MIMXRT1170 how to remove uboot in QSPI flash
yunlian
    I tried to install the BSP from emcrafts to install linux on the board.
    Now the devices uses the uboot on the QSPI flash to boot to linux every time. I want to go back to
the default system so that I can play with the MCUXpresso SDK. But I don't know how to do that.
   The emcrafts people told me "bringing the board back to the factory state is just erasing U-Boot in the QSPI Flash", So my question becomes how to access and remove files in the QSPI flash.
yunlian
Omar_Anguiano
Hello!
I hope you are well.
You can erase the content from the flash by using MCUBoot Utility: GitHub - JayHeng/NXP-MCUBootUtility: A one-stop boot utility tool based on Python2.7+wxPython4.0, it...
Please note that to use you need to set your board in Serial Downloader mode.
If you have more questions do not hesitate to ask me.
Omar
