MIMXRT1060-EVK: Power Consumption Measurement of the MCU
759件の閲覧回数
matthiasroedder
Hello Everybody,
I'm using the MIMXRT1060 Evaluation Kit for some Machine Learning Applications. Now I want to measure the power consumption of the MCU (i.MX RT 1060). I don't want to know the power consumption of the whole board. I have the Board's Schematic, but I have no clue where to measure.
I thought, maybe there is an extra pin to read the power consumption? If not maybe I can solder a shunt resistor to get the input current? Any Ideas or advice? Thank you in advance!
Best Regards
Matthew
743件の閲覧回数
Alexis_A
Hello @matthiasroedder,
I will suggest taking a look at the following application note. This has many tips about current consumption.
https://www.nxp.com/docs/en/application-note/AN12245.pdf
Alexis Andalon
730件の閲覧回数
matthiasroedder
Hey @Alexis_A !
Thank you very much. That looks helpful.
Matthew
