RT1024 USB Audio 2.0 Windows 10
1,114 次查看
asarbs
I;m working on some product that is using USB Audio 2.0. I have a communication from Linux Machines to my device via USB Audio 2.0 with out any problems, the same code on Windows 10 don't work, in Device Manager I got information about error code 10 "The specified range cannot be found in the range list" In Details under "problem status" i have 0xc000028c witch indicates that this might be an issue with Windows Driver? I'm attaching dump from USBView tool from Windows Debug toolkit with my USB descriptors configuration.
Any advice?
5 回复数
1,062 次查看
EdwinHz
Hi @asarbs,
Could you please try enabling the "USB_DEVICE_WORKAROUND_AUDIO_20_WINDOWS" macro definition under "usb_device_descriptor.h" file and let me know if this solves the issue?
BR,
Edwin.
1,017 次查看
asarbs
Sorry for late response, I have missed notification mail.
Unfortunately in my  code base I don't have any "USB_DEVICE_WORKAROUND_AUDIO_20_WINDOWS" macro.
1,008 次查看
EdwinHz
Hi @asarbs,
I would highly suggest you base your USB audio 2.0 application on our SDK drivers and examples, so you can enable the "USB_DEVICE_WORKAROUND_AUDIO_20_WINDOWS" macro that provides a workaround for the issue between the USB stack and Windows machines.
BR,
Edwin.
993 次查看
asarbs
I have based my solution on Examples and MCUXpresso IDE tool. We are glued to  SDK v2.13.0 Was USB_DEVICE_WORKAROUND_AUDIO_20_WINDOWS implemented in higher version?
979 次查看
asarbs
OK, I see that USB_DEVICE_WORKAROUND_AUDIO_20_WINDOWS is available in SDK 2.16. Thanks for your support.
标记 (1)
