I am working with an i.MX RT1170 and external NOR flash S25FL128LAGMFM010.
I generated an fcb.bin using the MCUXpresso Secure Provisioning Tool, and this binary works perfectly with my board. However, when I use the flexspi_nor_config.c inside MCUXpresso IDE (generated/modified manually), I face issues during debug and get the error please find the attachment for error.
It seems that the .c configuration I made in MCUXpresso does not match the working fcb.bin.
I need support on:
How to correctly write or align flexspi_nor_config.c with the parameters of my working fcb.bin?
Is there a way to convert the fcb.bin into flexspi_nor_config.c for direct use in projects?
Are there any reference files for flexspi_nor_config.c specific to the S25FL128LAGMFM010?
Any guidance or example configurations would be greatly appreciated.
Thanks in advance!
