RT1050 wifi module (WIFI_BOARD_AW_NM191MA) porting error message
yen_chen
when I porting wifi example from RT1050 wifi_cli to my project encounter memory allocation error message.
Could you tell me whether loss some setting or not?
danielchen
Hi @yen_chen
This issue seems to involve with memory issue. can not allocate enough memory for pmadapter private structure.
I would suggest you check the heap size.   in FreeRTOSConfig.h
Please try to increase the heap size
danielchen
Hi @yen_chen
