Not able to mass erase/flash after running AN12255SW Flash Remap
schafbo
After running the example AN12255SW "Flash Remap Test" in MCUXpresso, I'm not able to reflash my RT106x. Also I'm not able to do a mass erase in order to reprogram again. I'm using an MCU-Link (LinkServer) debugger with MCUXpresso. Any attempt to program/mass erase shows that 0 SWD devices are connected, then I receive the following serial output when performing a mass erase:
Executing flash operation 'Erase' (Erase flash) - Fri Jan 10 08:57:39 CST 2025
Checking MCU info...
Scanning for targets...
Executing flash action...
MCUXpresso IDE RedlinkMulti Driver v11.10 (Jul 2 2024 19:33:51 - crt_emu_cm_redlink.exe build 741)
( 0) Reading remote configuration
Wc(03). No cache support.
Found chip XML file in C:/Users/.../workspace/flash_remap_test/Debug\MIMXRT1062xxxxA.xml
( 5) Remote configuration complete
Reconnected to existing LinkServer process.
Connecting to probe 1 core 0 (using server started externally) reports:
'Ee(42). Could not connect to core.'
Retrying...
Server OK but no connection to probe 1 core 0 (after 3 attempts) - Ee(42). Could not connect to core.
============= SCRIPT: RT1060_connect.scp =============
RT1060 Connect Script
DpID = 0BD11477
Error: Wire Ack Fault - target connected?
Disabling MPU
Configure FlexRAM for 768KB OC RAM, 128KB I-TCM, 128KB D-TCM
Finished
============= END SCRIPT =============================
Failed on connect: Ee(42). Could not connect to core.
No connection to chip's debug port
(100) Target Operation Failed
Unable to perform operation!
Command failed with exit code 1
I've encountered problems reflashing before, but usually this is solved by erasing the chip and then programming again.. is there a way to recover from this and test AN12255SW again?
diego_charles
Hi @schafbo
Have you tried an erase when the MCU is in serial  downloader mode? If SWD keeps failing, please try to do a recover using MCUXpresso Secure Provisionining Tool, this tool sends erase commands over UART/USB.
Please let me know your results.
Diego
schafbo
Nevermind, I see that LPUART1 is used. After setting the boot mode pins I was able to set the MCU into serial download, then reset and program again. Thanks!
diego_charles
Hi @schafbo
Thank you for letting us know! I am glad that you can keep developing.
Diego
schafbo
Diego,
I'm not using an eval board, but the boot mode pins can be set to serial download with some effort. I am using the process outlined in the doc "Recover_RT1064". Is there a specific UART line on the MCU that I need to use, or it can work with any of them?
diego_charles
Hi @schafbo
Diego
%3CLINGO-SUB%20id%3D%22lingo-sub-2025904%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ENot%20able%20to%20mass%20erase%2Fflash%20after%20running%20AN12255SW%20Flash%20Remap%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2025904%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EAfter%20running%20the%20example%20AN12255SW%20%22Flash%20Remap%20Test%22%20in%20MCUXpresso%2C%20I'm%20not%20able%20to%20reflash%20my%20RT106x.%20Also%20I'm%20not%20able%20to%20do%20a%20mass%20erase%20in%20order%20to%20reprogram%20again.%20I'm%20using%20an%20MCU-Link%20(LinkServer)%20debugger%20with%26nbsp%3BMCUXpresso.%20Any%20attempt%20to%20program%2Fmass%20erase%20shows%20that%200%20SWD%20devices%20are%20connected%2C%20then%20I%20receive%20the%20following%20serial%20output%20when%20performing%20a%20mass%20erase%3A%3C%2FP%3E%3CP%3EExecuting%20flash%20operation%20'Erase'%20(Erase%20flash)%20-%20Fri%20Jan%2010%2008%3A57%3A39%20CST%202025%3CBR%20%2F%3EChecking%20MCU%20info...%3CBR%20%2F%3EScanning%20for%20targets...%3CBR%20%2F%3EExecuting%20flash%20action...%3CBR%20%2F%3EMCUXpresso%20IDE%20RedlinkMulti%20Driver%20v11.10%20(Jul%202%202024%2019%3A33%3A51%20-%20crt_emu_cm_redlink.exe%20build%20741)%3CBR%20%2F%3E(%200)%20Reading%20remote%20configuration%3CBR%20%2F%3EWc(03).%20No%20cache%20support.%3CBR%20%2F%3EFound%20chip%20XML%20file%20in%20C%3A%2FUsers%2F...%2Fworkspace%2Fflash_remap_test%2FDebug%5CMIMXRT1062xxxxA.xml%3CBR%20%2F%3E(%205)%20Remote%20configuration%20complete%3CBR%20%2F%3EReconnected%20to%20existing%20LinkServer%20process.%3CBR%20%2F%3EConnecting%20to%20probe%201%20core%200%20(using%20server%20started%20externally)%20reports%3A%3CBR%20%2F%3E'Ee(42).%20Could%20not%20connect%20to%20core.'%3CBR%20%2F%3ERetrying...%3CBR%20%2F%3EReconnected%20to%20existing%20LinkServer%20process.%3CBR%20%2F%3EServer%20OK%20but%20no%20connection%20to%20probe%201%20core%200%20(after%203%20attempts)%20-%20Ee(42).%20Could%20not%20connect%20to%20core.%3CBR%20%2F%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20SCRIPT%3A%20RT1060_connect.scp%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3ERT1060%20Connect%20Script%3CBR%20%2F%3EDpID%20%3D%200BD11477%3CBR%20%2F%3EError%3A%20Wire%20Ack%20Fault%20-%20target%20connected%3F%3CBR%20%2F%3EError%3A%20Wire%20Ack%20Fault%20-%20target%20connected%3F%3CBR%20%2F%3EDisabling%20MPU%3CBR%20%2F%3EError%3A%20Wire%20Ack%20Fault%20-%20target%20connected%3F%3CBR%20%2F%3EError%3A%20Wire%20Ack%20Fault%20-%20target%20connected%3F%3CBR%20%2F%3EConfigure%20FlexRAM%20for%20768KB%20OC%20RAM%2C%20128KB%20I-TCM%2C%20128KB%20D-TCM%3CBR%20%2F%3EError%3A%20Wire%20Ack%20Fault%20-%20target%20connected%3F%3CBR%20%2F%3EError%3A%20Wire%20Ack%20Fault%20-%20target%20connected%3F%3CBR%20%2F%3EError%3A%20Wire%20Ack%20Fault%20-%20target%20connected%3F%3CBR%20%2F%3EFinished%3CBR%20%2F%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20END%20SCRIPT%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3EFailed%20on%20connect%3A%20Ee(42).%20Could%20not%20connect%20to%20core.%3CBR%20%2F%3ENo%20connection%20to%20chip's%20debug%20port%3CBR%20%2F%3E(100)%20Target%20Operation%20Failed%3CBR%20%2F%3EUnable%20to%20perform%20operation!%3CBR%20%2F%3ECommand%20failed%20with%20exit%20code%201%3C%2FP%3E%3CP%3EI've%20encountered%20problems%20reflashing%20before%2C%20but%20usually%20this%20is%20solved%20by%20erasing%20the%20chip%20and%20then%20programming%20again..%20is%20there%20a%20way%20to%20recover%20from%20this%20and%20test%26nbsp%3BAN12255SW%20again%3F%3C%2FP%3E%3CP%3EThanks%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2025904%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MXRT%20106x%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2032602%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Not%20able%20to%20mass%20erase%2Fflash%20after%20running%20AN12255SW%20Flash%20Remap%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2032602%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F244267%22%20target%3D%22_blank%22%3E%40schafbo%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThank%20you%20for%20letting%20us%20know!%20I%20am%20glad%20that%20you%20can%20keep%20developing.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EDiego%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2032441%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Not%20able%20to%20mass%20erase%2Fflash%20after%20running%20AN12255SW%20Flash%20Remap%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2032441%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENevermind%2C%20I%20see%20that%20LPUART1%20is%20used.%20After%20setting%20the%20boot%20mode%20pins%20I%20was%20able%20to%20set%20the%20MCU%20into%20serial%20download%2C%20then%20reset%20and%20program%20again.%20Thanks!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2031705%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Not%20able%20to%20mass%20erase%2Fflash%20after%20running%20AN12255SW%20Flash%20Remap%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2031705%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDiego%2C%3C%2FP%3E%3CP%3EI'm%20not%20using%20an%20eval%20board%2C%20but%20the%20boot%20mode%20pins%20can%20be%20set%20to%20serial%20download%20with%20some%20effort.%20I%20am%20using%20the%20process%20outlined%20in%20the%20doc%20%22Recover_RT1064%22.%20Is%20there%20a%20specific%20UART%20line%20on%20the%20MCU%20that%20I%20need%20to%20use%2C%20or%20it%20can%20work%20with%20any%20of%20them%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2026068%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Not%20able%20to%20mass%20erase%2Fflash%20after%20running%20AN12255SW%20Flash%20Remap%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2026068%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F244267%22%20target%3D%22_blank%22%3E%40schafbo%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EHave%20you%20tried%20an%20erase%20when%20the%20MCU%20is%20in%20serial%26nbsp%3B%20downloader%20mode%3F%20If%20SWD%20keeps%20failing%2C%20please%20try%20to%20do%20a%20recover%20using%20MCUXpresso%20Secure%20Provisionining%20Tool%2C%20this%20tool%20sends%20erase%20commands%20over%20UART%2FUSB.%3C%2FP%3E%0A%3CP%3EPlease%20let%20me%20know%20your%20results.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EDiego%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
