Need some information on how to build, flash and execute project using IAR IDE through command line in linux.
I have installed bxarm-9.40.1-unprotected.deb
in linux and the path is /opt/iarsystems.
wanted to know how can I use this to build the project.
Surabhi.
Hi @surabhi_sk30 ,
Please refer to my document:
https://community.nxp.com/t5/i-MX-RT-Knowledge-Base/RT-Linux-SDK-build-based-on-Ubuntu/ta-p/1690185
It will tell you how to build the RT Linux SDK demo. But it is the ARM GCC demo.
Wish it helps you!
Kerry
Hi @kerryzhou
Thank you for the info but, I have tried this ARMGCC tool chain
If you have any idea on below toolchain how to build the project can you please share the details.
" /opt/iarsystems$
bxarm bxarm-9.40.1"
Surabhi
Hi @surabhi_sk30 ,
To the IAR linux situation, I think, you may can create case to the IAR side, they will be more familiar with their tools.
You can ask question here:
https://www.iar.com/knowledge/support/request-technical-support
As I am also not familiar with the IAR linux version.
Wish it helps you!
Kerry
