So, section 34.7.2.2.2 (TCM Arrays) of IMXRT1170RM states the following for the CM4 core:
Is it possible for both code TCM and system TCM regions to be redefined in a custom manner?
Example custom allocations include:
I know this is possible for CM7's TCM space by reconfiguring the fuses.
Is the same kind of approach possible with CM4's TCM space?
解決済! 解決策の投稿を見る。
Unfortunately, the TCM size for M4 is not reconfigurable, it has a fixed size. I apologize for the inconvenience this may cause you.
Omar
Omar
...correcting example allocation in my previous post to stay in line with absolute range limits:
