RT1050 bootloader
RT1050 bootloader
895 次查看
dskim2
I want to make a bootloader for IMXRT1050EVK.
The bootloader and application are stored in hyper flash, and the application is stored at 0x6008000.
The application memory is set as shown below.
After downloading the bootloader and application to flash, run it.
It seems that only the bootloader is running and the application is not running.
What's wrong?
The application was downloaded using the GUI Flash Tool as shown in the image below.
I am uploading the source as an attachment.
VTR_WOBD4_Boot is bootloader and hello_world is application
Best Regards
876 次查看
mjbcswitzerland
Specialist V
An off the shelf 1050 secure boot loader solution is available at https://www.utasker.com/iMX/RT1050.html
Documentation and video guides, including security analysis at https://www.utasker.com/iMX/developers.html
Mark
For our discounted i.MX and Kinetis stock availability see https://www.utasker.com/Shop/semi.html
