I'm having trouble converting OrCAD design file, specifically .brd format, into Altium. Can someone convert it and post here? Altium prefers .alg format rather than .brd
I think it can be done via OrCad itself or extracta.exe
Solved! Go to Solution.
Hi @MaxYildiz
Please check the private message, I already send you the files through the message, as I can't send it in the public isde.
Wish it helps you!
kerry
Hi @MaxYildiz
Wish it helps you!
kerry
Hi Kerry,
I would appreciate if you send me RT1060 Altium (converted) layout design files.
Alfan
Hi @Alfan ,
If you need the AD file, please create your own case, then we send you in your case privately.
This is the case create flow:
1. Open below SUPPORT site, click blue "Go to Tickets" in the middle.
http://www.nxp.com/support/support:SUPPORTHOME
2.Then you will be requested to Login, if you have no an account, please first Register with your business email.
3.After login, please "Create New Cases" button in the middle, then you can submit your question.
Kerry
