I Designed my MIMXRT106F based PCB. we use this IC for face recognition project. I found a section in project properties named BOARD_FLASH_LICENSES. what is this section? is there any license we need to buy?
Solved! Go to Solution.
1) What is this section? is there any license we need to buy?
-- Firstly, I was wondering if you can introduce which project you used, as I've no idea about the section you mentioned, next, you needn't to buy a license to run the Face recognization library on RT106F.
TIC
TIC
