PWMX output of RT1064EVK flexPWM
1,183件の閲覧回数
Alexander-cloud
hi
I am using flexPWM's PWMX to output PWM, which can output a 50 percent waveform, but it can only be output in debug mode, not in offline mode, I want to know what happened?
The implemented code is below
1,157件の閲覧回数
_Leo_
Hi Alexander,
Thank you so much for using our community.
Could you please tell me if the complete image does not work or only does not generate the PWM? And if you are working in UART or in semihost? Could you try with the evkmimxrt1064_pwm SDK example and tell me your results please?
