- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
Hi All,
I am not able to access PIT timer base address(0x40084000) in Linux tried both absolute address and remapping. Any suggestions, Please let me know. The kernel just hangs on read also. Thanks.
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @Miguel04 Thanks, I got it working. What should be the value for Load register to get 5 micro sec resolution interrupts, using OSC clk (24Mhz) Thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @sbabu
Can you provide more details please.
Which linux distribution are you using?
Are you getting a HardFault when trying to access the address?
Are you using MCUXpresso IDE? Is it a custom project?
Best Regards, Miguel.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @Miguel04 We are using ucLinux customized for RT1024. Not using mcuXpresso. There is not crash messages or panic, it just hangs.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @sbabu
The i.MXRT crossover MCUs are not made to run linux, so we do not support this type of questions.
However I can recommend you to look into this post.
Also, verify what are you trying to do on the PIT address and if the module's clock is enabled, if the clock is not enabled this can cause the MCU to get a hardfault.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @sbabu
I'm glad you have your project working.
You can see the PIT driver example on the SDK.
It uses the next formula to calculate the value:
count = us*clockFreqInHz / 1000000
and the value is written on the register:
base->CHANNEL[channel].LDVAL = count - 1U;
I recommend you to look into the SDK example.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@Miguel04 Thanks. Even If I set the LDVAL to generate interrupt at 10 or 70 microsecond, Its trigerred at fixed 40 micro seconds. Any pointers?
