3D%22%3Adisappointed_face%3A%22%3E%3C%2FLI-EMOJI%3E%20Connected%26amp%3BReset.%20DpID%3A%206BA02477.%20CpuID%3A%2000000C27.%20%3C%2FSPAN%3E%3CSPAN%3EInfo%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3CNONE%3E%3C%2FNONE%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%3C%2FSPAN%3E%3CSPAN%3EDebug%3C%2FSPAN%3E%3CSPAN%3E%20protocol%3A%20SWD.%20RTCK%3A%20Disabled.%20Vector%20catch%3A%20Disabled.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENs%3A%20Content%20of%20CoreSight%20%3C%2FSPAN%3E%3CSPAN%3EDebug%3C%2FSPAN%3E%3CSPAN%3E%20ROM(s)%3A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20RBASE%20E00FD000%3A%20CID%20B105100D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E000008E88C%3C%2FSPAN%3E%3CSPAN%3E%20ROM%20(type%20%3C%2FSPAN%3E%3CSPAN%3E0x1%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%20E00FE000%3A%20CID%20B105100D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04000BB4C8%3C%2FSPAN%3E%3CSPAN%3E%20ROM%20(type%20%3C%2FSPAN%3E%3CSPAN%3E0x1%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%20%3C%2FSPAN%3E%3CSPAN%3E2%3C%2FSPAN%3E%3CSPAN%3E%20E00FF000%3A%20CID%20B105100D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04000BB4C7%3C%2FSPAN%3E%3CSPAN%3E%20ROM%20(type%20%3C%2FSPAN%3E%3CSPAN%3E0x1%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%20%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3E%20E000E000%3A%20CID%20B105E00D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04000BB00C%3C%2FSPAN%3E%3CSPAN%3E%20Gen%20SCS%20(type%20%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%20%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3E%20E0001000%3A%20CID%20B105E00D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04000BB002%3C%2FSPAN%3E%3CSPAN%3E%20Gen%20DWT%20(type%20%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%20%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3E%20E0002000%3A%20CID%20B105E00D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04000BB00E%3C%2FSPAN%3E%3CSPAN%3E%20Gen%20(type%20%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%20%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3E%20E0000000%3A%20CID%20B105E00D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04000BB001%3C%2FSPAN%3E%3CSPAN%3E%20Gen%20ITM%20(type%20%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%20%3C%2FSPAN%3E%3CSPAN%3E2%3C%2FSPAN%3E%3CSPAN%3E%20E0041000%3A%20CID%20B105900D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04001BB975%3C%2FSPAN%3E%3CSPAN%3E%20CSt%20ARM%20%3C%2FSPAN%3E%3CSPAN%3EETMv4.0%3C%2FSPAN%3E%3CSPAN%3E%20type%20%3C%2FSPAN%3E%3CSPAN%3E0x13%3C%2FSPAN%3E%3CSPAN%3E%20Trace%20Source%20-%20Core%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%20%3C%2FSPAN%3E%3CSPAN%3E2%3C%2FSPAN%3E%3CSPAN%3E%20E0042000%3A%20CID%20B105900D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04004BB906%3C%2FSPAN%3E%3CSPAN%3E%20CSt%20type%20%3C%2FSPAN%3E%3CSPAN%3E0x14%3C%2FSPAN%3E%20%3CSPAN%3EDebug%3C%2FSPAN%3E%3CSPAN%3E%20Control%20-%20Trigger%2C%20%3C%2FSPAN%3E%3CSPAN%3Ee.g%3C%2FSPAN%3E%3CSPAN%3E.%20ECT%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%20E0043000%3A%20CID%20B105900D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04001BB908%3C%2FSPAN%3E%3CSPAN%3E%20CSt%20CSTF%20type%20%3C%2FSPAN%3E%3CSPAN%3E0x12%3C%2FSPAN%3E%3CSPAN%3E%20Trace%20Link%20-%20Trace%20funnel%2Frouter%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20NXP%3A%20MIMXRT1176xxxxx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20DAP%20stride%20is%20%3C%2FSPAN%3E%3CSPAN%3E1024%3C%2FSPAN%3E%3CSPAN%3E%20bytes%20(%3C%2FSPAN%3E%3CSPAN%3E256%3C%2FSPAN%3E%3CSPAN%3E%20words)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Inspected%20%3C%2FSPAN%3E%3CSPAN%3Ev.2%3C%2FSPAN%3E%3CSPAN%3E%20External%20Flash%20Device%20on%20SPI%20using%20SFDP%20JEDEC%20ID%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Image%20%3C%2FSPAN%3E%3CSPAN%3E'iMXRT1170_SFDP_FlexSPI1_A_QSPI%20Jul%2021%202025%2018%3A35%3A07'%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Opening%20flash%20driver%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Sending%20VECTRESET%20to%20run%20flash%20driver%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Flash%20variant%20%3C%2FSPAN%3E%3CSPAN%3E'iMXRT1170_SFDP_FlexSPI1_A_QSPI%20Jul%2021%202025%2018%3A35%3A07'%3C%2FSPAN%3E%3CSPAN%3E%20detected%20(64MB%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E1024%3C%2FSPAN%3E%3CSPAN%3E*64K%20at%20%3C%2FSPAN%3E%3CSPAN%3E0x30000000%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Closing%20flash%20driver%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPc%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E65%3C%2FSPAN%3E%3CSPAN%3E)%20Chip%20Setup%20Complete%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPc%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E70%3C%2FSPAN%3E%3CSPAN%3E)%20License%20Check%20Complete%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%3A%20Loading%20%3C%2FSPAN%3E%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%3CSPAN%3E%20ELF%20%3C%2FSPAN%3E%3CSPAN%3E0x30000400%3C%2FSPAN%3E%3CSPAN%3E%20len%20%3C%2FSPAN%3E%3CSPAN%3E0x200%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Opening%20flash%20driver%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3CSPAN%3E%20(already%20resident)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Sending%20VECTRESET%20to%20run%20flash%20driver%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Warning%20-%20failed%20to%20start%20flash%20driver%20(at%20%3C%2FSPAN%3E%3CSPAN%3E0x2000009D%3C%2FSPAN%3E%3CSPAN%3E%3F)%20-%20rc%20Nn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E).%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Flash%20Driver%20%3C%2FSPAN%3E%3CSPAN%3EV.2%3C%2FSPAN%3E%3CSPAN%3E%20startup%20failed%20-%20rc%20Nn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E).%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%3A%20(%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E)%20Writing%20Flash%20ended%20with%20an%20error.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EEd%3A05%3C%2FSPAN%3E%3CSPAN%3E%3A%20File%20%3C%2FSPAN%3E%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%3CSPAN%3E%20load%20failure%3A%20Nn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E).%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%3A%20Loading%20%3C%2FSPAN%3E%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%3CSPAN%3E%20ELF%20%3C%2FSPAN%3E%3CSPAN%3E0x30001000%3C%2FSPAN%3E%3CSPAN%3E%20len%20%3C%2FSPAN%3E%3CSPAN%3E0x30%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Opening%20flash%20driver%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20request%20to%20clear%20DAP%20error%20failed%20-%20status%20%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%3A%20(%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E)%20Writing%20Flash%20ended%20with%20an%20error.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EEd%3A05%3C%2FSPAN%3E%3CSPAN%3E%3A%20File%20%3C%2FSPAN%3E%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%3CSPAN%3E%20load%20failure%3A%20Nn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E).%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%3A%20Loading%20%3C%2FSPAN%3E%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%3CSPAN%3E%20ELF%20%3C%2FSPAN%3E%3CSPAN%3E0x30002000%3C%2FSPAN%3E%3CSPAN%3E%20len%20%3C%2FSPAN%3E%3CSPAN%3E0x12044%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Opening%20flash%20driver%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20request%20to%20clear%20DAP%20error%20failed%20-%20status%20%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%3A%20(%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E)%20Writing%20Flash%20ended%20with%20an%20error.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EEd%3A05%3C%2FSPAN%3E%3CSPAN%3E%3A%20File%20%3C%2FSPAN%3E%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%3CSPAN%3E%20load%20failure%3A%20Nn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E).%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%3A%20Loading%20%3C%2FSPAN%3E%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%3CSPAN%3E%20ELF%20%3C%2FSPAN%3E%3CSPAN%3E0x33FC0000%3C%2FSPAN%3E%3CSPAN%3E%20len%20%3C%2FSPAN%3E%3CSPAN%3E0x7144%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Opening%20flash%20driver%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20request%20to%20clear%20DAP%20error%20failed%20-%20status%20%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%3A%20(%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E)%20Writing%20Flash%20ended%20with%20an%20error.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EEd%3A05%3C%2FSPAN%3E%3CSPAN%3E%3A%20File%20%3C%2FSPAN%3E%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%3CSPAN%3E%20load%20failure%3A%20Nn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E).%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPc%3A%20(%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E)%20Target%20Operation%20Failed%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20request%20to%20clear%20DAP%20error%20failed%20-%20status%20%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20request%20to%20clear%20DAP%20error%20failed%20-%20status%20%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20error%20closing%20down%20debug%20session%20-%20Nn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E).%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3EINFO%3C%2FSPAN%3E%3CSPAN%3E%3A%20Exact%20match%20for%20MIMXRT1176xxxxx%3AMIMXR%3C%2FSPAN%3E%3CSPAN%3ET1170%3C%2FSPAN%3E%3CSPAN%3E-EVKB%20found%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EINFO%3C%2FSPAN%3E%3CSPAN%3E%3A%20Selected%20device%20MIMXRT1176xxxxx%3AMIMXR%3C%2FSPAN%3E%3CSPAN%3ET1170%3C%2FSPAN%3E%3CSPAN%3E-EVKB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EINFO%3C%2FSPAN%3E%3CSPAN%3E%3A%20Getting%20available%20probes%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EINFO%3C%2FSPAN%3E%3CSPAN%3E%3A%20Selecting%20probe%20by%20serial%20substring%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EINFO%3C%2FSPAN%3E%3CSPAN%3E%3A%20Selected%20probe%20%23%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%20H3RHID4AC30FD%20(MCU-LINK%20on-board%20(r0E2)%20CMSIS-DAP%20%3C%2FSPAN%3E%3CSPAN%3EV3.160%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EINFO%3C%2FSPAN%3E%3CSPAN%3E%3A%20MCU-Link%20firmware%20update%20%60check%60%3A%20Probe%20(%5BH3RHID4AC30FD%5D%20%5BMCU-LINK%20on-board%20(r0E2)%20CMSIS-DAP%20%3C%2FSPAN%3E%3CSPAN%3EV3.160%3C%2FSPAN%3E%3CSPAN%3E%5D)%20is%20already%20running%20the%20same%20firmware%20version%20as%20the%20included%20firmware%20version%20%5B%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E160%3C%2FSPAN%3E%3CSPAN%3E%5D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECRITICAL%3C%2FSPAN%3E%3CSPAN%3E%3A%20Critical%20error%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EERRMSG%3A%20%3C%2FSPAN%3E%3CSPAN%3EException%3C%2FSPAN%3E%3CSPAN%3E%3A%20Flash%20operation%20exited%20with%20code%20%3C%2FSPAN%3E%3CSPAN%3E%3CSPAN%3E1%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSTRONG%3EThis%20is%20the%20log%20when%20the%20flashing%20actually%20succeeds%3A%26nbsp%3B%3C%2FSTRONG%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T01%3A03%3A12.927%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FUsers%2Fmelker%2F.mcuxpressotools%2Fpemicrogdbserver%2Fpegdbserver_console%20-showhardware%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T01%3A03%3A12.928%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FApplications%2FSEGGER%2FJLink_V824%2FJLinkGDBServerCLExe%20-listprobes%20USB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T01%3A03%3A12.928%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FApplications%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E33%3C%2FSPAN%3E%3CSPAN%3E%2FLinkServer%20probes%20--json%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T01%3A03%3A14.329%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FUsers%2Fmelker%2F.mcuxpressotools%2Fpemicrogdbserver%2Fpegdbserver_console%20-showhardware%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T01%3A03%3A14.338%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FApplications%2FSEGGER%2FJLink_V824%2FJLinkGDBServerCLExe%20-listprobes%20USB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T01%3A03%3A14.346%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FApplications%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E33%3C%2FSPAN%3E%3CSPAN%3E%2FLinkServer%20probes%20--json%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T01%3A03%3A17.511%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FApplications%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E33%3C%2FSPAN%3E%3CSPAN%3E%2FLinkServer%20flash%20--probe%20H3RHID4AC30FD%20--no-boot%20MIMXRT1176xxxxx%3AMIMXR%3C%2FSPAN%3E%3CSPAN%3ET1170%3C%2FSPAN%3E%3CSPAN%3E-EVKB%20load%20%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_primary_core%2Farmgcc%2Fflexspi_nor_debug%2Ffreertos_message_buffers_primary_core.elf%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T01%3A03%3A23.784%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%20%3CSPAN%3EINFO%3C%2FSPAN%3E%3CSPAN%3E%3A%20Exact%20match%20for%20MIMXRT1176xxxxx%3AMIMXR%3C%2FSPAN%3E%3CSPAN%3ET1170%3C%2FSPAN%3E%3CSPAN%3E-EVKB%20found%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EINFO%3C%2FSPAN%3E%3CSPAN%3E%3A%20Selected%20device%20MIMXRT1176xxxxx%3AMIMXR%3C%2FSPAN%3E%3CSPAN%3ET1170%3C%2FSPAN%3E%3CSPAN%3E-EVKB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EINFO%3C%2FSPAN%3E%3CSPAN%3E%3A%20Getting%20available%20probes%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EINFO%3C%2FSPAN%3E%3CSPAN%3E%3A%20Selecting%20probe%20by%20serial%20substring%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EINFO%3C%2FSPAN%3E%3CSPAN%3E%3A%20Selected%20probe%20%23%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%20H3RHID4AC30FD%20(MCU-LINK%20on-board%20(r0E2)%20CMSIS-DAP%20%3C%2FSPAN%3E%3CSPAN%3EV3.160%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EINFO%3C%2FSPAN%3E%3CSPAN%3E%3A%20MCU-Link%20firmware%20update%20%60check%60%3A%20Probe%20(%5BH3RHID4AC30FD%5D%20%5BMCU-LINK%20on-board%20(r0E2)%20CMSIS-DAP%20%3C%2FSPAN%3E%3CSPAN%3EV3.160%3C%2FSPAN%3E%3CSPAN%3E%5D)%20is%20already%20running%20the%20same%20firmware%20version%20as%20the%20included%20firmware%20version%20%5B%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E160%3C%2FSPAN%3E%3CSPAN%3E%5D%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T01%3A03%3A23.784%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5BLinkServer%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20LinkServer%20flash%20operation%20completed%20successfully%3A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EFirmware%20update%20%60check%60%3A%20not%20required%20-%20forced%20update%20can%20be%20performed%20using%3A%20%60.%2FLinkServer%20probe%20%23%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%20update%20forced%60%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENs%3A%20LinkServer%20RedlinkMulti%20Driver%20%3C%2FSPAN%3E%3CSPAN%3Ev25.7%3C%2FSPAN%3E%3CSPAN%3E%20(Jul%20%3C%2FSPAN%3E%3CSPAN%3E21%3C%2FSPAN%3E%20%3CSPAN%3E2025%3C%2FSPAN%3E%20%3CSPAN%3E20%3A37%3A00%3C%2FSPAN%3E%3CSPAN%3E%20-%20crt_emu_cm_redlink%20build%20%3C%2FSPAN%3E%3CSPAN%3E1038%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPc%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E)%20Reading%20remote%20configuration%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc(%3C%2FSPAN%3E%3CSPAN%3E03%3C%2FSPAN%3E%3CSPAN%3E).%20No%20cache%20support.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Found%20generic%20directory%20XML%20file%20in%20%2Fvar%2Ffolders%2F8x%2F1csc34zn7pq1_ksyf9k3x24h0000gn%2FT%2Ftmpci6yg1l_%2Fcrt_directory.xml%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPc%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3CSPAN%3E)%20Remote%20configuration%20complete%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Reconnected%20to%20existing%20LinkServer%20process.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20SCRIPT%3A%20%3C%2FSPAN%3E%3CSPAN%3ERT1170_connect_M7_wake_M4.scp%3C%2FSPAN%3E%3CSPAN%3E%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20R%3C%2FSPAN%3E%3CSPAN%3ET1170%3C%2FSPAN%3E%3CSPAN%3E%20Connect%20M7%20and%20Wake%20M4%20Script%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20DpID%20%3D%206BA02477%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20APID%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0x84770001%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20Setting%20M4%20spin%20code%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20Setting%20M4%20clock%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20Resetting%20M4%20core%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20Releasing%20M4%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20View%20cores%20on%20the%20DAP%20AP%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20DpID%20%3D%206BA02477%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20TAP%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3A%206BA02477%20Core%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3A%20M7%20APID%3A%20%3C%2FSPAN%3E%3CSPAN%3E84770001%3C%2FSPAN%3E%3CSPAN%3E%20ROM%20Table%3A%20E00FD003*%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20TAP%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3A%206BA02477%20Core%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%3A%20M4%20APID%3A%20%3C%2FSPAN%3E%3CSPAN%3E24770011%3C%2FSPAN%3E%3CSPAN%3E%20ROM%20Table%3A%20E00FF003%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20END%20SCRIPT%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Probe%20Firmware%3A%20MCU-LINK%20on-board%20(r0E2)%20CMSIS-DAP%20%3C%2FSPAN%3E%3CSPAN%3EV3.160%3C%2FSPAN%3E%3CSPAN%3E%20(NXP%20Semiconductors)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Serial%20Number%3A%20H3RHID4AC30FD%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20VID%3APID%3A%20%3C%2FSPAN%3E%3CSPAN%3E1FC9%3A0143%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20USB%20Path%3A%20%3C%2FSPAN%3E%3CSPAN%3E0014%3A0002%3A00%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Using%20memory%20from%20core%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%20after%20searching%20for%20a%20good%20core%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPc%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E30%3C%2FSPAN%3E%3CSPAN%3E)%20Emulator%20Connected%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPc%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E40%3C%2FSPAN%3E%3CSPAN%3E)%20%3C%2FSPAN%3E%3CSPAN%3EDebug%3C%2FSPAN%3E%3CSPAN%3E%20Halt%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPc%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E50%3C%2FSPAN%3E%3CSPAN%3E)%20CPU%20ID%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20debug%20interface%20type%20%3D%20CoreSight%20DP%20(DAP%20DP%20ID%206BA02477)%20over%20SWD%20TAP%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20processor%20type%20%3D%20Cortex-M7%20(CPU%20ID%2000000C27)%20on%20DAP%20AP%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20number%20of%20h%2Fw%20breakpoints%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E8%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20number%20of%20flash%20patches%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20number%20of%20h%2Fw%20watchpoints%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E4%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Probe(%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3CLI-EMOJI%20id%3D%22lia_disappointed-face%22%20title%3D%22%3Adisappointed_face%3A%22%3E%3C%2FLI-EMOJI%3E%20Connected%26amp%3BReset.%20DpID%3A%206BA02477.%20CpuID%3A%2000000C27.%20%3C%2FSPAN%3E%3CSPAN%3EInfo%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3CNONE%3E%3C%2FNONE%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%3C%2FSPAN%3E%3CSPAN%3EDebug%3C%2FSPAN%3E%3CSPAN%3E%20protocol%3A%20SWD.%20RTCK%3A%20Disabled.%20Vector%20catch%3A%20Disabled.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENs%3A%20Content%20of%20CoreSight%20%3C%2FSPAN%3E%3CSPAN%3EDebug%3C%2FSPAN%3E%3CSPAN%3E%20ROM(s)%3A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20RBASE%20E00FD000%3A%20CID%20B105100D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E000008E88C%3C%2FSPAN%3E%3CSPAN%3E%20ROM%20(type%20%3C%2FSPAN%3E%3CSPAN%3E0x1%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%20E00FE000%3A%20CID%20B105100D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04000BB4C8%3C%2FSPAN%3E%3CSPAN%3E%20ROM%20(type%20%3C%2FSPAN%3E%3CSPAN%3E0x1%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%20%3C%2FSPAN%3E%3CSPAN%3E2%3C%2FSPAN%3E%3CSPAN%3E%20E00FF000%3A%20CID%20B105100D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04000BB4C7%3C%2FSPAN%3E%3CSPAN%3E%20ROM%20(type%20%3C%2FSPAN%3E%3CSPAN%3E0x1%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%20%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3E%20E000E000%3A%20CID%20B105E00D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04000BB00C%3C%2FSPAN%3E%3CSPAN%3E%20Gen%20SCS%20(type%20%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%20%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3E%20E0001000%3A%20CID%20B105E00D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04000BB002%3C%2FSPAN%3E%3CSPAN%3E%20Gen%20DWT%20(type%20%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%20%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3E%20E0002000%3A%20CID%20B105E00D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04000BB00E%3C%2FSPAN%3E%3CSPAN%3E%20Gen%20(type%20%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%20%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3E%20E0000000%3A%20CID%20B105E00D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04000BB001%3C%2FSPAN%3E%3CSPAN%3E%20Gen%20ITM%20(type%20%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%20%3C%2FSPAN%3E%3CSPAN%3E2%3C%2FSPAN%3E%3CSPAN%3E%20E0041000%3A%20CID%20B105900D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04001BB975%3C%2FSPAN%3E%3CSPAN%3E%20CSt%20ARM%20%3C%2FSPAN%3E%3CSPAN%3EETMv4.0%3C%2FSPAN%3E%3CSPAN%3E%20type%20%3C%2FSPAN%3E%3CSPAN%3E0x13%3C%2FSPAN%3E%3CSPAN%3E%20Trace%20Source%20-%20Core%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%20%3C%2FSPAN%3E%3CSPAN%3E2%3C%2FSPAN%3E%3CSPAN%3E%20E0042000%3A%20CID%20B105900D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04004BB906%3C%2FSPAN%3E%3CSPAN%3E%20CSt%20type%20%3C%2FSPAN%3E%3CSPAN%3E0x14%3C%2FSPAN%3E%20%3CSPAN%3EDebug%3C%2FSPAN%3E%3CSPAN%3E%20Control%20-%20Trigger%2C%20%3C%2FSPAN%3E%3CSPAN%3Ee.g%3C%2FSPAN%3E%3CSPAN%3E.%20ECT%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%20E0043000%3A%20CID%20B105900D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04001BB908%3C%2FSPAN%3E%3CSPAN%3E%20CSt%20CSTF%20type%20%3C%2FSPAN%3E%3CSPAN%3E0x12%3C%2FSPAN%3E%3CSPAN%3E%20Trace%20Link%20-%20Trace%20funnel%2Frouter%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20NXP%3A%20MIMXRT1176xxxxx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20DAP%20stride%20is%20%3C%2FSPAN%3E%3CSPAN%3E1024%3C%2FSPAN%3E%3CSPAN%3E%20bytes%20(%3C%2FSPAN%3E%3CSPAN%3E256%3C%2FSPAN%3E%3CSPAN%3E%20words)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Inspected%20%3C%2FSPAN%3E%3CSPAN%3Ev.2%3C%2FSPAN%3E%3CSPAN%3E%20External%20Flash%20Device%20on%20SPI%20using%20SFDP%20JEDEC%20ID%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Image%20%3C%2FSPAN%3E%3CSPAN%3E'iMXRT1170_SFDP_FlexSPI1_A_QSPI%20Jul%2021%202025%2018%3A35%3A07'%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Opening%20flash%20driver%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Sending%20VECTRESET%20to%20run%20flash%20driver%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Flash%20variant%20%3C%2FSPAN%3E%3CSPAN%3E'iMXRT1170_SFDP_FlexSPI1_A_QSPI%20Jul%2021%202025%2018%3A35%3A07'%3C%2FSPAN%3E%3CSPAN%3E%20detected%20(64MB%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E1024%3C%2FSPAN%3E%3CSPAN%3E*64K%20at%20%3C%2FSPAN%3E%3CSPAN%3E0x30000000%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Closing%20flash%20driver%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPc%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E65%3C%2FSPAN%3E%3CSPAN%3E)%20Chip%20Setup%20Complete%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPc%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E70%3C%2FSPAN%3E%3CSPAN%3E)%20License%20Check%20Complete%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%3A%20Loading%20%3C%2FSPAN%3E%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%3CSPAN%3E%20ELF%20%3C%2FSPAN%3E%3CSPAN%3E0x30000400%3C%2FSPAN%3E%3CSPAN%3E%20len%20%3C%2FSPAN%3E%3CSPAN%3E0x200%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Opening%20flash%20driver%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3CSPAN%3E%20(already%20resident)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Sending%20VECTRESET%20to%20run%20flash%20driver%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Flash%20variant%20%3C%2FSPAN%3E%3CSPAN%3E'iMXRT1170_SFDP_FlexSPI1_A_QSPI%20Jul%2021%202025%2018%3A35%3A07'%3C%2FSPAN%3E%3CSPAN%3E%20detected%20(64MB%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E1024%3C%2FSPAN%3E%3CSPAN%3E*64K%20at%20%3C%2FSPAN%3E%3CSPAN%3E0x30000000%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%3A%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%20of%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%20(%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E)%20Writing%20sectors%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E-%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%20at%20%3C%2FSPAN%3E%3CSPAN%3E0x30000400%3C%2FSPAN%3E%3CSPAN%3E%20with%20%3C%2FSPAN%3E%3CSPAN%3E512%3C%2FSPAN%3E%3CSPAN%3E%20bytes%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPs%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E)%20at%20%3C%2FSPAN%3E%3CSPAN%3E30000000%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%20bytes%20-%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%2F%3C%2FSPAN%3E%3CSPAN%3E1536%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPs%3A%20(%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E)%20at%20%3C%2FSPAN%3E%3CSPAN%3E30000000%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E16384%3C%2FSPAN%3E%3CSPAN%3E%20bytes%20-%20%3C%2FSPAN%3E%3CSPAN%3E16384%3C%2FSPAN%3E%3CSPAN%3E%2F%3C%2FSPAN%3E%3CSPAN%3E1536%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%3C%2FSPAN%3E%3CSPAN%3E30004000%3C%2FSPAN%3E%3CSPAN%3E%20done%20%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E%25%20(%3C%2FSPAN%3E%3CSPAN%3E16384%3C%2FSPAN%3E%3CSPAN%3E%20out%20of%20%3C%2FSPAN%3E%3CSPAN%3E1536%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Sectors%20written%3A%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%2C%20unchanged%3A%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%2C%20total%3A%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Closing%20flash%20driver%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%3A%20(%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E)%20Finished%20writing%20Flash%20successfully.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%3A%20Loaded%20%3C%2FSPAN%3E%3CSPAN%3E0x200%3C%2FSPAN%3E%3CSPAN%3E%20bytes%20in%20295ms%20(about%201kB%2Fs)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%3A%20Loading%20%3C%2FSPAN%3E%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%3CSPAN%3E%20ELF%20%3C%2FSPAN%3E%3CSPAN%3E0x30001000%3C%2FSPAN%3E%3CSPAN%3E%20len%20%3C%2FSPAN%3E%3CSPAN%3E0x30%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Opening%20flash%20driver%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3CSPAN%3E%20(already%20resident)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Sending%20VECTRESET%20to%20run%20flash%20driver%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Flash%20variant%20%3C%2FSPAN%3E%3CSPAN%3E'iMXRT1170_SFDP_FlexSPI1_A_QSPI%20Jul%2021%202025%2018%3A35%3A07'%3C%2FSPAN%3E%3CSPAN%3E%20detected%20(64MB%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E1024%3C%2FSPAN%3E%3CSPAN%3E*64K%20at%20%3C%2FSPAN%3E%3CSPAN%3E0x30000000%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%3A%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%20of%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%20(%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E)%20Writing%20sectors%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E-%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%20at%20%3C%2FSPAN%3E%3CSPAN%3E0x30001000%3C%2FSPAN%3E%3CSPAN%3E%20with%20%3C%2FSPAN%3E%3CSPAN%3E48%3C%2FSPAN%3E%3CSPAN%3E%20bytes%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPs%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E)%20at%20%3C%2FSPAN%3E%3CSPAN%3E30000000%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%20bytes%20-%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%2F%3C%2FSPAN%3E%3CSPAN%3E4144%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPs%3A%20(%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E)%20at%20%3C%2FSPAN%3E%3CSPAN%3E30000000%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E16384%3C%2FSPAN%3E%3CSPAN%3E%20bytes%20-%20%3C%2FSPAN%3E%3CSPAN%3E16384%3C%2FSPAN%3E%3CSPAN%3E%2F%3C%2FSPAN%3E%3CSPAN%3E4144%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%3C%2FSPAN%3E%3CSPAN%3E30004000%3C%2FSPAN%3E%3CSPAN%3E%20done%20%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E%25%20(%3C%2FSPAN%3E%3CSPAN%3E16384%3C%2FSPAN%3E%3CSPAN%3E%20out%20of%20%3C%2FSPAN%3E%3CSPAN%3E4144%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Sectors%20written%3A%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%2C%20unchanged%3A%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%2C%20total%3A%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Closing%20flash%20driver%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%3A%20(%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E)%20Finished%20writing%20Flash%20successfully.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%3A%20Loaded%20%3C%2FSPAN%3E%3CSPAN%3E0x30%3C%2FSPAN%3E%3CSPAN%3E%20bytes%20in%20310ms%20(about%200kB%2Fs)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%3A%20Loading%20%3C%2FSPAN%3E%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%3CSPAN%3E%20ELF%20%3C%2FSPAN%3E%3CSPAN%3E0x30002000%3C%2FSPAN%3E%3CSPAN%3E%20len%20%3C%2FSPAN%3E%3CSPAN%3E0x12044%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Opening%20flash%20driver%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3CSPAN%3E%20(already%20resident)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Sending%20VECTRESET%20to%20run%20flash%20driver%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Flash%20variant%20%3C%2FSPAN%3E%3CSPAN%3E'iMXRT1170_SFDP_FlexSPI1_A_QSPI%20Jul%2021%202025%2018%3A35%3A07'%3C%2FSPAN%3E%3CSPAN%3E%20detected%20(64MB%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E1024%3C%2FSPAN%3E%3CSPAN%3E*64K%20at%20%3C%2FSPAN%3E%3CSPAN%3E0x30000000%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%3A%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%20of%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%20(%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E)%20Writing%20sectors%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E-%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%20at%20%3C%2FSPAN%3E%3CSPAN%3E0x30002000%3C%2FSPAN%3E%3CSPAN%3E%20with%20%3C%2FSPAN%3E%3CSPAN%3E73796%3C%2FSPAN%3E%3CSPAN%3E%20bytes%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPs%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E)%20at%20%3C%2FSPAN%3E%3CSPAN%3E30000000%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%20bytes%20-%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%2F%3C%2FSPAN%3E%3CSPAN%3E81988%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPs%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E19%3C%2FSPAN%3E%3CSPAN%3E)%20at%20%3C%2FSPAN%3E%3CSPAN%3E30000000%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E16384%3C%2FSPAN%3E%3CSPAN%3E%20bytes%20-%20%3C%2FSPAN%3E%3CSPAN%3E16384%3C%2FSPAN%3E%3CSPAN%3E%2F%3C%2FSPAN%3E%3CSPAN%3E81988%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%3C%2FSPAN%3E%3CSPAN%3E30004000%3C%2FSPAN%3E%3CSPAN%3E%20done%20%3C%2FSPAN%3E%3CSPAN%3E19%3C%2FSPAN%3E%3CSPAN%3E%25%20(%3C%2FSPAN%3E%3CSPAN%3E16384%3C%2FSPAN%3E%3CSPAN%3E%20out%20of%20%3C%2FSPAN%3E%3CSPAN%3E81988%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPs%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E39%3C%2FSPAN%3E%3CSPAN%3E)%20at%20%3C%2FSPAN%3E%3CSPAN%3E30004000%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E16384%3C%2FSPAN%3E%3CSPAN%3E%20bytes%20-%20%3C%2FSPAN%3E%3CSPAN%3E32768%3C%2FSPAN%3E%3CSPAN%3E%2F%3C%2FSPAN%3E%3CSPAN%3E81988%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%3C%2FSPAN%3E%3CSPAN%3E30008000%3C%2FSPAN%3E%3CSPAN%3E%20done%20%3C%2FSPAN%3E%3CSPAN%3E39%3C%2FSPAN%3E%3CSPAN%3E%25%20(%3C%2FSPAN%3E%3CSPAN%3E32768%3C%2FSPAN%3E%3CSPAN%3E%20out%20of%20%3C%2FSPAN%3E%3CSPAN%3E81988%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPs%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E59%3C%2FSPAN%3E%3CSPAN%3E)%20at%20%3C%2FSPAN%3E%3CSPAN%3E30008000%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E16384%3C%2FSPAN%3E%3CSPAN%3E%20bytes%20-%20%3C%2FSPAN%3E%3CSPAN%3E49152%3C%2FSPAN%3E%3CSPAN%3E%2F%3C%2FSPAN%3E%3CSPAN%3E81988%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%203000C000%20done%20%3C%2FSPAN%3E%3CSPAN%3E59%3C%2FSPAN%3E%3CSPAN%3E%25%20(%3C%2FSPAN%3E%3CSPAN%3E49152%3C%2FSPAN%3E%3CSPAN%3E%20out%20of%20%3C%2FSPAN%3E%3CSPAN%3E81988%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPs%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E79%3C%2FSPAN%3E%3CSPAN%3E)%20at%203000C000%3A%20%3C%2FSPAN%3E%3CSPAN%3E16384%3C%2FSPAN%3E%3CSPAN%3E%20bytes%20-%20%3C%2FSPAN%3E%3CSPAN%3E65536%3C%2FSPAN%3E%3CSPAN%3E%2F%3C%2FSPAN%3E%3CSPAN%3E81988%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%3C%2FSPAN%3E%3CSPAN%3E30010000%3C%2FSPAN%3E%3CSPAN%3E%20done%20%3C%2FSPAN%3E%3CSPAN%3E79%3C%2FSPAN%3E%3CSPAN%3E%25%20(%3C%2FSPAN%3E%3CSPAN%3E65536%3C%2FSPAN%3E%3CSPAN%3E%20out%20of%20%3C%2FSPAN%3E%3CSPAN%3E81988%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPs%3A%20(%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E)%20at%20%3C%2FSPAN%3E%3CSPAN%3E30010000%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E65536%3C%2FSPAN%3E%3CSPAN%3E%20bytes%20-%20%3C%2FSPAN%3E%3CSPAN%3E131072%3C%2FSPAN%3E%3CSPAN%3E%2F%3C%2FSPAN%3E%3CSPAN%3E81988%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Sectors%20written%3A%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%2C%20unchanged%3A%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%2C%20total%3A%20%3C%2FSPAN%3E%3CSPAN%3E2%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Closing%20flash%20driver%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%3A%20(%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E)%20Finished%20writing%20Flash%20successfully.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%3A%20Loaded%20%3C%2FSPAN%3E%3CSPAN%3E0x12044%3C%2FSPAN%3E%3CSPAN%3E%20bytes%20in%20499ms%20(about%20147kB%2Fs)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%3A%20Loading%20%3C%2FSPAN%3E%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%3CSPAN%3E%20ELF%20%3C%2FSPAN%3E%3CSPAN%3E0x33FC0000%3C%2FSPAN%3E%3CSPAN%3E%20len%20%3C%2FSPAN%3E%3CSPAN%3E0x7144%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Opening%20flash%20driver%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3CSPAN%3E%20(already%20resident)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Sending%20VECTRESET%20to%20run%20flash%20driver%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Flash%20variant%20%3C%2FSPAN%3E%3CSPAN%3E'iMXRT1170_SFDP_FlexSPI1_A_QSPI%20Jul%2021%202025%2018%3A35%3A07'%3C%2FSPAN%3E%3CSPAN%3E%20detected%20(64MB%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E1024%3C%2FSPAN%3E%3CSPAN%3E*64K%20at%20%3C%2FSPAN%3E%3CSPAN%3E0x30000000%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%3A%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%20of%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%20(%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E)%20Writing%20sectors%20%3C%2FSPAN%3E%3CSPAN%3E1020-1020%3C%2FSPAN%3E%3CSPAN%3E%20at%20%3C%2FSPAN%3E%3CSPAN%3E0x33FC0000%3C%2FSPAN%3E%3CSPAN%3E%20with%20%3C%2FSPAN%3E%3CSPAN%3E28996%3C%2FSPAN%3E%3CSPAN%3E%20bytes%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPs%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E)%20at%2033FC0000%3A%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%20bytes%20-%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%2F%3C%2FSPAN%3E%3CSPAN%3E28996%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPs%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E56%3C%2FSPAN%3E%3CSPAN%3E)%20at%2033FC0000%3A%20%3C%2FSPAN%3E%3CSPAN%3E16384%3C%2FSPAN%3E%3CSPAN%3E%20bytes%20-%20%3C%2FSPAN%3E%3CSPAN%3E16384%3C%2FSPAN%3E%3CSPAN%3E%2F%3C%2FSPAN%3E%3CSPAN%3E28996%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%2033FC4000%20done%20%3C%2FSPAN%3E%3CSPAN%3E56%3C%2FSPAN%3E%3CSPAN%3E%25%20(%3C%2FSPAN%3E%3CSPAN%3E16384%3C%2FSPAN%3E%3CSPAN%3E%20out%20of%20%3C%2FSPAN%3E%3CSPAN%3E28996%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPs%3A%20(%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E)%20at%2033FC4000%3A%20%3C%2FSPAN%3E%3CSPAN%3E16384%3C%2FSPAN%3E%3CSPAN%3E%20bytes%20-%20%3C%2FSPAN%3E%3CSPAN%3E32768%3C%2FSPAN%3E%3CSPAN%3E%2F%3C%2FSPAN%3E%3CSPAN%3E28996%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%2033FC8000%20done%20%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E%25%20(%3C%2FSPAN%3E%3CSPAN%3E32768%3C%2FSPAN%3E%3CSPAN%3E%20out%20of%20%3C%2FSPAN%3E%3CSPAN%3E28996%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Sectors%20written%3A%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%2C%20unchanged%3A%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%2C%20total%3A%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Closing%20flash%20driver%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%3A%20(%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E)%20Finished%20writing%20Flash%20successfully.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%3A%20Loaded%20%3C%2FSPAN%3E%3CSPAN%3E0x7144%3C%2FSPAN%3E%3CSPAN%3E%20bytes%20in%20550ms%20(about%2052kB%2Fs)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%3A%20Reset%20target%20(system)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20SCRIPT%3A%20%3C%2FSPAN%3E%3CSPAN%3ERT1170_reset.scp%3C%2FSPAN%3E%3CSPAN%3E%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20This%20probe%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20This%20TAP%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20This%20core%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20SYSTEM%20Reset%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20Wirespeed%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E10000000%3C%2FSPAN%3E%3CSPAN%3E%20Hz%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20DpID%20%3D%206BA02477%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20TAP%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3A%206BA02477%20Core%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3A%20M7%20APID%3A%20%3C%2FSPAN%3E%3CSPAN%3E84770001%3C%2FSPAN%3E%3CSPAN%3E%20ROM%20Table%3A%20E00FD003*%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20TAP%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3A%206BA02477%20AP%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%3A%20APID%3A%20%3C%2FSPAN%3E%3CSPAN%3E24770011%3C%2FSPAN%3E%3CSPAN%3E%20ROM%20Table%3A%20E00FF003%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20TAP%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3A%206BA02477%20AP%20%3C%2FSPAN%3E%3CSPAN%3E2%3C%2FSPAN%3E%3CSPAN%3E%3A%20APID%3A%20%3C%2FSPAN%3E%3CSPAN%3E54770002%3C%2FSPAN%3E%3CSPAN%3E%20ROM%20Table%3A%20%3C%2FSPAN%3E%3CSPAN%3E00000002%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20APID%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0x84770001%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20Setting%20M4%20spin%20code%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20Setting%20M4%20clock%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20Resetting%20M4%20core%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20Releasing%20M4%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20View%20cores%20on%20the%20DAP%20AP%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20DpID%20%3D%206BA02477%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20TAP%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3A%206BA02477%20Core%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3A%20M7%20APID%3A%20%3C%2FSPAN%3E%3CSPAN%3E84770001%3C%2FSPAN%3E%3CSPAN%3E%20ROM%20Table%3A%20E00FD003*%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20TAP%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3A%206BA02477%20Core%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%3A%20M4%20APID%3A%20%3C%2FSPAN%3E%3CSPAN%3E24770011%3C%2FSPAN%3E%3CSPAN%3E%20ROM%20Table%3A%20E00FF003%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20R15%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0x00223104%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20Vector%20table%20SP%2FPC%20is%20the%20reset%20context.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20PC%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0x3000247D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20SP%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0x20040000%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20XPSR%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0x01000000%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20VTOR%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0x30002000%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20Set%20DEMCR%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0x010007F1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20END%20SCRIPT%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENs%3A%20Stopped%3A%20Halt%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENs%3A%20restart%20on%20reset%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2171731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RT1170%20EVKB%20Multicore%20project%20and%20LinkServer%20Flash%20programmer%20not%20working%20(mcuxpresso%20vs%20code)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2171731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20do%20have%20have%20latest%20firmware%20for%20the%20MCU-Link.%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EResetting%20the%20probe%20before%20a%20flash%20as%20you%20suggested%20does%20not%20make%20a%20difference%20unfortunately.%20Still%20get%20this%20error%20most%20of%20the%20time%3A%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A09%3A34.034%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FUsers%2Fmelker%2F.mcuxpressotools%2Fpemicrogdbserver%2Fpegdbserver_console%20-showhardware%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A09%3A34.035%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FApplications%2FSEGGER%2FJLink_V824%2FJLinkGDBServerCLExe%20-listprobes%20USB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A09%3A34.035%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FApplications%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E33%3C%2FSPAN%3E%3CSPAN%3E%2FLinkServer%20probes%20--json%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A09%3A35.433%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FApplications%2FMCUXpressoIDE_24.%3C%2FSPAN%3E%3CSPAN%3E12%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E148%3C%2FSPAN%3E%3CSPAN%3E%2Fide%2Ftools%2Fbin%2Farm-none-eabi-gcc%20--version%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A09%3A35.436%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FUsers%2Fmelker%2F.mcuxpressotools%2Farm-%3C%2FSPAN%3E%3CSPAN%3Egnu-toolchain-13.2.Rel1-darwin-x86_64-arm-none%3C%2FSPAN%3E%3CSPAN%3E-eabi%2Fbin%2Farm-none-eabi-gcc%20--version%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A09%3A35.458%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FApplications%2FMCUXpressoIDE_24.%3C%2FSPAN%3E%3CSPAN%3E12%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E148%3C%2FSPAN%3E%3CSPAN%3E%2Fide%2Ftools%2Fbin%2Farm-none-eabi-gcc%20--version%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A09%3A35.470%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FUsers%2Fmelker%2F.mcuxpressotools%2Farm-%3C%2FSPAN%3E%3CSPAN%3Egnu-toolchain-13.2.Rel1-darwin-x86_64-arm-none%3C%2FSPAN%3E%3CSPAN%3E-eabi%2Fbin%2Farm-none-eabi-gcc%20--version%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A09%3A35.481%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FUsers%2Fmelker%2F.mcuxpressotools%2Farm-%3C%2FSPAN%3E%3CSPAN%3Egnu-toolchain-13.2.Rel1-darwin-x86_64-arm-none%3C%2FSPAN%3E%3CSPAN%3E-eabi%2Fbin%2Farm-none-eabi-gcc%20--version%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A09%3A35.482%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FApplications%2FMCUXpressoIDE_24.%3C%2FSPAN%3E%3CSPAN%3E12%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E148%3C%2FSPAN%3E%3CSPAN%3E%2Fide%2Ftools%2Fbin%2Farm-none-eabi-gcc%20--version%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A10%3A30.963%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FUsers%2Fmelker%2F.mcuxpressotools%2Fpemicrogdbserver%2Fpegdbserver_console%20-showhardware%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A10%3A30.965%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FApplications%2FSEGGER%2FJLink_V824%2FJLinkGDBServerCLExe%20-listprobes%20USB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A10%3A30.966%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FApplications%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E33%3C%2FSPAN%3E%3CSPAN%3E%2FLinkServer%20probes%20--json%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A10%3A32.425%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FUsers%2Fmelker%2F.mcuxpressotools%2Fpemicrogdbserver%2Fpegdbserver_console%20-showhardware%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A10%3A32.426%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FApplications%2FSEGGER%2FJLink_V824%2FJLinkGDBServerCLExe%20-listprobes%20USB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A10%3A32.427%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FApplications%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E33%3C%2FSPAN%3E%3CSPAN%3E%2FLinkServer%20probes%20--json%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A10%3A35.933%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2FApplications%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E33%3C%2FSPAN%3E%3CSPAN%3E%2FLinkServer%20flash%20--probe%20H3RHID4AC30FD%20--no-boot%20MIMXRT1176xxxxx%3AMIMXR%3C%2FSPAN%3E%3CSPAN%3ET1170%3C%2FSPAN%3E%3CSPAN%3E-EVKB%20load%20%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_primary_core%2Farmgcc%2Fflexspi_nor_debug%2Ffreertos_message_buffers_primary_core.elf%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A10%3A39.480%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Berror%5D%3C%2FSPAN%3E%3CSPAN%3E%20%2FApplications%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E7%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E33%3C%2FSPAN%3E%3CSPAN%3E%2FLinkServer%20exited%20with%20code%20%3C%2FSPAN%3E%3CSPAN%3E255%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-09-18T09%3A10%3A39.480%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Berror%5D%3C%2FSPAN%3E%3CSPAN%3E%20Firmware%20update%20%60check%60%3A%20not%20required%20-%20forced%20update%20can%20be%20performed%20using%3A%20%60.%2FLinkServer%20probe%20%23%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%20update%20forced%60%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENs%3A%20LinkServer%20RedlinkMulti%20Driver%20%3C%2FSPAN%3E%3CSPAN%3Ev25.7%3C%2FSPAN%3E%3CSPAN%3E%20(Jul%20%3C%2FSPAN%3E%3CSPAN%3E21%3C%2FSPAN%3E%20%3CSPAN%3E2025%3C%2FSPAN%3E%20%3CSPAN%3E20%3A37%3A00%3C%2FSPAN%3E%3CSPAN%3E%20-%20crt_emu_cm_redlink%20build%20%3C%2FSPAN%3E%3CSPAN%3E1038%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPc%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E)%20Reading%20remote%20configuration%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc(%3C%2FSPAN%3E%3CSPAN%3E03%3C%2FSPAN%3E%3CSPAN%3E).%20No%20cache%20support.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Found%20generic%20directory%20XML%20file%20in%20%2Fvar%2Ffolders%2F8x%2F1csc34zn7pq1_ksyf9k3x24h0000gn%2FT%2Ftmps1gdrldt%2Fcrt_directory.xml%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPc%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3CSPAN%3E)%20Remote%20configuration%20complete%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Reconnected%20to%20existing%20LinkServer%20process.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20SCRIPT%3A%20%3C%2FSPAN%3E%3CSPAN%3ERT1170_connect_M7_wake_M4.scp%3C%2FSPAN%3E%3CSPAN%3E%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20R%3C%2FSPAN%3E%3CSPAN%3ET1170%3C%2FSPAN%3E%3CSPAN%3E%20Connect%20M7%20and%20Wake%20M4%20Script%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20DpID%20%3D%206BA02477%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20APID%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0x84770001%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20Setting%20M4%20spin%20code%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20Setting%20M4%20clock%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20Resetting%20M4%20core%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20View%20cores%20on%20the%20DAP%20AP%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20DpID%20%3D%206BA02477%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20TAP%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3A%206BA02477%20Core%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3A%20M7%20APID%3A%20%3C%2FSPAN%3E%3CSPAN%3E84770001%3C%2FSPAN%3E%3CSPAN%3E%20ROM%20Table%3A%20E00FD003*%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20TAP%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3A%206BA02477%20Core%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%3A%20M4%20APID%3A%20%3C%2FSPAN%3E%3CSPAN%3E24770011%3C%2FSPAN%3E%3CSPAN%3E%20ROM%20Table%3A%20E00FF003%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20END%20SCRIPT%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Probe%20Firmware%3A%20MCU-LINK%20on-board%20(r0E2)%20CMSIS-DAP%20%3C%2FSPAN%3E%3CSPAN%3EV3.160%3C%2FSPAN%3E%3CSPAN%3E%20(NXP%20Semiconductors)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Serial%20Number%3A%20H3RHID4AC30FD%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20VID%3APID%3A%20%3C%2FSPAN%3E%3CSPAN%3E1FC9%3A0143%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20USB%20Path%3A%20%3C%2FSPAN%3E%3CSPAN%3E0014%3A0003%3A00%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Using%20memory%20from%20core%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%20after%20searching%20for%20a%20good%20core%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPc%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E30%3C%2FSPAN%3E%3CSPAN%3E)%20Emulator%20Connected%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPc%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E40%3C%2FSPAN%3E%3CSPAN%3E)%20%3C%2FSPAN%3E%3CSPAN%3EDebug%3C%2FSPAN%3E%3CSPAN%3E%20Halt%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPc%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E50%3C%2FSPAN%3E%3CSPAN%3E)%20CPU%20ID%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20debug%20interface%20type%20%3D%20CoreSight%20DP%20(DAP%20DP%20ID%206BA02477)%20over%20SWD%20TAP%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20processor%20type%20%3D%20Cortex-M7%20(CPU%20ID%2000000C27)%20on%20DAP%20AP%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20number%20of%20h%2Fw%20breakpoints%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E8%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20number%20of%20flash%20patches%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20number%20of%20h%2Fw%20watchpoints%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E4%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Probe(%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3CLI-EMOJI%20id%3D%22lia_disappointed-face%22%20title%3D%22%3Adisappointed_face%3A%22%3E%3C%2FLI-EMOJI%3E%20Connected%26amp%3BReset.%20DpID%3A%206BA02477.%20CpuID%3A%2000000C27.%20%3C%2FSPAN%3E%3CSPAN%3EInfo%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3CNONE%3E%3C%2FNONE%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20%3C%2FSPAN%3E%3CSPAN%3EDebug%3C%2FSPAN%3E%3CSPAN%3E%20protocol%3A%20SWD.%20RTCK%3A%20Disabled.%20Vector%20catch%3A%20Disabled.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENs%3A%20Content%20of%20CoreSight%20%3C%2FSPAN%3E%3CSPAN%3EDebug%3C%2FSPAN%3E%3CSPAN%3E%20ROM(s)%3A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20RBASE%20E00FD000%3A%20CID%20B105100D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E000008E88C%3C%2FSPAN%3E%3CSPAN%3E%20ROM%20(type%20%3C%2FSPAN%3E%3CSPAN%3E0x1%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%20E00FE000%3A%20CID%20B105100D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04000BB4C8%3C%2FSPAN%3E%3CSPAN%3E%20ROM%20(type%20%3C%2FSPAN%3E%3CSPAN%3E0x1%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%20%3C%2FSPAN%3E%3CSPAN%3E2%3C%2FSPAN%3E%3CSPAN%3E%20E00FF000%3A%20CID%20B105100D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04000BB4C7%3C%2FSPAN%3E%3CSPAN%3E%20ROM%20(type%20%3C%2FSPAN%3E%3CSPAN%3E0x1%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%20%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3E%20E000E000%3A%20CID%20B105E00D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04000BB00C%3C%2FSPAN%3E%3CSPAN%3E%20Gen%20SCS%20(type%20%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%20%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3E%20E0001000%3A%20CID%20B105E00D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04000BB002%3C%2FSPAN%3E%3CSPAN%3E%20Gen%20DWT%20(type%20%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%20%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3E%20E0002000%3A%20CID%20B105E00D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04000BB00E%3C%2FSPAN%3E%3CSPAN%3E%20Gen%20(type%20%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%20%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3E%20E0000000%3A%20CID%20B105E00D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04000BB001%3C%2FSPAN%3E%3CSPAN%3E%20Gen%20ITM%20(type%20%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%20%3C%2FSPAN%3E%3CSPAN%3E2%3C%2FSPAN%3E%3CSPAN%3E%20E0041000%3A%20CID%20B105900D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04001BB975%3C%2FSPAN%3E%3CSPAN%3E%20CSt%20ARM%20%3C%2FSPAN%3E%3CSPAN%3EETMv4.0%3C%2FSPAN%3E%3CSPAN%3E%20type%20%3C%2FSPAN%3E%3CSPAN%3E0x13%3C%2FSPAN%3E%3CSPAN%3E%20Trace%20Source%20-%20Core%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%20%3C%2FSPAN%3E%3CSPAN%3E2%3C%2FSPAN%3E%3CSPAN%3E%20E0042000%3A%20CID%20B105900D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04004BB906%3C%2FSPAN%3E%3CSPAN%3E%20CSt%20type%20%3C%2FSPAN%3E%3CSPAN%3E0x14%3C%2FSPAN%3E%20%3CSPAN%3EDebug%3C%2FSPAN%3E%3CSPAN%3E%20Control%20-%20Trigger%2C%20%3C%2FSPAN%3E%3CSPAN%3Ee.g%3C%2FSPAN%3E%3CSPAN%3E.%20ECT%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20ROM%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%20E0043000%3A%20CID%20B105900D%20PID%20%3C%2FSPAN%3E%3CSPAN%3E04001BB908%3C%2FSPAN%3E%3CSPAN%3E%20CSt%20CSTF%20type%20%3C%2FSPAN%3E%3CSPAN%3E0x12%3C%2FSPAN%3E%3CSPAN%3E%20Trace%20Link%20-%20Trace%20funnel%2Frouter%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20NXP%3A%20MIMXRT1176xxxxx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20DAP%20stride%20is%20%3C%2FSPAN%3E%3CSPAN%3E1024%3C%2FSPAN%3E%3CSPAN%3E%20bytes%20(%3C%2FSPAN%3E%3CSPAN%3E256%3C%2FSPAN%3E%3CSPAN%3E%20words)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Inspected%20%3C%2FSPAN%3E%3CSPAN%3Ev.2%3C%2FSPAN%3E%3CSPAN%3E%20External%20Flash%20Device%20on%20SPI%20using%20SFDP%20JEDEC%20ID%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Image%20%3C%2FSPAN%3E%3CSPAN%3E'iMXRT1170_SFDP_FlexSPI1_A_QSPI%20Jul%2021%202025%2018%3A35%3A07'%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Opening%20flash%20driver%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Sending%20VECTRESET%20to%20run%20flash%20driver%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Flash%20variant%20%3C%2FSPAN%3E%3CSPAN%3E'iMXRT1170_SFDP_FlexSPI1_A_QSPI%20Jul%2021%202025%2018%3A35%3A07'%3C%2FSPAN%3E%3CSPAN%3E%20detected%20(64MB%20%3D%20%3C%2FSPAN%3E%3CSPAN%3E1024%3C%2FSPAN%3E%3CSPAN%3E*64K%20at%20%3C%2FSPAN%3E%3CSPAN%3E0x30000000%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Closing%20flash%20driver%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPc%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E65%3C%2FSPAN%3E%3CSPAN%3E)%20Chip%20Setup%20Complete%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPc%3A%20(%20%3C%2FSPAN%3E%3CSPAN%3E70%3C%2FSPAN%3E%3CSPAN%3E)%20License%20Check%20Complete%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%3A%20Loading%20%3C%2FSPAN%3E%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%3CSPAN%3E%20ELF%20%3C%2FSPAN%3E%3CSPAN%3E0x30000400%3C%2FSPAN%3E%3CSPAN%3E%20len%20%3C%2FSPAN%3E%3CSPAN%3E0x200%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Opening%20flash%20driver%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3CSPAN%3E%20(already%20resident)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Sending%20VECTRESET%20to%20run%20flash%20driver%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20request%20to%20clear%20DAP%20error%20failed%20-%20status%20%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20After%20error%20Nn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E).%20Wire%20ACK%20Fault%20in%20DAP%20access%20-%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Failed%20to%20read%20address%20register%20in%20DAP%20-%20Nn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E).%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20flash%20driver%20polled%20mailbox%20(%3C%2FSPAN%3E%3CSPAN%3E8%3C%2FSPAN%3E%3CSPAN%3E%20bytes%20at%20%3C%2FSPAN%3E%3CSPAN%3E0x2000A840%3C%2FSPAN%3E%3CSPAN%3E)%20read%20failed%20(on%20poll%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%2F%3C%2FSPAN%3E%3CSPAN%3E301%3C%2FSPAN%3E%3CSPAN%3E)%20-%20retrying%20after%201ms%20-%20rc%20Em(%3C%2FSPAN%3E%3CSPAN%3E17%3C%2FSPAN%3E%3CSPAN%3E).%20%3C%2FSPAN%3E%3CSPAN%3EDebug%3C%2FSPAN%3E%3CSPAN%3E%20port%20inaccessible%20after%20access%20at%20location%20%3C%2FSPAN%3E%3CSPAN%3E0x2000A840%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3ENc%3A%20request%20to%20clear%20DAP%20error%20failed%20-%20status%20%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20After%20error%20Nn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E).%20Wire%20ACK%20Fault%20in%20DAP%20access%20-%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Failed%20to%20read%20address%20register%20in%20DAP%20-%20Nn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E).%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWc%3A%20flash%20driver%20polled%20mailbox%20(%3C%2FSPAN%3E%3CSPAN%3E8%3C%2FSPAN%3E%3CSPAN%3E%20bytes%20at%20%3C%2FSPAN%3E%3CSPAN%3E0x2000A840%3C%2FSPAN%3E%3CSPAN%3E)%20read%20failed%20(on%20poll%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%2F%3C%2FSPAN%3E%3CSPAN%3E301%3C%2FSPAN%3E%3CSPAN%3E)%20-%20halting%20for%20postmortem%20-%20rc%20Em(%3C%2FSPAN%3E%3CSPAN%3E17%3C%2FSPAN%3E%3CSPAN%3E).%20%3C%2FSPAN%3E%3CSPAN%3EDebug%3C%2FSPAN%3E%3CSPAN%3E%20port%20inaccessible%20after%20access%20at%20location%20%3C%2FSPAN%3E%3CSPAN%3E0x2000A840%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3EWc%3A%20failed%20to%20halt%20target%20for%20postmortem%20-%20rc%20Nn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E).%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3ENc%3A%20request%20to%20clear%20DAP%20error%20failed%20-%20status%20%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20failed%20to%20read%20registers%20-%20Nn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E).%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Flash%20Driver%20%3C%2FSPAN%3E%3CSPAN%3EV.2%3C%2FSPAN%3E%3CSPAN%3E%20startup%20failed%20-%20rc%20Em(%3C%2FSPAN%3E%3CSPAN%3E17%3C%2FSPAN%3E%3CSPAN%3E).%20%3C%2FSPAN%3E%3CSPAN%3EDebug%3C%2FSPAN%3E%3CSPAN%3E%20port%20inaccessible%20after%20access%20at%20location%20%3C%2FSPAN%3E%3CSPAN%3E0x2000A840%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%3A%20(%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E)%20Writing%20Flash%20ended%20with%20an%20error.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EEd%3A05%3C%2FSPAN%3E%3CSPAN%3E%3A%20File%20%3C%2FSPAN%3E%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%3CSPAN%3E%20load%20failure%3A%20Em(%3C%2FSPAN%3E%3CSPAN%3E17%3C%2FSPAN%3E%3CSPAN%3E).%20%3C%2FSPAN%3E%3CSPAN%3EDebug%3C%2FSPAN%3E%3CSPAN%3E%20port%20inaccessible%20after%20access%20at%20location%20%3C%2FSPAN%3E%3CSPAN%3E0x2000A840%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%3A%20Loading%20%3C%2FSPAN%3E%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%3CSPAN%3E%20ELF%20%3C%2FSPAN%3E%3CSPAN%3E0x30001000%3C%2FSPAN%3E%3CSPAN%3E%20len%20%3C%2FSPAN%3E%3CSPAN%3E0x30%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Opening%20flash%20driver%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20request%20to%20clear%20DAP%20error%20failed%20-%20status%20%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%3A%20(%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E)%20Writing%20Flash%20ended%20with%20an%20error.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EEd%3A05%3C%2FSPAN%3E%3CSPAN%3E%3A%20File%20%3C%2FSPAN%3E%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%3CSPAN%3E%20load%20failure%3A%20Nn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E).%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%3A%20Loading%20%3C%2FSPAN%3E%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%3CSPAN%3E%20ELF%20%3C%2FSPAN%3E%3CSPAN%3E0x30002000%3C%2FSPAN%3E%3CSPAN%3E%20len%20%3C%2FSPAN%3E%3CSPAN%3E0x12044%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Opening%20flash%20driver%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20request%20to%20clear%20DAP%20error%20failed%20-%20status%20%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%3A%20(%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E)%20Writing%20Flash%20ended%20with%20an%20error.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EEd%3A05%3C%2FSPAN%3E%3CSPAN%3E%3A%20File%20%3C%2FSPAN%3E%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%3CSPAN%3E%20load%20failure%3A%20Nn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E).%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENt%3A%20Loading%20%3C%2FSPAN%3E%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%3CSPAN%3E%20ELF%20%3C%2FSPAN%3E%3CSPAN%3E0x33FC0000%3C%2FSPAN%3E%3CSPAN%3E%20len%20%3C%2FSPAN%3E%3CSPAN%3E0x7144%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20Opening%20flash%20driver%20%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20request%20to%20clear%20DAP%20error%20failed%20-%20status%20%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPb%3A%20(%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E)%20Writing%20Flash%20ended%20with%20an%20error.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EEd%3A05%3C%2FSPAN%3E%3CSPAN%3E%3A%20File%20%3C%2FSPAN%3E%3CSPAN%3E'freertos_message_buffers_primary_core.elf'%3C%2FSPAN%3E%3CSPAN%3E%20load%20failure%3A%20Nn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E).%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPc%3A%20(%3C%2FSPAN%3E%3CSPAN%3E100%3C%2FSPAN%3E%3CSPAN%3E)%20Target%20Operation%20Failed%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20request%20to%20clear%20DAP%20error%20failed%20-%20status%20%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20request%20to%20clear%20DAP%20error%20failed%20-%20status%20%3C%2FSPAN%3E%3CSPAN%3E5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ENc%3A%20error%20closing%20down%20debug%20session%20-%20Nn(%3C%2FSPAN%3E%3CSPAN%3E05%3C%2FSPAN%3E%3CSPAN%3E).%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3EINFO%3C%2FSPAN%3E%3CSPAN%3E%3A%20Exact%20match%20for%20MIMXRT1176xxxxx%3AMIMXR%3C%2FSPAN%3E%3CSPAN%3ET1170%3C%2FSPAN%3E%3CSPAN%3E-EVKB%20found%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EINFO%3C%2FSPAN%3E%3CSPAN%3E%3A%20Selected%20device%20MIMXRT1176xxxxx%3AMIMXR%3C%2FSPAN%3E%3CSPAN%3ET1170%3C%2FSPAN%3E%3CSPAN%3E-EVKB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EINFO%3C%2FSPAN%3E%3CSPAN%3E%3A%20Getting%20available%20probes%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EINFO%3C%2FSPAN%3E%3CSPAN%3E%3A%20Selecting%20probe%20by%20serial%20substring%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EINFO%3C%2FSPAN%3E%3CSPAN%3E%3A%20Selected%20probe%20%23%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%20H3RHID4AC30FD%20(MCU-LINK%20on-board%20(r0E2)%20CMSIS-DAP%20%3C%2FSPAN%3E%3CSPAN%3EV3.160%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EINFO%3C%2FSPAN%3E%3CSPAN%3E%3A%20MCU-Link%20firmware%20update%20%60check%60%3A%20Probe%20(%5BH3RHID4AC30FD%5D%20%5BMCU-LINK%20on-board%20(r0E2)%20CMSIS-DAP%20%3C%2FSPAN%3E%3CSPAN%3EV3.160%3C%2FSPAN%3E%3CSPAN%3E%5D)%20is%20already%20running%20the%20same%20firmware%20version%20as%20the%20included%20firmware%20version%20%5B%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E160%3C%2FSPAN%3E%3CSPAN%3E%5D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECRITICAL%3C%2FSPAN%3E%3CSPAN%3E%3A%20Critical%20error%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EERRMSG%3A%20%3C%2FSPAN%3E%3CSPAN%3EException%3C%2FSPAN%3E%3CSPAN%3E%3A%20Flash%20operation%20exited%20with%20code%20%3C%2FSPAN%3E%3CSPAN%3E%3CSPAN%3E1%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3EAlso%20I've%20noticed%20that%20when%20when%20the%20flashing%20actually%20succeeds%20the%20M4%20core%20is%20most%20of%20the%20time%20one%20or%20more%20versions%20behind%20even%20though%20I%20do%20a%20clean%20and%20rebuild%20of%20both%20projects%20before%20flashing.%20However%20sometimes%2C%20seemingly%20randomly%20both%20cores%20does%20get%20the%20correct%20version.%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EThis%20is%20the%20build%20log%3A%26nbsp%3B%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CP%3EExecuting%20task%3A%20CMake%3A%20build%20M4%3C%2FP%3E%3CP%3EWorkspace%20is%20%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_secondary_core%3CBR%20%2F%3Ebuild%20task%20started....%3CBR%20%2F%3E%2FUsers%2Fmelker%2F.mcuxpressotools%2Fcmake-3.30.0-macos10.10-universal%2FCMake.app%2FContents%2Fbin%2Fcmake%20--build%20%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_secondary_core%2Farmgcc%2Fdebug%20--clean-first%20--target%20all%20--%3CBR%20%2F%3E%5B1%2F2%5D%20Cleaning%20additional%20files...%3CBR%20%2F%3E%5B2%2F2%5D%20Cleaning%20all%20built%20files...%3CBR%20%2F%3ECleaning...%2039%20files.%3CBR%20%2F%3E%5B1%2F39%5D%20Building%20ASM%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fgcc%2Fstartup_MIMXRT1176_cm4.S.obj%3CBR%20%2F%3E%5B2%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fsystem_MIMXRT1176_cm4.c.obj%3CBR%20%2F%3E%5B3%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_common_arm.c.obj%3CBR%20%2F%3E%5B4%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_gpio.c.obj%3CBR%20%2F%3E%5B5%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_common.c.obj%3CBR%20%2F%3E%5B6%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_secondary_core%2Fhardware_init.c.obj%3CBR%20%2F%3E%5B7%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_secondary_core%2Fpin_mux.c.obj%3CBR%20%2F%3E%5B8%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_anatop_ai.c.obj%3CBR%20%2F%3E%5B9%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_secondary_core%2Fboard.c.obj%3CBR%20%2F%3E%5B10%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_mu.c.obj%3CBR%20%2F%3E%5B11%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fcomponents%2Fuart%2Ffsl_adapter_lpuart.c.obj%3CBR%20%2F%3E%5B12%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_gpc.c.obj%3CBR%20%2F%3E%5B13%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_secondary_core%2Fmain.c.obj%3CBR%20%2F%3E%5B14%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Frtos%2Ffreertos%2Ffreertos-kernel%2Fcroutine.c.obj%3CBR%20%2F%3E%5B15%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_secondary_core%2Fclock_config.c.obj%3CBR%20%2F%3E%5B16%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Frtos%2Ffreertos%2Ffreertos-kernel%2Flist.c.obj%3CBR%20%2F%3E%5B17%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_pgmc.c.obj%3CBR%20%2F%3E%5B18%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Fcm4%2Ffsl_cache.c.obj%3CBR%20%2F%3E%5B19%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Frtos%2Ffreertos%2Ffreertos-kernel%2Ftimers.c.obj%3CBR%20%2F%3E%5B20%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Frtos%2Ffreertos%2Ffreertos-kernel%2Fevent_groups.c.obj%3CBR%20%2F%3E%5B21%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Frtos%2Ffreertos%2Ffreertos-kernel%2Fportable%2FGCC%2FARM_CM4F%2Fport.c.obj%3CBR%20%2F%3E%5B22%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_dcdc.c.obj%3CBR%20%2F%3E%5B23%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fmiddleware%2Fmulticore%2Fmcmgr%2Fsrc%2Fmcmgr.c.obj%3CBR%20%2F%3E%5B24%2F39%5D%20Building%20ASM%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Futilities%2Ffsl_memcpy.S.obj%3CBR%20%2F%3E%5B25%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Futilities%2Ffsl_sbrk.c.obj%3CBR%20%2F%3E%5B26%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Futilities%2Ffsl_syscall_stub.c.obj%3CBR%20%2F%3E%5B27%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Frtos%2Ffreertos%2Ffreertos-kernel%2Fstream_buffer.c.obj%3CBR%20%2F%3E%5B28%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Frtos%2Ffreertos%2Ffreertos-kernel%2Fqueue.c.obj%3CBR%20%2F%3E%5B29%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_lpuart.c.obj%3CBR%20%2F%3E%5B30%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_clock.c.obj%3CBR%20%2F%3E%5B31%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_soc_src.c.obj%3CBR%20%2F%3E%5B32%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Frtos%2Ffreertos%2Ffreertos-kernel%2Ftasks.c.obj%3CBR%20%2F%3E%5B33%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fmiddleware%2Fmulticore%2Fmcmgr%2Fsrc%2Fmcmgr_mu_internal.c.obj%3CBR%20%2F%3E%5B34%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Fdrivers%2Ffsl_pmu.c.obj%3CBR%20%2F%3E%5B35%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fmiddleware%2Fmulticore%2Fmcmgr%2Fsrc%2Fmcmgr_internal_core_api_imxrt1170.c.obj%3CBR%20%2F%3E%5B36%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Futilities%2Fdebug_console_lite%2Ffsl_assert.c.obj%3CBR%20%2F%3E%5B37%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Futilities%2Fdebug_console_lite%2Ffsl_debug_console.c.obj%3CBR%20%2F%3E%5B38%2F39%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_secondary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fsdk%2FSDK_25_03_00_MIMXRT1170-EVKB%2Fdevices%2FMIMXRT1176%2Futilities%2Fstr%2Ffsl_str.c.obj%3CBR%20%2F%3E%5B39%2F39%5D%20Linking%20C%20executable%20freertos_message_buffers_secondary_core.elf%3CBR%20%2F%3EMemory%20region%20Used%20Size%20Region%20Size%20%25age%20Used%3CBR%20%2F%3Em_interrupts%3A%201%20KB%201%20KB%20100.00%25%3CBR%20%2F%3Em_text%3A%2027876%20B%20127%20KB%2021.44%25%3CBR%20%2F%3Em_data%3A%203280%20B%20127%20KB%202.52%25%3CBR%20%2F%3Em_ncache%3A%200%20GB%20256%20KB%200.00%25%3CBR%20%2F%3Em_data2%3A%200%20GB%20256%20KB%200.00%25%3CBR%20%2F%3Em_heap%3A%201%20KB%201%20KB%20100.00%25%3CBR%20%2F%3Erpmsg_sh_mem%3A%206%20KB%208%20KB%2075.00%25%3CBR%20%2F%3Ebuild%20finished%20successfully.%3CBR%20%2F%3E*%20Terminal%20will%20be%20reused%20by%20tasks%2C%20press%20any%20key%20to%20close%20it.%3C%2FP%3E%3CP%3E*%20Executing%20task%3A%20CMake%3A%20build%3C%2FP%3E%3CP%3EWorkspace%20is%20%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_primary_core%3CBR%20%2F%3Ebuild%20task%20started....%3CBR%20%2F%3E%2FUsers%2Fmelker%2F.mcuxpressotools%2Fcmake-3.30.0-macos10.10-universal%2FCMake.app%2FContents%2Fbin%2Fcmake%20--build%20%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_primary_core%2Farmgcc%2Fflexspi_nor_debug%20--target%20all%20--%3CBR%20%2F%3E%5B1%2F2%5D%20Building%20C%20object%20CMakeFiles%2Ffreertos_message_buffers_primary_core.elf.dir%2FUsers%2Fmelker%2FCodeProjects%2FAudioBox%2Fcode%2Fcode_primary_core%2Fmain.c.obj%3CBR%20%2F%3E%5B2%2F2%5D%20Linking%20C%20executable%20freertos_message_buffers_primary_core.elf%3CBR%20%2F%3EMemory%20region%20Used%20Size%20Region%20Size%20%25age%20Used%3CBR%20%2F%3Em_flash_config%3A%20512%20B%203%20KB%2016.67%25%3CBR%20%2F%3Em_ivt%3A%2048%20B%204%20KB%201.17%25%3CBR%20%2F%3Em_interrupts%3A%201%20KB%201%20KB%20100.00%25%3CBR%20%2F%3Em_text%3A%2072188%20B%2065271%20KB%200.11%25%3CBR%20%2F%3Em_qacode%3A%200%20GB%20256%20KB%200.00%25%3CBR%20%2F%3Em_data%3A%2022968%20B%20256%20KB%208.76%25%3CBR%20%2F%3Em_data2%3A%200%20GB%20504%20KB%200.00%25%3CBR%20%2F%3Erpmsg_sh_mem%3A%206%20KB%208%20KB%2075.00%25%3CBR%20%2F%3Em_core1_image%3A%2028996%20B%20256%20KB%2011.06%25%3CBR%20%2F%3Ebuild%20finished%20successfully.%3CBR%20%2F%3E*%20Terminal%20will%20be%20reused%20by%20tasks%2C%20press%20any%20key%20to%20close%20it.%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3EWhat%20could%20be%20causing%20this%3F%3CBR%20%2F%3E%3CBR%20%2F%3EI%20will%20try%20J-link%20firmware%20and%20see%20if%20that%20helps.%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2171595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RT1170%20EVKB%20Multicore%20project%20and%20LinkServer%20Flash%20programmer%20not%20working%20(mcuxpresso%20vs%20code)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2171595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F251274%22%20target%3D%22_blank%22%3E%40cyberhelmer%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3EThanks%20for%26nbsp%3B%20your%20interest%20in%20NXP%20MIMXRT%20series!%3C%2FP%3E%0A%3CP%3EDuring%20the%20failed%20operation%2C%20I%20noticed%20it%20was%20missing%20from%20the%20logs%3A%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20%20language-markup%22%3E%3CCODE%3EReleasing%20M4%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3EThis%20led%20to%20subsequent%20failures.%20We%20recommend%20updating%20the%20MCU-Link%20firmware%20and%20performing%20the%20following%20operation%20when%20debugging%20or%20programming%20again%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Gavin_Jia_0-1758167694150.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Gavin_Jia_0-1758167694150.png%22%20style%3D%22width%3A%20254px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F357422iD4D5B078A4526AD1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Gavin_Jia_0-1758167694150.png%22%20alt%3D%22Gavin_Jia_0-1758167694150.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EOn%20the%20other%20hand%2C%20based%20on%20my%20personal%20experience%2C%20using%20JLink%20firmware%20provides%20better%20stability.%20If%20possible%2C%20try%20replacing%20the%20MCU-Link%20firmware%20with%20JLink%20firmware.%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EGavin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2171443%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RT1170%20EVKB%20Multicore%20project%20and%20LinkServer%20Flash%20programmer%20not%20working%20(mcuxpresso%20vs%20code)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2171443%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EAlso%2C%20sometimes%20when%20I%20make%20changes%20to%20both%20cores%20and%20do%20a%20clean%20and%20rebuild%20of%20both%20projects%20only%20the%20m7%20is%20updated%20with%20the%20correct%20code%2C%20m4%20still%20runs%20an%20older%20version.%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
